Question about Bosch Nexxt 300 Series WFMC2201UC
I have an error 13 on my bosch nexxt 300 i removed door and removed plug but there is a gray plug or cover still in there how do i remove this to get to trap? thanks.
    Brigadier General:
  • 6,277 Answers
I'm presuming that is the actual filter itself. Had the same problem with our Bosch, cap would not even turn!
Suggestions-
pour anticalc/limescale fluid into any gap there is around the cap. Empty the machine and you can switch it off providing the door is open! Then pour the contents of at least 2 sachets of proprietary anticalc powder/liquid into the drum direct together with a kettle full of boiling water. Leave overnight at the very least. The following day run just a spin cycle as then there will be no water diluting the mix. This mix will go through the filter and motor and is likely to help release the filter/cap. If you feel like it, do the overnight again. If nothing else it will ensure that the heater element is clean!
I had to spend a couple of hours gently turning the cap back and forth until it finally released its hold- but the filter did not remain attached to the cap by its rubber ring. More patience, anticalc fluid and all was revealed!
I now run an anticalc clean regularly............which reminds me..............!
Good luck
John C
Posted on Mar 20, 2011
When door locks ..the drain pump runs. As water enters it is drained instantly. No water in drum,drain passage clear. Unplugged the pressure sensor..still DOES IT Bosch Nexxt 300 WFMC2201UC/13
Possible that the drain pump is running due to a small leak is present at the base of the machine, providing this has a metal cover on it ,it gets water in here which activates afloat switch switching on the pump hence draining the machine to avoid possible flooding, if the pump does not appear to be running then the drain hose is too low resulting in syphon effect,in which case raise it...Good luck
Jun 01, 2015 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
Im getting an error e 13 message and the door will not unlock
error code = bad pump? or just a clogged screen /kinked drain hose?
E:13Er:13 test #P:15Drain pump time exceeded,Faulty drain pump, wire harness, hose
Apr 26, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Bosch series 300 washer: E:04 error; how to remove pump cover
You can get that cover off, by prying it up at the bottom and spinning the thing clockwise. then there is a large hand turnable plug inside.
Once you turn it water will start leaking out, you'll have to get in and pull out the crud from the pump screen there to clear the jam. Good luck!
Apr 10, 2010 | Bosch Nexxt 300 Series WFMC2201UC
Hello, I get a E:13 error code and the door will not unlock. Any ideas?
On the bottom right there is a round door with a small hole. Insert a small rod and push slightly, you will feel a spring action, then turn to the side and the door will come out. Inside you will see a large twist handle ( this is the clean out for the water pump) THERE WILL BE WATER THAT COMES OUT, BECAUSE YOUR FILTER IS PROBABLY CLOGGED, THAT IS THE E-13 CODE) Remove the door, clean the filter, clean up the mess and this will probably fix the problem.
Oct 10, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Hello! My Bosch Nexxt series 300 washing machine is showing a E: 13 error and won't open. I have tried unplugging it but that doesn't seem to help.
e 13 is a door lock error if you are lucky you may have a manual release check where filter is for a red pull release this mechanically activates the door to retrieve trapped washing,if not lock will need replacing engineer visit unfortunately.
Aug 05, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Error Code 13 Washer won't drain
First, unplug your washer. After that find the little round plate below your drum opening on the exterior of the washer. It should have a small hole in it. Use something to gently push trough this hole and twist the cover off, Inside there you will find the drain access. Be careful, if there is water in your drum this will make a mess when you unscrew the drain access. Take the usual precautions and unscrew the drain access slowly until it is off. Remove any obstructions and replace access door and cover. Clean up any mess and plug back in your washer and try again. takes about thirty minutes to an hour depending on how much water is in the drum.
Apr 18, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Wahing Machine 300 NEXXT Series
Sounds like a baby sock stuck in the drain. Remove the access door bottom right. Reach in and unscrew drain cover slowly and a little at a time. Put a sheet pan under it to catch the water as it drains. It’ll fill the sheet pan a couple of times so have patients. That’s where your clog will probably be.
May 17, 2008 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 300 Series WFMC2201UC Logo
77 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Craig Butler
Craig Butler
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
