Question about Cameras
The camera has a box on the screen which says 'Memory card locked' I can look at the pictures on the memory card but can't take a picture etc????
  • 6,831 Answers
Hello
Thank you for using Fixya!!!
Before you try anything, try using another card. If the problem persists, try the suggestions below.
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Mar 20, 2011
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
How do i unlock the card on my exilim.casio camera
if you put the camera on view and scroll through them does it give you any options , such as save ,delete etc,etc.
Feb 27, 2015 | Casio Exilim Cameras
When I try to take a picture, it gives me the error message "Card Locked !" I have checked the tab and the memory card is not locked. I have put memory card in another camera and it works. Also, I hav
Check the card slot for debris and clear it out gently with canned air, small thin piece of plastic, etc on the same side as the lock tab. Try not to use anything metal unless you have a really delicate touch.
Oct 30, 2014 | Cameras
After I shoot a picture the camera freezes up. I have to power off and up a couple of times to get it back to shoot mode. It does not store the image when it freezes up.
Can you power up the camera don't take a picture but move around the functions and view pictures on the LCD screen? If the camera does all the functions it's suppose to except hold a picture then I'd say the memory is at question. You might not have a memory card installed in the camera and it's working on the Internal Memory which is now full or not able to load another picture. If there is a memory card in the camera it might have the protection switch in the lock position which then would shift the picture storage to the internal memory. You need to check to see if there is a memory card in the camera if so make sure this card is in the unlock position. If the images are on the internal memory then you need to transfer the internal memory pictures to the memory card for download to the PC. Make sure the memory card is unlocked and formatted to the camera after you download the pictures to the PC
Jan 08, 2011 | Kodak EASYSHARE Z1485 IS Digital Camera
When i insert my fujifilm 2gb memory card into model jv100 all i can do is look through my pictures i cannot delete or use anything else ,and a icon comes up in the centre of the screen when i look at my...
A few things but the first that comes to mind is that there is a little slid lock on the upper left side of the memory card. This lock needs to be pushed forward towards the gold contacts to unlock the card. Another problem could be tat the 2gig card is full of pictures and needs to be downloaded to your computer. Once this is done the card will need to be formatted to clean the old pictures off and make the card ready for new pictures. I suspect when you take this card out (2gig) the camera defaults to internal memory and yes everything will work as it should until the internal memory is full of pictures as well
Dec 24, 2010 | FUJIFILM FinePix JV100 Digital Camera
The camera says in the screen that the card is locked The memory card is locked and I cant figure out how to un lock it is in the set up or what do I do ? my camera is EXILIM 8.1 Mega Pixels
I've never fiddled with this brand of camera, but there will be the option to lock the pictures in the menu. In your manual, look for "memory", "locking your pictures", things like that. Also, some memory cards have a plastic tab that slides to lock the card- make sure that isn't in the lock position, if your card has one. Good luck, and hope this helps.
Jun 11, 2010 | Casio Exilim Zoom EX-Z80 Digital Camera
New camera ,not working.
lol, ok...The memory card will only go in one way. But check the little white switch on the side of the memory card and make sure it is NOT in the locked position. Once this is taken care of reinstall the memory card. Now in you options/menu screen you can select on there where you want your pictures to be stored...Device / Memory / Auto. You can either put it on Memory or Auto (if you have this). In addition, you may need to format your new memory card. This is also in your menu screen to Format Memory Card. Go ahead and do this. But be forwarned...if you do this when you have pictures on your card, it will erase all of your pictures completely. If you do those things, everything should work fine. You don't need a full charge for your camera to work, but if you have rechargable batteries, it is recommended to fully charge your camera before use. If you are using standard AA batteries this isn't necessary. Oh, and when your memory card is in the camera you should see a little icon on your LCD screen that looks like a mini memory card. This is an indicator that the camera recognizes you have the memory card in the camera and along with that will be a counter...ie 4/1200. The first number is the amount of pictures taken on the card currently and the second number is the total possible pictures you can take on the card before it is full.
Any further questions
extreme7528@yahoo.com
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/matthew_d24b835e574ef6ca
Oct 13, 2009 | Cameras
Camera is not taking out no pictures on display screen marks memory card locked
It sounds like the memory card has its little locking switch in the locked position. Take the card out of the camera and move the small switch on the side of the card to the opposite position. Re-install and you should be good to go.
May 19, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Camera says no memory after taking only 4 pics.
Camera has built-in memory but its small in capacity. Buy new memory card and install it in camera slot and memory card will hold more picture data. Regarding pictures quantity, it depends what size of memory card like...1GB, 2GB etc. greater size, more storage.
Aug 17, 2008 | Cameras
Memory card error displayed
There is a little slide switch on the side of the memory card. Good luck!
Nov 25, 2007 | Canon PowerShot A410 Digital Camera
Cameras Logo
Top Cameras Experts
Marvin
Marvin
Are you a Camera Expert? Answer questions, earn points and help others
