Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Won't retain power, only stays on when you hold power button
2 Suggested Answers
rabbitbrains
  • 575 Answers
SOURCE: The power button on my Dyson DC19T2 won't stay on
The switch is broken. If you are handy, remove the old switch and match it up at a hardware store or a Vacuum repair shop. It shouldn't cost much to have it replaced by a proffessional either.
Posted on Nov 18, 2011
Vax zoom not staying on
It is likely that the button (switch) is defective and will have to be replaced
Jun 28, 2013 | VAX Appliances Vacuums
Vacuum won't stay powered without holding the button down.
This is over a year too late, but perhaps this will help other people in your situation. Here is how the switch assembly should go together:
Jan 26, 2013 | Dyson Vacuums
Nov 18, 2011 | Dyson Vacuums
My dyson dc14 all floors won't stay on when I press the power button. I can hold it down and it will work, but that makes cleaning very slow.
Quick Fix...takes 4 minutes max
Remove the switch by using instructions here:
http://www.sparesaver.com/vacuum-spares/help-and-support/dyson-section/dyson-technical-advice-450/dyson-dc14-technical-advice-474/replacing-the-cable.html
(The was an additional torx screw 3 " below the one in the directions...yours may have this too...just remove)
Then...While holding the body of the switch in one hand, use your other to hold both contacts between your thumb and forefinger and gently place pressure on each contact in the opposite direction, just like screwing a nut onto a bolt. Press the switch down while applying this torque and see if it sticks. If it does just bend the contacts slightly and continue pressing the switch to ensure it holds. Reinstall switch.
I still advise buying a switch from amazon for $4.00 and replacing it but this will help you to continue to use your vacuum in the meantime without having to hold the button...
Aug 11, 2011 | Dyson DC14 Telescope Reach All Floors...
My dyson power button won't stay on unless you hold the button down. Is there anything that I can trouble shoot to fix the problem or is the button broke? If broke where can I go for repair?
Sorry to hear you're having difficulties with your DC24. If the on/off switch won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Customer Service
Jul 30, 2011 | Dyson Ball DC24 Bagless Upright Vacuum
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
I am trying to replace the belt on my bissell. The directions state "remove the screw that holds the red retainer in place, set red retainer arm and screw aside. I see the red retainer but can not get...
Did you release the handle first before you flipped it over?
Have you removed the screw and it still won't come out, or is it stuck even after the screw is out?
Are you having trouble getting to it?
Please reply back with more info.
Thanks,
Handie Andie
May 09, 2011 | Bissell 1699 ProHeat Clear View Upright...
Power button not engaging...vacuum will not stay
The power button is worn out and needs to be replaced. That vacuum is pretty simple. So even if you don't know how to take it apart it shouldn't cost much to have it repaired.
Nov 08, 2009 | Dyson DC14 All floors Bagless Upright...
Power won't stay on unless you hold the button down . How can I fix this and what is the problem?
You can't fix this problem yourself - a repair dealer needs to open up the button and inspect the power switch - call the Dyson helpline, they will find the closest authorized dealer in your area and if your machine is still under warranty it'll probably fixed under warranty for you.
Jun 24, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
73 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
