Question about Frigidaire FRS26R4A Side by Side Refrigerator
Electrolux side by side refrigerator
I need to know where the location for defrost timer in the electrolux side by side refrigerator model # frs23r4a. the food in my freezer has begun to thaw out and the ice maker is not making ice. HELP.
    Scholar:
  • 149 Answers
This uses a adaptive defrost board its located in the fridge compartment in the back left side remove the cover and you'll see the adaptive defrost board if you have any questions don't hesitate to e-mail me @ hvac.tech7872pr@gmail.com
here's an URL of the diagram (copy paste link to your browser)
http://www.partselect.com/Schematics/Frigidaire/XFXTKOQX.gif
Posted on Aug 02, 2008
Freezer is not deforsting
If your model you listed is a TFX27PRBWW it will have a defrost timer located in the fresh food compartment and behind the controls. It's location is 257 in this photo HERE I would like you to turn the timer clockwise slowly until youi hear the compressor and fans stop. This should put the refrigerator into defrost if the defrost heater is still working. Did you hear any crackling or sizzle when place into defrost this way? Wait up to 35 minutes for the timer to come out of defrost and it should restart the refrigerator compressor and fans. If it does not come on automatically then simply turn the timer slowly clockwise again until they do restart. If you need to turn timer again to start refrigerator you will need to replace the timer=> WR9X489 Defrost Timer
If the defrost timer is not the problem then we move to the freezer side, remove the rear panel of freezer and defrost the frost covering the evaporator as in this photo HERE The model TFX27PRBWW takes a=> WR51X10055 Defrost Heater Assembly
and the defrost thermostat=> WR50X122 Defrost Thermostat
The defrost heater is location 230 and the defrost thermostat is location 24 in this photo HERE Instructions in testing these parts are located on the parts pages I listed above. Please let me know if the model number is different than the one above your post so I may help you better, Thanks Sea Breeze
Feb 01, 2013 | GE Profile 26.6 cu. ft. Side-by-Side...
Need to locate the defrost timer. do you know where it is located?
its in the control panel in the fresh food (ref, not freezer) compartment where the thermostat is and it isn't a older style timer yet the defrost control is intergrated into the control board. See the picture for the link i have attached and it will be item #6
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GD5SHAXLT01/1198/0165000/W0312152/00010?blt=06&prst=&shdMod=
Jul 22, 2011 | Whirlpool GD5SHAX Side by Side...
Not defrosting
First, locate the defrost timer which may hidden behindcorners of the fridge at the back bottom, in some models located in the ceilingof the fresh food section or behind the cold control cover. Once you locate thedefrost timer, slowly turn the screw in the middle of the defrost timer withstraight screwdriver until the fridge shuts off. Now it's in defrost. If thedefrost heater(s) starts, replace the defrost timer and defrost thermostat. Ifthe heater(s) does not start, unplug wire cord to check ohm test for continuityof heater. If continuity is there, plug cord wire which gives power 120volts(check specification) to heater. If heater no starts, bypass defrost thermostatby join the 2 wires in the defrost thermostat. If the heater now comes on, replacethe defrost timer and defrost thermostat. If the heater itself is bad, replaceit. Thanks and hope helpful.
Feb 14, 2011 | Electrolux ER7926B Bottom Freezer...
The Electrolux refrigerator is not working it's not cold but the freezer is working I was told it may be the thermostat. Food and milk in fridge is getting spoiled. It's been out for 3 days already. Thank...
First thing to check is if (a) the evaporator fan is running in the freezer and (b) if there is a build up of ice on the freezer wall. If the fan is not running in the freezer the ref. side won't cool. If there is a build up of ice on the freezer wall, then you a defrost system problem and there won't be any circulation to the ref. side. If you have a defrost problem, the defrost system consist of 3 parts: timer, bi-metal thermostat, and heaters. With fridgidaire more than likely the adaptive defrost board(timer) located in the fridge on the upper left side behide some white pastic is bad. If you change it go ahead and change the bi-metal thermostat, located behind the freezer wall, as well because its a very cheap part and will save you from having to do it later.
Nov 01, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Kenmore bottom freezer refrigerator model 596.71109101 were is the defrost timer located / freezer froze up deiced with heat gun but can't find the timer
it may not have a timer but a aditive defrost control . most common with newer model .. its located in the fresh food side just behind the thempt contro knob and its a pc board .. . . do ck your heater first and the defrost terminator as thes two parts ore more common to cause your freeze up .. mm
Aug 18, 2010 | Kenmore 65234 Bottom Freezer Refrigerator
Freezer side of refridgerator doesn't freeze foods properly and also makes only about 10 cubes a day. food side works fine, it's a Hotpoint model #HSS251FMB WW
If freezer is icing up, you might have a defrost problem. Frost free models have a heating element that is controlled by a timer to automatically defrost ice, defrost timer turns on defrost heating element every 12 hours to melt ice in freezer and allow good air flow.
You can test defrost element with an ohm meter(located inside freezer coils-will have two wires going to a plug connection), if OK replace defrost timer (located in various places depending on make and model
thumbs up
Aug 17, 2009 | Refrigerators
Freezer is icing over and fridge is not keeping food cold
I really believe your adaptive defrost located inside the fresh food compartment and inside the control panel is defective. It puts your refrigerator on a timely defrost and if defective this problem you listed in your post happens. Yes we may need to also check the defrost heater and defrost thermostat but with my experience with that type of Adaptive Defrost Control is famous for its failure.
ADAPTIVE DEFROST CONTROL Part Number 61005988 You can find it located on two of my websites. Some models like yours came with a Defrost Timer. We will need just look inside the control panel and see for sure. Here is a photo of the Adaptive defrost. If you should need to contact me please send an email or try to answer here. Problem is I don't get notifications when someone comments. appliancepartsouteast@live.com
Please rate and ask me as much as you like. Thank You, Sea Breeze
Part 61005988
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
Aug 10, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer freeze up
Your model TFX20JRBKWWW uses a defrost timer part number WR9X489 located behind the light shield in the fresh foods compartment. (top back area). Just in case you need to know, the defrost heater is a part number WR51X10101 located behind the back wall of the freezer.
Dec 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Will run all the time
Could you tell me more info like, how is the cooling and freezer temps. Is food spoiling ? does the defrost timer put it in defrost?
Oct 22, 2007 | Frigidaire FRS23R4A Side by Side...
GE Monogram Side by Side 42" Freezer light is lit on front panel.
The defrost timer is what I think you are asking. It is behind a cover near the light, The timer puts the fridge in defrost ever 6 to 8 hours. If the timer is bad it will stop the cycle of defrost and cause the freezer and the cold food section to warm spoiling the food and increase the freezer temp. Try turning the timer screw clockwise until you hear the fridge compressor stop. If after this listen for a crackling noise that will be the sound of defrost taking place. If doing this starts defrost, you will need to replace the timer.
Oct 20, 2007 | GE Monogram ZICS360NRRH C... Bottom...
Frigidaire FRS26R4A Side by Side Refrigerator Logo
243 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
