Question about Samsung MW888STB 800 Watts Microwave Oven
I have a samsung microwave that has not been used just a few months,no longer than app.seven. it is completely risted out and metal paint is dropping into the bottom everytime i use is. is it still good unsder your warranty. my daughter bought it for me when I moved and does not have the receipt. I feel as it is certainly defected because there is hardly no paint left in it,can you please help me?
    Top Expert:
  • Samsung Master
  • 24,373 Answers
Speaking an a retired Samsung Main Repairs Agent, it is not covered by warranty, as the paint peels if left wet after cooking/steaming etc.
If you get into the habit of leaving the door open until it cools down each time, it would have given you good service.
Posted on Aug 06, 2017
2 Suggested Answers
MicrowaveSvc
  • 9098 Answers
SOURCE: samsung otr microwave vent quit working
Since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
You can find your nearest Samsung-authorized service center here.
Posted on Jul 20, 2009
MICROWAVE TAKES LONGER TO COOK EVEN ON HIGH AND OCCASIONALLY SPARKS FOR NO REASON
inside your micro... walls are made of metal but protected with paint, if this paint is gone and the metal shows thats what happend you have to repaint the unprotected areas again, and the reason your micro... is not working so good anymore is due to the magnetron
Jan 31, 2014 | Sharp R-930AK Convection/Microwave Oven
Lg combi multiwave
see the troubleshooting section and follow the steps and fix it.
God bless you
Waveguide Cover
If the microwave is sparking or arcing the waveguide cover might be damaged and shorting out. Try removing the waveguide cover and see if the problem goes away. If there are any damaged spots in the microwave ceiling or sidewalls, repair them and paint them with microwave oven paint. Replace the waveguide cover if it is burnt or if it will not stay in place.
Microwave Oven Paint
If the microwave is sparking or arcing on the side walls the paint might have chipped causing pitting in the metal oven wall. Use microwave safe paint to touch up any bare metal spots.
Rack Support
If the microwave is sparking or arcing near one of the rack supports, remove the support, repaint any bare metal, install a new support.
Sep 30, 2013 | Microwave Ovens
Microwave when turn on making a noise and sparks comin from fan area?
follow this steps and fix it. God bless you
Waveguide Cover
Rack Support
Feb 06, 2013 | Turbo Air TMW-1100M Green World 1000 Watt...
When I use my microwave, it seems it was spark happening when I use it. I'm afraid to test it again. Please tell me how I should know it's safe to use
2 things cause sparks.... a damaged Waveguide RF window or bare metal inside the cooking area. If you note bare metal you can sand and paint it with an appliance enamel paint. (no lead paint!) Just make sure to only sand the area your painting as any sanding scuffs not painted will hasten a repeat performance of the sparking routine. The RF will bounce off bare metal and cause the sparking. Once PROPERLY painted it no longer sparks.
If it is coming from the area of the Waveguide RF window... Make sure the window is replaced before next use.
Thanks for choosing FixYa,
Kelly
Apr 21, 2011 | Frigidaire Model PLMVZ169GC Microwave Oven
I have a sansung microwave. Is it harmful to use if inside the top of the micro is peeling paint. Use alot for heating water for tea. Please advise Thank you
The paint plays no role in protecting you from the microwaves. The metal case is what contains the radiation, so you should be just fine.
Dec 03, 2010 | Samsung Microwave Ovens
Inside my Daewoo KOR-6Q27 microwave oven, underneath rotating glass plate, white layer (or paint) have piled off and rust have started to emerge. Can this problem be fixed or i have to buy a new one? Was...
I have painted many Microwave oven cavities. You have to sand down the pealed off rusted areas and completely clean and degrease. Before painting, I use laquer thinner as a cleaner degreaser. Fumes can be a bit strong but it has worked well of me. I normally buy an automotive spray paint. They have a lot of different colors and a lot of the import colors can really come close to the color inside the microwave. Spray on thin layers till you get good coverage and make sure you let it dry thoroughly before trying to use. The paint in a Microwave isi not a special microwave energy protective paint. it is only there to make it look pretty and protect the metal. So a good automotive paint normally works fine.
Sep 25, 2017 | Daewoo Microwave Ovens
Was cleaning inside of microwave and noticed the paint was bubbled and when I cleaned this area, all paint came off and metal was exposed 9about a 2 inch area). Should I use the microwave or will arching...
Hi Bonnie,
Do not use the microwave with the exposed metal surface.
What you can do is pick up some appliance touch up paint, it comes in a small plastic bottle with a brush. It looks similar to fingernail polish. It should be available at an appliance store such as Sears, Lowes, Home Depot etc.
Clean the area good and use sandpaper or steel wool if needed to make sure the area is smooth and clean. Then use the touch up paint to recoat the surface. Let dry before using the microwave oven, usually a couple hours or so.
May 01, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Enamel under the glass turntable has flaked off
This is due to spills, accumulated moisture from steam / condensation, or both.
It can also be worse if your internal cooling fan is not running, or if the vents or filters are blocked or clogged.
Since the the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and then dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Let it dry overnight with the microwave door open.
Once that's done, you should occasionally look for accumulated moisture on the floor of the oven and keep it dry.
The model number tag should tell you where it was made.
Jan 07, 2009 | Magic Chef MCB780W Microwave Oven
Paint off inside top of microwave exposing metal. Safe to use?
It would be dangerous to do so. Any exposed metal inside a microwave is source for sparks and is extremely hazardous. I would recommend getting the paint job done up, or even better, buy a newer model.
Nov 15, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
PEELING PAINT INSIDE MICROWAVE/TOASTER OVEN
I do have the same problem, but I know they make microwave paint if you can get it from an appliance store or you can order through the web - BUT 2 sites I just looked at said a gloss enamel paint, such as that used to paint "model" toys works just as well. In either case: Smooth the old stuff off, sand lightly (you want no metal dust left -or- damaging any coating on the metal) just sand enough to make sure there's no flakes & it's smooth, then use a gloss enamel paint rather it's approved for microwaves or the Testor's kind.
NEXT -Make sure you DRY with Hairdryer to set the paint, and keep the heat to med or low, don't bubble or scorch your work!) and do not use the microwave for 24 hours!! Leave the door open while drying for several days afterwards if you can. Any fume smells can be absorbed by using -used- coffee grounds and leaving overnight. Google groups was one source the other was a repair listing forum.
Aug 30, 2008 | Microwave Ovens
Samsung MW888STB 800 Watts Microwave Oven Logo
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
