Question about Casio Watches
Hello!! This is about my Casio HDA-600B-1B watch... Are there any way to reverse the date... Hehehe... Need answers ASAP... thanks in advance...
5 Suggested Answers
  • 65 Answers
SOURCE: need to reset time and date. its a casio wrist
Check out the manufacturers web site, some manufactureres have users manuals for their watches which can be downloaded. You may be lucky. You could also try some of the various manuals websites. They have manuals for all manor of things. Good Luck
Posted on Jul 22, 2009
SOURCE: cannot set the date on the casio tachymeter
wen u twist th big thing do it twice and press the top button to set dates
Posted on Mar 05, 2010
SOURCE: casio pathfinder SPF 70-s titanium band adjustment
I purchased a Casio Pathfinder solar/atomic watch, with compass, altimeter, barometer, thermometer, model 1200T-7WC (titanium).
Has the titanium band - on this particular band each link is somewhat waveshaped {i.e., there are 2 "arms" from the link making contact with the middle part of the link above (above meaning towards the watch body), and 1 arm fitting between the 2 arms of the next link down). Unlike described in the first solution, the pin is not split, but solid (doesn't look like a slotted screw on 1 end, so the solution at http://www.wikihow.com/Adjust-a-Casio-S-935L-Watch-Band is no help). Here's what to do if you have this band:
1. Note: before you start, be advised there is a tiny loose 1/8" part (sleeve) that will fall out as you pull the links apart, so work over an appropriate surface to "catch" it. Push pin (from the upper "arrow end) of one of the removeable links (those with the arrows on the backside) out of its hole with a fine poker (I used a 1/32" jeweler's screwdriver, an unbent paperclip would also work, just more likely to bend as you push pin out). This takes some force to do - in my case, after pushing, the pin projected out about 1/2 of it's length, I used needle-nosed pliers to gently pull it out the rest of the way). CAREFUL - once pin is removed and you pull the link away from the one above, a small (1/8") constriction sleeve should fall out of the center arm of the link above. SAVE THIS SLEEVE!
2. Using the same procedure, remove the pin from the bottom end of the link you're removing. again, SAVE THE SLEEVE.
3. to rejoin the band once the link is removed, look at the single/middle "arm" of the upper link, looking for the hole where the pin goes through. One side of the hole should be noticeably larger/wider than the other side - this is where you will place the SLEEVE - I used tweezers, or needle-nosed pliers will work - it will drop into hole. Keep this upright so that sleeve doesn't fall out, and slide the 2 arms of the lower link in place around the center arm.
4. Slide the pin you removed into one of the outer link arm holes - I found it easier if I started from below, pushing it into the center arm - it will stop when it reaches that 1/8" constriction sleeve. I set the extruded end on the pin on a magazine (i.e., slightly padded surface) and then pushed the top side of the band down, forcing the pin through the constriction sleeve and up into the upper arm hole, and Voila, your band is reconnected. The sleeve is important (without the sleeve in place, the pin will simply fall back out).
Posted on Mar 07, 2010
escapement
  • 2334 Answers
SOURCE: Need a user's guide for a recently purchased Casio
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIOwatch manuals.Rate me, please..
Posted on Mar 29, 2010
I cant get the arms to automatically set themselves
About Self-Winding Automatic Watches - Self-Defense Armory
www.selfdefensearmory.com/aboutautomatics.html
about mechanical watches, self-winding, automatic watches. ... Secondly, and this is where it gets a little hazier, people buy automatics for reasons that cannot be clearly ... Self-winding automatic watches depend on the movement of the arm to ... Avoidsetting the day and/or date (if your watch has these functions) at night.
About watch movements: technical details
Dec 26, 2015 | Casio GA-110-1B GA110 G-Shock Alarm World...
How do I activate the auto el on a Casio 350 1b
Hello there. I don't know what 'auto el' is but if it is not in the manual, it doesn't do it !!!!
Manual on the Casio GD-350-1b here http://www.casio-intl.com/asia-mea/en/wat/watch_detail/GD-350-1B/
On this page, 1) click 'operatiion guide' 2) agree to terms 3) download the pdf format manual.
Good luck
Sep 10, 2014 | Casio Watches
Change date on casio watch 3191
If the answers on the Casio website were clear and usable, there would be no need for the question. How do we change the date on the casio 3191
Aug 20, 2013 | Casio Watches
Cant get analog to sync with digital time. I live in SC and I try to set the time for 22:36 but then the analog set it to 12:36 am. :/
First set your local time, date and year and then run the "home positioning" (H-SET) procedure following manual instructions.If no any other problem exists, normally hands will "follow" digital time when watch is set back to time mode.
May 08, 2013 | Casio G-Shock GA-110-1B GA-110-1 Mens...
I need an Instruction manual for a Casio Gshock GD100-1B
you can download a soft version of the user manual on below link. .when you open the link just write the 4 digits code on the back side and click searched on the URL below
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
CASIO Watch User Manual Archives
http://world.casio.com/wat/download/en/manual/
Use this page to download a copy of CASIO watch manuals in PDF format.
To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
Oct 07, 2011 | Watches
I have a casio tough solar watch. Model LCF-30/ module 2790:I need to set the time, both analog and digital. Lost my manual. Please help
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals",
watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Jul 29, 2011 | Casio Classic LCF30-1B Watch for Women
I didnot get manual when i purchased casio gshock gdf100 1b model from macys ,new york
Hi,Here it is...to download the soft version of the user manual pls visit the URL below..
Hope this helps! Take care and please Remember to rate/vote and give me
Thanks
CASIO Watch User Manual Archives http://world.casio.com/wat/download/en/manual/
Jun 24, 2011 | Watches
I replaced the battery in my casio wave ceptor watch and the time and date displayed now is incorrect. How do I set the proper time, or will the watch access the satellite and set itself?
Hello Wifferdil38,
I believe that I've located a manual for your watch which will help you to re-set the time and date. Please click on the following link:
http://ftp.casio.co.jp/pub/world_manual/wat/en/qw2556.pdf
Please let me know if you need anything further.
--Sandy
Apr 13, 2011 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Please, I get problem with my casio wave captor, box number 4723, the problem is that since i changed the battery i was not able to fix the time and date. could you please assist me on that issue? ...
You might need to carry out a calibration of the hands. i did on mine. Do a search for casio 4723 operating instructions
ftp.casio.co.jp/pub/world_manual/wat/en/qw4723.pdf
Dec 01, 2010 | Casio Wave Ceptor WVA430A-1AV Wrist Watch
Watches Logo
55 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
