I have a samsung washer p1253, the machine goes thru all its cycles apart from taking the softner, ive taken the draw out on washed it put it back together and it still wont take softner in, any advice please
    Brigadier General:
  • 6,277 Answers
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
Good luck,
John C
Posted on Mar 20, 2011
My liquid softner does not work. The place you put it in stays full of water all the time . When you add softner to it doesnot seem to put it in the washing machine.
Liquid softener has a tendency to gum up and clog the hose that leads from the dispenser to the washer tub. The fact that water is always in the cup sort of leads to that conclusion. Cleaning it out can be difficult, but there are methods to do it without having to take the machine apart. One way is to use air pressure, but this often is not feasible. Another way is to take a wire, one with the insulation still on it, and thread it carefully down thru the hose to the tub, avoiding puncturing the hose. Once you get the line open, flush it with very hot water.
Oct 25, 2015 | Bosch Axxis 500 Series WAP24201UC White...
Softner is dispensed in Wash cycle
in the top of your soap draw compartment is a lever that switches the water jets over ( for instance on the main wash the jet arm is directed in the main wash compartment which will take away your main wash powder then it moves the jet are to the sofner compartment on the final rinse ) the jet arm somtimes jams and needs cleaning and the small holes above your draw compartments clog with lime build up the thing to do is take out your draw clean the inside at the top where the holes are and take the top off your machine there are two screws at the back top you will see the little ark on your soap draw it will have a return spring on it gently move it from side to side this will clear any obstuction make sure that it will spring back clean any line around the arm ( make sure you switch unplug your machine before you remove the top)
Nov 21, 2011 | Washing Machines
While the washer is go thru the wash cycle it is not adding the detergent, fabric softner, or bleach what would cause this ?
the disp. motor sounds to be off hook , unplug washer open the top of the machine and look to see if the dispenser arm is conected to the motor if its off trasck put it back on the track this shouldhelp
Sep 02, 2011 | LG WM1812C Front Load Washer
Softner still in the draw
The detergent/softner dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distribution to drawer's cells (following the programmed cycle)are done by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer. By opening upper machine's cover you will have an access to the dispenser. Disconnect the power cable from the machine before moving to next step !!!! Look first that they are not any disconnected wires. Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit). In case it works properly (manually) - you should test with a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced. Good luck !!
Aug 03, 2007 | Hotpoint WF645 Front Load Washer
My machaine no longer takes the softner when on rinse .
open the soap drawer when softener should be taken and see if there is a jet of water into the conditioner box. if not, a common cause is the jets in the roof of the box blocked. poke a hairpin in the holes in the roof of the box and see if this cures the problem. if the rinse water does come in, this means that the actual water valve is ok
May 18, 2007 | Hotpoint WF645 Front Load Washer
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
