I need the installation instructions for a neutral drain pack whurlpool number part 388253
    Brigadier General:
  • 6,277 Answers
Sorry but this forum does not supply any type of manual, installation instructions or schematic diagram direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
May I also suggest you try the manufacturer's web site direct? You may find, however, that it will supply only to service engineers but good luck anyway.
John C.
Posted on Mar 20, 2011
Washer drains but wont spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If it will drain (AND AGITATE) but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
See the Whirlpool / Kenmore Service manual for top load direct drive washers.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
WHIRLPOOL TRANSMISSION DESCRIPTION AND SPRINGS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/2550f737b3129b0c85256b0600504738/$FILE/787772%20%234.pdf
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
When ours had a similar problem, we looked at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) and noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
May 13, 2010 | Washing Machines
After draining the spin cycle wont activate
If it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
Mar 28, 2010 | Washing Machines
Kenmore washer drains but wont spin
If you it will drain but won't spin the problem is likely in the transmission. "Neutral Drain Assembly".
motor aside.
Jan 30, 2010 | Kenmore Washing Machines
Kenmore series 70 washing machine will pump water out of the tub but it won't spin the tub during the draining. Whats up?
This is the Whirlpool / Kenmore service manual for top load, direct drive washers.
It also has a troubleshooting guide.
Since it will drain the problem is likely in the transmission.
We had the same problem that pointed to the transmission "Neutral Drain Assembly".
Jan 26, 2010 | Kenmore Washing Machines
Pump works, but tub won't spin
This is the Whirlpool PDF on installation and maintenance of direct drive washers.
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase.
If you lift the lid, put it down again and the washer begins to spin, or only the drain worksw the problem is likely in the transmission "Neutral Drain Assembly".
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again.
The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
The top agitator uses a plastic 1/2" drive bolt. A 1/2" socket extension works well.
You can also see this site for removing the transmission.
ILLUSTRATED DESCRIPTION OF REMOVING CABINET THRU TRANSMISSION.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Dec 18, 2009 | Kenmore 22422 Top Load Washer
Motor runs, water drains but tub doesn't spin. checked lid switch but that works fine.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt.
Nov 19, 2009 | Washing Machines
Kenmore washes and on next cycle drains but it doesn't spin
If everything else works OK,, including the agitating and drain, and the timer moves, the problem could be in the transmission / gearcase.
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
http://www.fixya.com/support/r699497-replacing_gearcase
OR
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
Oct 25, 2009 | Kenmore Washing Machines
Machine will drain but want spin
OR
Oct 25, 2009 | Washing Machines
Spin cycle wont work. water drains but clothes are wet
Since the washer will drain, the lid switch and timer should be OK.
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase and the "Neutral Drain Assembly".
OR
Oct 18, 2009 | Kenmore 22642 Top Load Washer
Washer doesn't go into spin cycle, drains and stops.
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how the transmission and neutral drain works.
You don't have to remove the agitators and drum to access the transmission.
Oct 05, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
