Erratic display My display was dark when I returned home. After turning it on and off a brief flickering image appeared then the display turned dark. The computer works fine with another monitor. Turning it on and off brings up a brief flickering image, but it only lasts a second or so before going dark. I just recieved a Gateway FPD 1830,it powers up,but the screen is blank,and when I push the source or on/off button I see the screen display but only for a second or two then it goes blank again. I have cleaned the dust from the controls ,but the problem persists. Thanks , Darryl-Las Vegas
  • 1,879 Answers
Since the computer works fine with another monitor, now try the defective monitor on another computer.
Problem persists, you got a failing electronic part inside or the monitor cable.
Posted on Aug 02, 2008
    Genius:
  • 1,447 Answers
Hi-
For you to check if its the monitor that you are having an issue with the monitor itself is by trying it on a different computer, if it has other options to connect to your PC using a different cable, DVI as an example, then try that as well.
Keep us posted....
  • 19,396 Answers
It is a problem on main pcb, probably a burnt capacitor or an IC failing. Check also that is not the power adapter failing, but if lights keeps flickering it is the display.
You need to take it to repair shop to fix this.
    Genius:
  • 1,689 Answers
I was supposed to paste the whole article, but instead here is the link i founf on how to repair your issue.
How to repair flickering Gateway FPD 1830 flat panel color LCD monitor
good luck - voodoomox
  • 319 Answers
So your Gateway is brand new or a refurb?
  • Brian Berndt
    Brian Berndt Aug 02, 2008
    Are you using the analog connector or the DVI connector?
  • Brian Berndt
    Try these tips:
    Make sure that the video cable is connected securely to the back of the monitor and your computer.
    Make sure that the power cord is connected correctly to both the back of the monitor and the wall outlet.
    Try to restart the PC with your monitor ON.
    Check all video cables for damaged pins!
I have lenovo g550...my screen flickers in every 5minutes...
Failing Inverter An inverter, typically found inside a laptop computer, consists of a small board, which has impregnated electronic circuits stamped on it. Inverters look like thin boards about the of two sticks of chewing gum. The inverter and its bulb control the intensity of the liquid crystal display, which lights the screen monitor. The computer can control the output voltage of the inverter and either lighten or darken the screen. A special type of inverter can adjust the brightness of the screen by using an internal sensor to judge the room brightness, and then adjust the screen accordingly. Failing inverters give off some specific warning signs, which can be recognized by observing different screen characteristics.
Short Intermittent Display Upon turning on the laptop, the screen flashes on in the normal mode for a short period and then blinks to black. A very faint image appears in a dark background, which will be very hard to see almost invisible. After shutting off the laptop and restarting, the same mode occurs, where the screen appears normal for a few seconds then fades to black. This condition points to a failed inverter. To confirm this, plug in an operational external monitor; if the external monitor functions, the inverter has failed. b> Total Blackout with Ghost image b> The laptop turns on, as indicated by the power supply button, but the screen comes up black. The screen comes up black after restart. You might be able to detect a very dim or ghost-like image on the monitor. When you plug in a known functioning external monitor, the external monitor operates normally. This mode of display indicates a failed inverter. b> Long Term Periodic Operation b> With this failure mode, the laptop screen illuminates normally upon start-up and remains that way after several minutes, hours or even days, until it goes very dark again. Brightness controls or restoration attempts do not work. Most often, the screen will function normally with a computer restart, but will eventually return to black. Faint ghost images might appear, as seen in the total blackout mode. b> Dark With Color Variation b> Upon computer start-up, the monitor shows black or dark gray, accompanied by very faint images. The screen might have an intermittent color change, or remain on with a non-standard color variation, like pink or red. b> Auto Control Switch b> If the screen appears black, with no faint or ghost images, look for the lid switch near the back hinge. The switch, when depressed with a closed lid, shuts off the computer and monitor functions. Sometimes the switch becomes stuck in the closed position, disallowing the computer and monitor to turn on when opened. Pushing the switch manually several times can often free it up. If the switch tab has broken or jammed inside the case, it needs replacing. b> Loose Connection In this mode, the display looks normal upon start-up, but tapping the side case of the computer turns the screen black. More tapping results in the screen functioning normally then cutting out again. This condition points to a loose wire connection from the inverter to the LCD backlight lamp, or the video cable. The connectors can be accessed by removing the monitor bezel screws and pulling the plastic retainer off. Both connectors can be cleaned and refitted.
Feb 10, 2013 | Lenovo G550 PC Notebook
Noticable flickering when viewing dark images.
Hello, I too experience this exact same problem. In my opinion, any television under 2 grand is probably going to have some slight imperfection as this; I have tried a few different ones myself. To some, it would appear to only be a minor annoyance, but to those who truly can distinguish a good quality picture between a bad one, or to those people, such as myself, who would find something like this to be unacceptable, this is a disheartening situation.
My friend, I have tried many different settings to see which ones might resolve this issue with the blacks in the picture, or at least reduce it to a barely noticeable level and I have found that when I select the CUSTOM picture mode, reduce the contrast to about 60, turn up the brightness to 62, turn OFF blur reduction,x/v/ color on, CATS on, MPEG NR ON, turn Dark level to LIGHT(this is important) add a little bit of extra color for ex. 52, and sharpness to 75, that this produces a pleasing to the eye performance when watching blu ray movies and dvd's. The flickering is reduced to almost nothing, and the picture quality actually appears sharper and more ethereal in certain ways.
The downside to this is that you are lacking some true depth in the picture's darks, but after your eyes adjust and you are watching a good quality movie, you will notice that there still sort of is enough darks there to compensate. Further fine tuning may produce even better results, jsut have to keep playing around with it. But I am now convinced after hearing somebody come forward with the same exact problem i'm having on the same tv, that it is not a defect but just an imperfection that you sometimes have to deal with when you don't spend like 5 grand on a tv. Good luck and happy viewing!
Jul 05, 2010 | Panasonic TCP42S2 42 in. TV
Turned my gateway mx3414 laptop off, when I turned it back on the screen was black, turned off and restarted several times always just a black screen.
You may have a faulty inverter or defective CCFL lamp. A faulty CCFL lamp may have the following symptom: Screen flashes on and off or displays reddish pink hue. Picture stays on in red and slowly be come normal. Picture flickering and/or with dim display or appear black. Picture flickers on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replace the CCFL lamp.
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight or a faulty inverter that supplies high voltage to the CCFL lamp. Usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Dec 13, 2009 | Gateway Computers & Internet
Screen flickering when turning on laptop and sometimes the laptop turns on after flickering and sometimes doesn't turn on at all after flickering. Just stays black.
You may have a faulty inverter or loose power inverter connection. OR
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
Check out
www.lcdparts.net
Sep 01, 2009 | Acer Ferrari 5005WLMi (LXFR506119) PC...
Samsung 226bw visible flickers just after it is turned on
Check out
www.lcdparts.net
Aug 31, 2009 | Samsung 226BW Monitor
I dropped my laptop, white pixels turn pink
The CCFL lamp has been partially damaged and could fail completely any time. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
var selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 = null,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 = null,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 = null; function checkReviewsMarked() { if (selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 !== null) { $('btnctl00_SideColumn_ctrl_rater').disabled = ''; $('btnctl00_SideColumn_ctrl_rater').className = 'c_sub_small sub_enabled'; } } function checkAndSend(obj) { if (selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2 !== null && selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3 !== null) { setRate(selected_ctl00_SideColumn_ctrl_rater_ctrl_unit1,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit2,selected_ctl00_SideColumn_ctrl_rater_ctrl_unit3, function() { window.location.href = window.location.href; }); } }
Jul 09, 2009 | Dell Latitude D600 Notebook
Nothing appears on the display.
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Jul 07, 2009 | HP Pavilion ze2000 Notebook
Erratic display
it sounds like a blown cap.. you can replace it if you know how to soder
Jun 11, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Viewsonc VA720 Flickers On and Off Continuously
Take a look at the capacitors and see if you have any weak one. An obvious way to spot one would be one bubbled up on top. A bad cap won't always be bubbled up. The monitor probably can operate until the voltage drops under 8 volts. Also possible if power supply check out good would be a weak backlight inverter.
Apr 05, 2008 | ViewSonic VA720 17" LCD Flat Panel Monitor
Sony Bravia LCD Flickers/distorts
Wanna sell the tv for parts? Kev0201@yahoo
Sep 14, 2007 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Computers & Internet Logo
890 people viewed this question
David Payne
David Payne
