Question about Maytag Neptune MAH7500WH Front Load Washer
I have a Maytag Neptune Washer MAH7500AWW its almost 10 yrs old. Has worked perfect until a few days ago, when doing laundry it stops 45 minutes into the cycle and the message board gives me the code 07 that it doesn't seem to drain...had someone come out to look at it and he said it would cost more to fix then its worth..any ideas?? I think we can fix it.
    Brigadier General:
  • 6,277 Answers
(So do I so try this- it's what the 'someone' should have suggested first!)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play!
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 20, 2011
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
My husband purchased a Maytag Neptune front load washer model # MAH8700AWW about 5 years ago. The washer works great and we have never had any problems until recently. We just had pergo floors installed in...
you may need to put some anti vibration shock pads under the legs or some two sided tape to put on the feet to help secure it to the floor it may be slipping on the new floor surface
Feb 13, 2011 | Maytag Neptune MAH9700 Front Load Washer
My Neptune washer MAH7500AWW says that the washer won't lock to work. It does this on and off. How do we fix it?
You may have to change the wax motor (lock) on it. Before you door so though check the board in the control heading for a burn mark on the R34 resistorwhich is located near the middle of the board. If its burnt change both parts out or it will keep doing the same thing.
Nov 02, 2010 | Maytag Neptune MAH7500WH Front Load Washer
My machine is about 10 years old. it will run and then stop. we push start again and it will run a few minutes and then stop again.
THERE IS TROUBLESHOOTING GUIDE IN THAT CONSOLE TO TELL YOU HOW TO DO A SELF TEST. MOST LIKELY YOU WILL END UP WITH AN LR CODE. YOU MAY HAVE A BAD MOTOR CONTROL BOARD.
Apr 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Top Load Washer will not spin and water will not drain at the spin portion - the laundry becomes un-balanced. I have checked to ensure the machine is level per manual - once you reposition...
If your machine ius a FAV6800A LED console or FAV9800A LCD console then take a look at this post Clutch Fix if you want to DIY.
I will help you through the process. Your looking at $300 to $400 for a repair if you don't DIY. See if the DIY process is for you if so let me know I have a few additional questions......Rich
Apr 23, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH-1 won't stop filling with water
A couple things may be going on here... you may not want to hear, but the Neptune has a had many "consumer related problems".
If your complaint is "will not stop filling with water" I would access your inlet water-valve (typically blue with 2 black battery looking solenoids; where your water-lines connect directly), test for continuity and replace as necessary. Sometimes inlet-water valves also go bad where the complaint is: "no water comes in at all".
Jan 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Front load washer doesn't spin
My Maytag® Neptune® washer filled with water, but it won't spin or drain-what now?
Start by making sure the machine is plugged into a live (working) electrical outlet. Then check the appropriate circuit breaker and reset it if necessary (or check the fuse if you have a fuse box).
Next, inspect the drain hoses and remove any kinks. Take a look at the drain, too - if it's clogged, call your usual drain service person.
Then close the washer door and firmly press the START/STOP button. In a few moments, after the door locks, the washer should begin to spin. (For your safety, the washer will not tumble or spin unless the door is closed and locked.)
If this doesn't work, please contact Customer Service at 1-800-688-9900 for toll-free assistance and service scheduling if necessary.
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer
yes, but 900 is a little high for my area. is it loud in spin now? the seal can be replaced for about 50-80 part labor is 1 to 3 hours. if you just smelled the smoke and it is not loud you are ok for a long time, reduce load size and it will probly be ok for some time
May 16, 2008 | Maytag Neptune Washer
Error code OE does not finish whole cycle
Just resolved same problem...it is the pressure switch aka water level sensor.  OE is overflow error.  Pressure switch is located under top cover on front right hand side.  It is round and has a rubber tube leading down to the drum and a electrical connection to the board.  Paid maytag man to diagnose/install cost me about $150
Oct 11, 2007 | Maytag Neptune MAH9700 Front Load Washer
Maytag Neptune MAH7500WH Front Load Washer Logo
144 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
