Question about Kenwood KSC-310CCS Center Channel Speaker Car Speaker
I have kenwood car stereo.it shows protect mode..soo what is the main problem? wand what is the solution? pls help
  • 8,841 Answers
Hi, the unit enters protect mode when the output impedance is too low causing the power transistors to draw too much current. A short may be internal or external to the head unit. The thing to do is first disconnect the speakers to see if the unit will come out of protect. If this does not work, the short is internal, and the head unit must be repaired or replaced. If disconnecting the speakers DOES resolve the short, then the speakers and wiring must be checked for a short. The easiest way to do this is to use an ohmmeter at the speaker connector. Check the impedance of each pair of speaker wires. The impedance should be between 4-8 ohms. Anything less than 4 ohms may cause the unit to protect, depending on the exact design of the unit. If you find any wire pairs to have less resistance than the others, access the speaker to check the impedance of the speaker alone. If the speaker has an impedance of 4-8 ohms, the problem is a shorted wire. Please let me know if you have questions, and thanks for using FixYa.
Posted on Mar 20, 2011
How do i take my Kenwood car stereo out of protect mode ?
There may be an internal short which will have to be repaired before the radio can be used.
May 25, 2016 | Kenwood Car Audio & Video
Kenwood car stereo is displaying Protect and wont come on
If ur kenwood stereo is going into protect mode, it is because one of ur speaker wires is shorting out. Make sure all of ur speaker wire connections are good, and then wrap them so they aren't grounding out against the chassis. This should solve ur problem.
Oct 09, 2011 | Kenwood Excelon DDX-7015 Double Din Car...
I have a Kenwood car stereo model # KDC-MP342U. Protect mode has been activated on it. I found I had a frayed wire on a speaker from window movement and have replaced the wire. When I reset the radio and...
hold down preset 3 & 6 + reset
press preset 1 - shows dc err
press preset 1 - shows dc ok
press preset 2 - shows dc 2-4
press preset 2 - shows dc 2-0
then unit should be ok with eeprom reset
Jul 18, 2010 | Kenwood KDC-MP342U Car CD Player
MY KENWOOD CAR CD PLAYER IS SAYING PROTECT??
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Dec 09, 2009 | Kenwood KDC-319 CD Player
Kenwood car stereo cd player reads protect mode how do i fix this
i have a kenwood kdc-241 car stereo and it has gone onto protect mode i have done everything it says in the manual and even taken it out of the car just in case it was damp i have tried putting it back in but still is in protect mode can anyone help me please
May 25, 2009 | Kenwood Car Audio & Video
Its on protect mode and i cant get it off
Look on the face plate for a really small hole. Put the tip of a pen in the hole and hold it for a few seconds. Your system should then re-set. If the Protect signal keeps coming on, take it to the dealer to make sure your stereo is wired properly....hope this helps
May 02, 2009 | Kenwood KDC-MP235 CD Player
My kenwood car stereo says protect how do i fix this
well that means you had a safety stereo in the beggining and you proly didnt put the safety code in so it went into secure mode it to prevent the device from working if stollen
Mar 08, 2009 | Car Audio & Video
Car Stereo in Protected Mode will Not Play Radio or CD
try the small reset on the lower right hand side of the player it fixed mine
Feb 03, 2009 | Kenwood KDC-MP228 CD Player
Security Code for Protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Apr 30, 2008 | Kenwood KDC-W3534A CD Player
Car Audio & Video Logo
254 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
