Question about Toshiba Televison & Video
I have had problems with a particular DVD-R disc.I had troubles editing the disc with my titles.I then purchased a repair kit.I have now managed to put my titles on the disc.When I try to finalize the disc,which allows me to play the disc on another machine,I get a error message.Quote:- RECORDING ERROR.Can not record on this disc. E 16 28031100.When I tried to finalize it first time the code was E 3 28031100.I was going to ring Toshiba on Monday but then I found your website.Thanking you in advance.Regards.Peter
  • 254 Answers
SOURCE: How Do I use timed recording?
Is this a problem of the VCR not doing a timed record at all, or of it recording only snow (no signal) or perhaps the wrong channel? If the first, then it would point to incorrect setup of the timed record session or that the clock time & date settings are incorrect... the VCR setup stuff. Also, once the timed recording is setup, there is often one additional button to push to actually ready the VCR. Older VCRs, were put into the timed mode by power off. If VCR isn't recording anything (it is coming on to record, but no signal), then it has to do with hookup of the VCR. Depending on your cable system, the VCR can only record the channel the cable box is tuned to. Again, depending on the system, the VCR needs to be cabled in between the cable box and your TV (cable box RF out to VCR RF in, VCR RF out to TV RF in) RF=ant. Exact cabling will vary.
Posted on Apr 27, 2007
  • 158 Answers
SOURCE: DVD tray keeps opening and closing?
this sounds like the take up motor for dvd player the band maybe streached have you got it serviced latley as this maybe the cause of problem this is due to heat from dvd player and vcr comby drives please have it looked at by an expert in this field as my sony dvd player and vcr does the same as you've described
Posted on Aug 13, 2007
  • 221 Answers
SOURCE: Error Codes E-2, E-41, E-61
If you're experienced in capacitor replacement, check the capacitors on the mechanical interface board. When these caps fail, you get mechanical errors like you described. I generally replace all the capacitors on this board as a precaution; I've never had a callback when I replace them all.
Posted on Aug 22, 2007
SOURCE: Sony DCR-DVD 108 disc won't play or record
u tooo have same problem .. i recorded my whole trip on Dvd RW now the camcorder or computer shows fileformat as RAW rather than VR.. plz suggest some solutions.. all i want is my recordings back
Posted on Jan 08, 2008
  • 3 Answers
SOURCE: DVD recording problems
I have the same unit with the same exact problem. I ended up taking it in for repair and it's now working perfectly. I paid $100 for the repair. I dropped the unit off and picked it up myself. I think $30 additional is charged for shipping and handling in US.
1590 Touhy Ave
Elk Grove, IL 60007-5319
Part Number
Posted on Jun 28, 2008
Phillips BDP5100 not play BD (unknown disc) but DVD read and play no problem How can i do pls Help me ????
The player detects that the discs contains unauthorized copies of movie titles.
The disc is with a new format which is not yet supported by the player. Some newly released Blu-ray titles in the market apply new disc format which did not exist when the player was manufactured. This leads to playability problem with these discs. This is not a defect of the player and can possibly be solved by firmware upgrade.
The Philips technical team is constantly working on the firmware development to enable the player to play such discs. Installing the latest firmware in your player helps to ensure optimal playback performance. Please visit the support website of your player regularly to check out new firmware release.
Before you update, read the Firmware Upgrade Readme File on the Software and Drivers page. It contains information on playability resolution on discs of particular movie titles.
If the latest firmware is installed in the player and only one disc can't be played, there may be some problems with the disc. It may be defective/scratched.
Another possibility is that the lens of the player is dirty. Try cleaning the disc and the lens with a lens cleaning kit which is available at electronics stores
Mar 31, 2013 | Philips BDP5110 Blu-Ray Player
I burn dvd -r and dvd+r and it will not play on it
It is possible that the disks are not finalized. You may need to configure it to auto finalize, which is off by default. It would be impossible to have more than one title on a disk if you always auto finalized. Check your manual, and finalize your disks. Many times marginal disks will play OK in the unit they were recorded on, but not so well in other players. The media (disks) could be the problem as well. On a side note, the DR410 will NOT burn DL (dual layer) disks. I hope this helps and good luck.
Oct 28, 2009 | Toshiba DR410 DVD Recorder
Not able to print directly on CD/DVD
Printing Directly onto a CD or DVD in Roxio Express Labeler
  1. Make sure that the product is turned on and that the USB cable is connected to the product and the computer.
  2. Click Start , click All Programs , click Roxio , and then click Roxio Express Labeler v3 .
  3. Click Disk Label , then click Options . Figure 1: Options c01452912.gif 1 - Options button
  4. The Options screen appears. Figure 2: Options screen c01452913.gif
  5. Make sure that LightScribe 12cm Disc is selected from the Disc Label menu, then click OK to return to the Roxio Express Labeler window.
  6. Click Disc Titles , type the title and subtitle for the CD or DVD, and then click OK . Figure 3: Disc Title option c01452914.jpg 1 - Disc Titles button Figure 4: Edit Disc Title screen c01452915.gif
  7. Click Background , then click Import Background to use an image on the computer as the background on the CD or DVD. Click OK to return to the Roxio Express Labeler window. Figure 5: Background option c01452916.jpg 1 - Background button
  8. Insert a LightScribe CD or DVD into the LightScribe drive of the product. Make sure that the label side of the disc is facing down.
  9. In the Roxio Express Labeler window, click Print . The LightScribe label is printed on the CD or DVD. Figure 6: Print c01452917.jpg 1 - Print button
Jun 18, 2009 | HP Office Equipment & Supplies
LG DB370 Blue Ray player DVD Compatibility problem
Visit the LG website and download the latest software for this product. That solves the problem.
Apr 14, 2009 | Televison & Video
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
Jan 10, 2009 | Philips DVDR3545V/37
I have a Panasonic VDR-D160 mini disc camcorder. Im unable to edit discs while in camera and cannot connect camera to my computer. Computer doesnt recognize hardware, manaul is no assistance. No usb or...
i have recored the sveral movie on the DVD-R disc using Panasonic VDR-D160 and then i take the DVD-R disc with me to leave for another country (the Panasonic VDR-D160 left at home) and now i can not read the moviesrecored on the DVD-R disc !!! Why this should be ? The computer view the empty disc although it contains several movies when i checked it from Panasonic VDR-D160 camera when i was at home ! How can i do now to read the movies from the disc ? Thanks a lot !
Jun 24, 2008 | Panasonic VDR-D100 DVD Camcorder
How do I transfer my video from the DVD to my computer?
this is how i do it:
I use nero vision express 3 to edit my dvds. first just finalize the disc on the camcorder (if it lets you! i;m having trouble with mine on a particular disc), hook it up to your computer, use nero vision express 3 to import the disc (it helpfully converts the file format into mpg for you) and there you go!
im sure there are plenty of other ways to do it too.
Mar 16, 2008 | Panasonic VDR-D100 DVD Camcorder
Samsung DVD VR355 DVD format problems
I have just copied a video to a dvd on my samsung dvd-vr355 and finialised the disc with a title now it will not play any disc,even if it is. shop bought, just says loading then the dvd opens to reject the disc. please help
Mar 07, 2008 | Televison & Video
LG RC195 VCR/DVD Recorder
You need to "Finalize" the disc, or it will not play on any other dvd player other than your LG. Finalizing the disc permanently commits any data onto the disc, no more writing or editing can be done.
Jan 23, 2008 | Computers & Internet
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Televison & Video Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
