Question about Whirlpool Duet GHW9150P Front Load Washer
Do you know how to fix the "door locked light"
    Brigadier General:
  • 6,277 Answers
The door lock light indicates there is a problem with the door lock. Either the locking solenoid or the door lock sensor is malfunctioning and requires attention. Sorry- Service call!
John C
Posted on Mar 20, 2011
Testimonial: "Thank you! I now know I need a professional to take care of this problem. Your quick response was very much appreciated."
My washing machine will not lock to wash i have replaced the locking mechanism assembly and the lock lid light just blinks and click near the computer board what els should i try please jelp
How to fix a washing machine door lock in a Hotpoint ...
? 4:21
https://www.youtube.com/watch?v=p14EEa4AYGM
Jun 4, 2010 - Uploaded by eSpares
For all your washing machine spare parts go to http://bit.ly/1828iPF In this video, ... How to fix a washing machine door lock in a Hotpoint washing machine ... How to open a washing machine door that won't open normally.
Door makes clicking noise and won't lock or start - Kenmore ...
https://www.ifixit.com/.../Door+makes+clicking+noise+and+won't+l...
iFixitOct 30, 2013 - Door or Lid Latch Assembly If the washer lid or door won't lock the lockand switch assembly might be defective. This is a very ... The Kenmore Elite HE3 is awashing machine by Kenmore. ... Preview my answer. Post my ...
washing machine wont work. the door will not lock to start ...
www.shopyourway.com > Manage My Life > Questions
Manage My Life. washing machine wont work. the door will not lock to start the cycle. all the lights still ... Kenmore HE3T front load washing machine will not start.
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
Read on to learn how easy it is to fix the washing machine yourself... ... found on front load washing machine is the door switch and the door lock and strike.
Jan 23, 2016 | Washing Machines
Our hotpoint wt540 does not work. Choose any cycle and the wash light comes on and stays on. Then theres a small clunk from the machine but thats it. The door locked light is not coming on.
There is a small electronic lock on the inside of the machine where the striker unit of the door locks into and it sounds as though this have malfunctioned. You can change this quite simply.
Power Off machine
Take metal band which hold on door seal
Peel door seal off and you can now put your hand in and take this interlock out
Sometimes the lock will have screws to secure to the body of the machine
The lock might have visible signs where it has burnt but sometimes it wont
You can buy this lock from a parts supplier by quoting the model number and serial or product number found on the inside of the door
If this fails to work you most probably have a fault with the main board not recognising the door lock. For reconditioned modules and mother boards you can goto http://emwelec.co.uk/
Oct 17, 2013 | Washing Machines
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
May 05, 2013 | Ovens
Bosch classixx wash and dry - washing machine works fine but dryer does not start and door light does not go out?
if the door light is not going out it is an indication that the door switch is not working. this would also cause it to not run because it thinks the door is still open.
Mar 27, 2013 | Bosch Classixx WVF 2402 Front Load...
Error code " du "
DU = Door Unlock code
Washing machine displays error code F/DU after six attempts to unlock.
-Door lock assembly failed.
-Test door lock switch
-Visually inspect wire harness connection on CCU, Door lock assembly, replace door lock assembly.
The door lock assemble on this washing machine can be replaced from either the top of the front. The door boot can be removed or the top of the washer can be removed.
Hope this helps.
Jun 22, 2011 | Washing Machines
Washer. door lock wont lock. I hear a click click, like it's locked, but the indicator lock light is not on, then a couple seconds later I hear another click click like it's unlocking and then...
the actual door lock switch inside the wall of your washer where the door clips in has most likely burnt out or a piece has broken out of it i have found the only way to fix this problem is to replace the door lock switch
Jun 07, 2011 | LG WM-2277HW Front Load Washer
We have a Whirlpool WFS1071BW, and it has just stopped working for no reason. When you start the cycle (any cycle), it starts and then after 5 seconds or so, stops, the "Start" button light...
The problem is the door switch likely broken or not being activated. Make sure the door is closed firmly and nothing is caught in the door that might prevent the door from closing tightly. Replace the door lock/switch assembly if the door is closed firmly. You should hear the door lock/switch clicks when Start is pressed.
Let us know if you need further advice. Please accept the solution should you find it helpful and informative. Accepting the solution will not stop you from communicating with the expert. You can still communicate with the expert should you need further advice regarding the issue stated herein.
Mar 06, 2011 | Washing Machines
Machine stops, "door open light" flashes door is securely shut.
bad door lock and or harness replace door lock assy and check all connections
Jul 07, 2009 | Washing Machines
Whirlpool AWM8121 ?door open? light flashing and washing machine won't start. I had solved this same problem over a year ago. It seemed to be the door locking solenoid not working. I solved the problem by...
I had the same problem about a year ago, I replaced the door switch but didn't fix it, I found the brushes in the motor has worn out - Replaced the brushes and fixed the problem.
Jul 20, 2008 | Whirlpool AWM6120 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
235 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
