Question about Frigidaire Washing Machines
WASHER MOTOR NOT WORKING ON LOAD. - Frigidaire Washing Machines
    Brigadier General:
  • 6,277 Answers
It does sound as if the motor requires replacement unless it's the belt slipping.Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person:-
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
If it is the motor it might be suggested that just the brushes on the motor want changing; experience (of others) suggests that they may only last months rather than many years UNLESS the motor itself is refurbished. Refurbishment includes skimming the commutator on which the brushes run. Without skimming the brushes do not sit cleanly on the com, often causing excessive sparking and excessive wear on BOTH. Alternately a new motor! I changed the motor (and the belt at the same time) on our 19+ year-old Bosch at a cost of GBP250 ;-0(
It's your choice of course!
Good luck,
John C
Posted on Mar 20, 2011
Why wont the motor on a top load roper washer work after a flood
If the motor was submerged in water it's probably shot. They aren't made to function during and after exposure to water.
May 20, 2014 | Roper RAS8445KQ Top Load Washer
MY whirlpool WASHER MACHINE FILLS WITH WATER BUT DOES NOT WORK AFTER THAT. IT DOES MAKE SMALL NOISE LIKE MOTOR BUT DOES NOT WORK.
Maytag LAT3600A Top Load Washer
1 Points
Nov 27, 2012 | Maytag LAT3600A Top Load Washer
Washer motor turns, drum does not
Please be gentle with me if this is obviously not the problem, but I have made the mistake of running top load washers with the door open (which the washer notices and does not turn the basket. I fixed my problem by loading the washer, adding the detergent while the washing machine was filling and then closing the door. My washer worked fine with the door closed.
Again, please be gentle with me as you rate my helpfulness. OK?
May 21, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Our top load washer washes a couple of loads fine
Sounds like the thermal breaker inside the motor is heating up and triping it resets when it cools either the motor it's self is geting hot or something is causing it to over heat. Just a guess hope this helps
Apr 24, 2010 | Maytag Neptune FAV6800AW Top Load Washer
My maytag neptune front load washer will not spin this has happened before and I called service they held down some button where the start wash etc are on on top of the washer. It washed the load but when...
Check whether water is fully drained. Since the motor worked during wash motor is not faulty.
Check relay that poers the motor during spin mode. May be micro controller fault posiible.
Mar 31, 2010 | Maytag Neptune MAH6500A Front Load Washer
GE Top load washer 15years old. noisy when spinning
washer making a load cluck noise when the spin cycle starts.
It only happens when the motor turns slow for the first minute during the spin cycle. Otherwise it works fine.
if the motor is proper then the bearings in the motor got rusted and that needs replacement.the beasrings are located on the back of the motor.
Apr 03, 2009 | GE WVSR1060A Top Load Washer
Kenmore front load washer problem
i would say you have a bad motor control board
Feb 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER AGITATES WHEN SUPPOSE TO SPIN
Faulty spin windings on motor. Regards Advisor
Sep 01, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Won't spin.
Your washer obviously has been over-loaded. It trips the spin switch & prevents top-speed spinning. See that you load within the machine's user manual load, not more. You can even weigh your laundry before loading to see that you dont over-load. Also see that the laundry is evenly placed within the bucket. These are suggestions.
Apr 17, 2007 | GE WJSR2070B Top Load Washer
Washing Machines Logo
32 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
