Question about Freestyle Nomad Watches: Nomad Black Watch
I have a Freestyle Nomad. The temperature function is showing a much lower temp that what is correct.
How do I change the watchband on a freestyle fs81322 watch
GOOGLE IT I JUST LOOKED THEY SHOW YOU HOW TO TAKE IT APART
Nov 19, 2016 | Freestyle Watches
Ultronic clock, humidity & temperature. How does one read the "Temperature Trend" scal on the lower left of the screen. There are three scales shown and the indicators on the scale keeps...
This clock keeps track of the temperatures for each of the last 12 hours. So on the bottom, you'll see the temp at 12 hours ago (-12), 6 hours ago (-6), etc. On the left side, you'll see the temperature in Farenheit go from +5.4 to -5.4 from where it is currently. So if the temperature is 70F degrees right now, and it was 65F degrees 12 hours ago, then it'll show -5 in the first -12 column. It will always be at 0 for the current hour on the right. The scale on the right is in Celcius so it does the exact same thing as Farenheit.
Mar 01, 2011 | Watches
What is the correct battery for my freestyle model 750
The manufacturer does no recommend that you replace batteries yourself (presumably to ensure that it retains the waterp.roof seal)
See excerpt from their web site support.
"Do not attempt to repair the watch yourself. It is strongly recommended that a certified jeweler, watch repair technician or Freestyle service center replace your battery. This will help in preventing water leakage from improper battery replacement, which is not covered in your warranty. "
Dec 27, 2009 | Freestyle Shark Buzz Wrist Watch
The watch will show incorrect time within hours of
Usually this is a faulty battery - make sure you go to a reputable jeweller and have the battery changed. Even somewhere like Kmart will only use decent quality batteries.
I bought batteries off eBay once that were very cheap, and I had this problem all the time. Now I only buy Energizer, Duracell, etc.
Nov 25, 2009 | Freestyle Watches
My tissot t touch shows a temprature way low than the real one.
The watch will show body temperature until you remove it from your wrist and leave it in the open air for a few hours whilst it acclimatises and then reads the ambient temp, not your body temp.
This renders the thermo pretty useless.
Aug 17, 2009 | Tissot T-Touch T33759851
Help me please by using my tissot t-touch. my thermo function show´s 80 C on the display. i expected 30 C. But i can´t find a way to reset the values ?
The thermo function will show your body temperature while you wear the watch. For ambient air temperature, remove the watch and let it settle to ambient temp for about 15 minutes. Then it will read correct air temperature.
Jul 19, 2009 | Tissot T-Touch T33759851
Can't set the time!!!!
the instruction aren't much help either. this was a watch they discontinued pretty shortly after they released it. poor instructions and poor usability. great watch company though. this one was just a dog.
this was taken from a page off amazon: "Try to use the following for setting.
Press/hold with the upper left button until LIGHT OFF on the display.
Use lower left to select hour, min, date........
Use upper/lower buttons for adjust hour, min, date......
Press upper left to exit setting."
it worked for me. i have several of their watches, but like i said, this one was one of their "dogs"
Feb 14, 2009 | Freestyle Cortez Mid Watch
I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
Oct 16, 2008 | Freestyle Digital 79801 Watch
Freestyle watch
Press the mode button (bottom left) to cycle through all the watch modes. The last mode is the time setting mode. Yeah, not the usual way watches work in my experience. But have had this watch for 8 years or so and like it because of the big numbers and that it always shows the time while you're in other modes. But now today for the first time it somehow went into "chime" mode (beeps on the hour) and I can't figure out how it got there or how to undo it!
Feb 03, 2008 | Freestyle Shark CX4 7090111 Wrist Watch
Freestyle Nomad Watches:  Nomad Black Watch Logo
53 people viewed this question
Top Freestyle Watches Experts
ray gallant
Are you a Freestyle Watch Expert? Answer questions, earn points and help others
