Question about Hotpoint Dishwashers
It's not draining, is there away to make it drain only?
  • Hotpoint Master
  • 1,527 Answers
Hello put a little bit of bleach down the drain plug inside the dishwasher that cured my hope it works
regards
shaun
Posted on Mar 20, 2011
Bush fridge freezer water not draining away
Not draining away from where? There is probably a plugged drain hole or hose somewhere.
Jan 03, 2017 | Bush Refrigerators
Washing Machine won't drain away water.
Hi, can you hear the pump running when you select a drain program?
Mar 11, 2013 | Washing Machines
Flashing display 7 mins into cycle. Water drains away and eventually display goes blank. Help?
Do you get an F21 code or some other code.
An F21 code means the water is not draining away properly. There may be plugged pipe.
Here are some tips to help you:
1. Check to make sure the washer's drain pipe is draining properly.
2. Check the drain hose to see if there are any kicks or clogs in it.
3. Check the washer for excessive subs. Sometimes excessive subs can also keep the water from draining.
Of course, the above tips are useful only if you have a F21 code. If you have other error codes, you'll have to look at the manual that came with the machine.
Feb 22, 2013 | Washing Machines
Water wont drain away when in its final spin,and i have have fitted a new drain pump
If you changed the drain pump I would check the following things:
1) Is the machine actually sending power to the pump to turn it on. You can check this by using a volt meter and with the machine open disconnect the power to the pump and place machine in drain and test to see if voltaqge is being sent to the pump
2) Check your lines and the drain itself. Any blockages could prevent draining.
May 27, 2012 | Hotpoint Washing Machines
Candy intergrated fridge, the drain away does not drain water away, what is the best setting for keeping items cool and ensuring the drain away works
The drain in the freezer behind back lower panel
needs opening. You can see it at the bottom of the back panel
underneath the evaporator coils. (The cold coils)
Run Hot water in the drain until it clears or use a hairdryer.
When the defrost melts the water it goes down the drain
If the drain is clogged with Ice or ? The defrost water
overflows into the ref. or freezer or on floor
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help GO HERE:
http://www.applianceaid.com/procedures.html
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME IF THIS WAS HELPFUL
Aug 30, 2011 | Refrigerators
Beko Dishwasher DE3542F is not draining away and when i open the door it all floods out. I cleaned it through with a wash aid and cleaned filters and put boiling water in to clear away but it is still not...
It could be several things--- a clog, a jammed or broken drain pump iimpeller, a burned out drain pump motor, or the control is not sending power to the drain pump.
If you can hear the drain pump running (you might have to get down on fhe floor), then you should try something simple first. The drain from the dishwasher is probably a rubber hose that connects to the side of your garbage disposal. It might be clogged right there. Loosen or remove the clamp that holds that hose to the disposal. Put a stick in the hole and wiggle it around. Do the same in the hose. Put the hose back on and try it again. If this doesn't fix it, you will again have water in the dishwasher to deal with. :(
If you can't hear the drain pump running, it just might be a pretty quiet motor, or the problem will take a little more doing.
Apr 07, 2010 | Little Giant - 3-MDQX-SC Inline Pump
Water is not draining away throguh the hole near
the drain is probably frozen, unplug unit and defrost manually, use a hair dryer to melt the ice around the drain , be careful not to melt any of the plastic
Nov 03, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Dishwashers Logo
47 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
