Question about Zebra 220XiIII Label Printer
Printer idle error condition head open - Zebra 220XiIII Label Printer
ozztech
  • 285 Answers
SOURCE: urgent soln
try to move the silver plate (under the printhead) up a litle bit.
this silver plate is the "print head open, and the media sensor.
Posted on May 08, 2008
ozztech
  • 285 Answers
SOURCE: z4mplus
try to move up the silver plate unther the print head.
this silver plate is the "print head open" and the media sensors.
bartech9
  • 155 Answers
SOURCE: printing error condition
First clean the sensor tag and sensor head open and tape. Then perform a calibration label pressing the PAUSE and FEED buttons and turn on the printer, release the keys until it starts to move the label. Wait until you are finished and ready to print.
Posted on Mar 16, 2009
thesuperdude
  • 97 Answers
SOURCE: error condition head open
if this is a zebra 170 xi or similar, the problem will be a sensor in the interior of the printer. Don't get scared as this is easy to fix. you will need to remove the cover to be able to view all the circuit boards.
when you have removed the cover, if you check the axle of the latch that you use to open the printhead, (the one with the two pressure knobs) and check the end of that axle in the sidde where the circuit boards are, you will see that it has a small piece of plastic about 1.5cm long by 0.5 cm wide that should turn with the axle when opening and closing.
when the printhead is closed, this bit of plastic should be in front of a small black sensor.
The problem that you may have is that either is broken or became lose.
Please let me know if you have managed to sort this or whether you will need more guidance.
obviously, if the printer is under warranty, do contact your distributor before proceeding to open the case to avoid any warranty issues.
Also, don't forget to unplug the printer from the mains before doing anything to it.
Posted on Mar 26, 2009
ozztech
  • 285 Answers
SOURCE: lable print ran out for paper and will not go back
check the setings, change the setings, Media TYPE from Termal Transfere to Direct Termal.
if necessery, reset the printer to Factory Defult.
Posted on Mar 26, 2011
Zebra Z6m Error Paper Out
sensor not working or dirty in the feed path id suggest
Dec 27, 2017 | Zebra Z6M Plus Thermal Label Printer
Canon Pixma Mp258 B200 Error
My printer is canon mp258 there was an error B200 . how t fix this?
Apr 07, 2011 | Computers & Internet
The message "head open " printer idle v53.16.5z
Try taking the printer off pause. It should clear the error.
Mar 03, 2011 | Zebra ZM400 Thermal Label Printer -...
Error Condition , Head Open on Zebra printer model: Z90-401-00204 We have play around the pressure but still the same. What would be the root cause? Mechanical or electronic board or sensor.
If the Head Open condition is showing when the head is closed, then the problem is with the Head Open Flag. It is located on the electronic side of the printer. You need to take off the side cover (with printer turned off). The lever that raises and closes the printhead is attached to a shaft (the pressure toggle is also on this shaft). Follow this shaft to the electronic side of the printer.
At the end of this shaft, there will be a black rectangular piece of plastic. This is the head open flag. When printhead is closed, the flag is positioned at the six o'clock position between two optic sensors. When the printhead is opened, the flag rotates clockwise to about the nine o'clock position. If the HEAD OPEN message appears when the head is closed, then the flag is out of position, usually it has become loose on the end of the shaft.
The flag is attached to the end of the shaft with an allen screw. Make sure the head is closed, position the flag to the six o'clock position between the two sensors and tighten the screw. this should take care of the problem.
Hope that helps !
Apr 16, 2010 | Zebra 105Se Thermal Printer
Lable print ran out for paper and will not go back to normal. The lights on top are all on except Data , and is blinking Error Condition, Print Idle, Error cleared head open on the screen.
Mar 31, 2010 | Zebra Z4Mplus Label Printer
Zebra 220xiIII Error Condition Head Open will not go away
The head open sensor is inside the printer is detected by the gear head.
Mar 16, 2009 | Zebra 220XiIII Label Printer
Printing error condition
Feb 27, 2009 | Zebra Z6M Plus Thermal Label Printer
Error condition
Have you tried to reset the printers defaults?
Aug 13, 2008 | Zebra 170XiIIIPlus Thermal Label Printer
Urgent soln
Mar 21, 2008 | Zebra Z4M Printer
Z4mplus
Mar 12, 2008 | Zebra Z4M Printer
Zebra 220XiIII Label Printer Logo
411 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
