Question about HP Office Equipment & Supplies
Wide black strip across all pages that are photocopied. Have requested assistance once already but heard nothing from HP. I have had the printer for about 2 1/2 months but did not install it until last week. Please respond. Leslie Gibson
  • gisley Aug 08, 2008
    Lets just pretend that I dont have a clue about computers, printers etc. Where might I find the charger cleaner?
    Thank you for your response I do hope I can figure out where the charger cleaner is.
    Gisley
    Novelist:
  • 158 Answers
Check the charger cleaner. It is a plastic piece that you can slide back and forth to clean the charger. Make sure it is pushed all the way to the end. Otherwise, if it is left in any other position, it will leave a black bar across any prints.
Posted on Aug 02, 2008
  • Phil Oellrich Aug 08, 2008
    If you can please tell me the brand name and most important, the model number of your printer, I can probably give you a better idea of where the charger is located, and how to access it if I know the model number. thank you.
The CM2320nf printer has random 1/2" wide black
Really sounds like a defective cartridge or bad contact. Have you changed any of the toners recently? If so, try another cartridge of the color that you just changed.
Mar 16, 2011 | HP Laserjet CM2320nf All-In-One Color...
A thin line also appears on the photocopy.why and what is the solution?
The page goes thro the feeder mechanism and passes over a thin strip of glass; maybe about 1/4 inch wide and runs across the fax under the cover where the paper is fed. You probably have dirt,corrector fluid or something like that on the glass this will cause the problem of a black line down the page to appear at the other end when you send a fax...and also to appear on your pages when you make a copy...open up the machine and clean the glass...cant help any more as you didnt state make or model.
Nov 04, 2010 | Office Equipment & Supplies
Error code 5100 on mx700 printer
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This part is related to the optical encoder which tells the print head where it is. Look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start up sequence. Softly clean this strip with a damp lint free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Jan 28, 2010 | Office Equipment & Supplies
I have a canon MX700 and it is showing error code 5100, I looked it up in the manual and there is nothing for this code..help!
Try this.....
There is a thin (1/4"wide) plastic strip running across the width in front of and below the drive belt. This is part of the optical encoder that tells the print-head where it is. If you look closely, there are fine black vertical lines on this strip. If the strip gets a piece of crud on it, you get an error during the start-up sequence. Gently clean this strip with a damp lint-free tissue. This also fixed a gap in the printing running lengthwise (not across the page like a clogged head).
Sep 09, 2009 | Canon PIXMA iP90 Mobile Printer
Photocopy has black band at end of the page
well ithink tou are using the ADF to copy something...you will have to clean the scanner glass(not the scan bed but when you lift the ADF cover you will see a scanner glass about inch wide)...it should resove your concern...
Mar 27, 2009 | HP Photosmart C7280 Printer
Repeating wide smudgy horizintal line across my printed pages
I had the same problem, replaced the PCR in the cartridge, the small black drum that pre charges the drum and erase the old image.
After that print was all back ok.
Regards
Dec 11, 2008 | HP Q2613A OEM Genuine Black Laser Toner...
Black vertical strip showing on copied and scanned documents
Sometimes this is caused simply by a bit of dirt or dust on a part of the scanner's lens. Since the page is fed through a horizontal "strip" style scanner, something blocking the light on a little piece of it will cause a long black strip all the way down the page.
Here's a guide showing you how to go about cleaning it:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00899181&lc=en&cc=fr&dlc=fr&product=3382186&rule=18644&lang=fr
Remember to use a soft, non abrasive lint free cloth! Like a glasses cleaning cloth or a camera/binoculars lens cloth. Last thing you want to do is scratch the glass :P.
Jan 27, 2008 | HP Photosmart C6100 All-In-One Printer
Line Across Page
There could be something on the scan glass. You have to open the cover on the scanner and look across the scanner glass. It is only about a half to an inch wide strip that the original passes over.
If there is nothing on that glass then some of the segments in that array have gone bad and it would need to be replaced.
Dec 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Scanner & black pages
The black printing usualy occurs when there is a faillure in the light, since your light is working fine, there may be a problem in the imaging device inside(camera) or the reflector. There is nothing wrong with the cartridge.
May 05, 2007 | HP PSC 1510 All-In-One InkJet Printer
50 people viewed this question
Ben Johnson
