Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hi, my Hotpoint Aquarius + WF630 screen has what looks like something E5 something on the screen and goes from prewash through to spin within a few moments and no water enters. i have made sure the drain fitter etc is clear, thanks for any help. Cheers Tom.
    Brigadier General:
  • 6,277 Answers
If you have cleaned the drain filter AND checked the operation of the drain motor, for Hotpoint (and the manufacturer Indesit) E5 states ' pressure switch jammed on full or pump blocked- check switch and module'. Sometimes there can be bad connections between plugs/cables/module (PCB). If you haven't done already please make sure that the pump does actually work by removing the filter, seeing the pump motor and putting the machine on spin. You should see it rotate! Otherwise it looks like a service call ;-0(
Good luck,
John C
Posted on Mar 20, 2011
Hi my wf220 won't do a full cycle the prewash flashes all the time if i put it onto wash it just sticks on wash all the time but will spin if i just set it to rinse n spin or just fast spin could you help...
My guess is heating element, if its broke it wont heat water and because the thermostat does not detect hot water the machine does not move onto next step. i suspect you will not be able to do a prewash.
Part cost ££20 to £30
My machine has same problem but im struggling to pull out the eliment.
Jan 15, 2011 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint washing machine, model WF630, Error F-03???
Error code F03 is indicating a problem with the wash thermistor, it could be open or short circuit.
Check connections on thermistor and heater element.
Hope this helps.
Dec 15, 2009 | Hotpoint Aquarius WD640 Front Load...
I cant find my filter
It is either behind the kick plate at the front or in the pipe on the bottom of the drum which runs to the pump.
This is acessed by removing the panel at the back.
Hope this helps & thankyou for using Fixya.
Jan 19, 2009 | Washing Machines
My washe keeps reading either F04 or F05
F04 - Pressure switch jammed on empty while F05 is a blocked filter.
Check that the pump is working o/k, if it seems o/k and it drains o/k, then you have no alternative than to call an engineer.
This really is your only option.
Plz rate my solution
Thanks.
Jan 19, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Error message LE5E and would only oparate prewash
it's not on 'test' is it,
try turning the machine on while pressing the start and on buttons together until dOFF apears.
Jan 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing machine WMA54 Hotpoint sticks on prewash
I realised that the washer was not filling properly with water!  So I pulled it out from the wall and noticed the cold water fill pipe had been squashed and had a kink in it so not enough water was getting through.  I remedied this by pulling the pipes through the under sink cupboard and securing them with gaffer tape,  Hey presto the machine now works again!  Hooray :D
Oct 06, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
128 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
