Question about Bosch Classixx WFC 2465 Front Load Washer
What bolts need to come out the washer when delelieved new?
    Brigadier General:
  • 6,277 Answers
That information I would have expected to have found in the washer manual OR received from the supplier/vendor when it was delivered!
I remember from our Bosch that there were a couple of transport bolts easily visible when the top was removed.
Hope this helps ;-0)
John C
Posted on Mar 20, 2011
I need an exploded view of a 1994 toyota 4 X 4 hub
Exploded view of the free wheeling hub
Turn the handle with your hand to the free position
Note the directions in which you can turn the handle: left-free, right-lock
  1. Remove the hub cover. Set the control handle to free.
With the handle in the free position, remove the six hub cover bolts
  1. Remove the cover mounting bolts, then pull off the cover. Remove and discard the gasket.
Pull the cover off
  1. Remove the bolt with washer.
Using the correct size wrench, loosen ...
... then remove the center bolt and washer
  1. Remove the mounting nuts and washers.
Next, remove the outside mounting nuts and washers
  1. Using a brass bar and hammer, tap on the bolt ends, then remove the cone washers.
Using a brass bar and hammer, tap on the bolt ends ...
... then remove the cone washers
  1. Pull off the hub body.
The free wheeling body should come off easily; be sure to discard the old gaskets
  1. Remove and discard the gasket.
To install:
  1. Place a new gasket into position on the front axle hub. Install the free wheeling hub body with the cones washers and nuts. Tighten the nuts to 23 ft. lbs. (31 Nm).
  2. Install the bolt with washer, tighten to 13 ft. lbs. (18 Nm).
  3. Apply multi-purpose grease to the inner hub splines.
  4. Set the control handle and clutch to the free position.
  5. Place a new gasket into position on the cover.
  6. Install the cover to the body with the follower pawl tabs aligned with the non toothed portions of the body.
  8. i hope this is what you are looking for
  9. plz vote comment and reply if need more help
Jan 18, 2011 | 1994 Toyota Pickup
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
Nov 24, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
The tank leaks from the two bolts that hold tank to bowl. I replaced bolts and the rubber gasket (it has ears). Slow dripping from two bolts.
Under the heads of the two bolts (inside the tank) there should also be rubber washers. Remove the bolts, clean the bolt holes (in the tank) thoroughly (a nylon scouring pad works). If the rubber washer aren't new, replace them. If the bolts aren't new, replace them too. While you have it apart, thoroughly clean the surfaces where the large rubber gasket seats too, in case your leak is coming from there. If cleaning and new bolts and washers doesn't fix it, you might try some plumbers putty or bathtub silicon caulk (not on the large gasket). Coat the two rubber washer generously all over. Good luck.
Nov 01, 2010 | Eljer 141-0220-00 Toilet Tank White
How do you change the oil on a 1985honda aspencade goldwing?
Center stand the motorcycle.First place your pan under the oil filter cover under the front right corner of the machine. Using a six point socket loosen the filter cover bolt and remove the cover. Dump out the oil in the cover being careful to save the spring and the washer that is stuck to the filter.Many Goldwings have lost there washer in a previous oil change , if lost replace the washer. If you desire change the o-ring on the bolt and the o-ring on the cover. Put the bolt back into the cover and place the spring first over the bolt, then the washer, then the filter , so the spring is pushing the filter against the engine. Put the new filter onto the motorcycle and snug up the cover bolt just enough so the oil wont leak out. Do Not Over Tighten The Cover Bolt. Now place the pan under the right rear corner of the motor. You will find a horizontal bolt near the bottom right rear corner of the main block of the motor. It will have an aluminum or copper sealing washer. Take off the bolt and let the oil drain out. When the oil is finished draining , put the bolt back in with a new sealing washer , if needed , and snug up the bolt just enough so that it does not leak or come out. Again do not over tighten the bolt. Now pour in the new oil through the dipstick hole. Be sure you use JASO MA certified motorcycle oil. You will need 4 quarts but you may have a partial quart left over. The quantity is something between 3.4 and 4 quarts. Run the bike and double check the oil level with your dipstick so you do not over fill.
Sep 12, 2010 | 1985 Honda GL 1200 Aspencade Gold Wing
How do I drain the oil on a ZZR1100 D3 - I beleive that there are two bolts need to locate them.
There are actually two drain plugs...look for the 17mm bolts with the washer under the head. The washers are "crush" washers that need to be inspected and replaced if necessary to prevent leaks.
The other bolt that needs to be removed is the oil filter drain plug. It is the large round cap. The bolt has an O ring for a seal. The new filter should come with an O ring for the drain bolt as well as a large O ring for the cover. (Be sure to ask or inspect the box when you buy a new one)
Check your manual for torque specs to be sure and not overtighten. On my '91ZX1100c the torque settings for the drain bolts = 18ft/lb and the oil filter bolt = 14.5 ft/lb. check your settings to be sure.
Jul 07, 2010 | 1990 kawasaki ZZR 1100
Installing new jacuzzi 1.6 gallon maxima toilet. despite following the instructions, the water is leaking from between where the tank connects to the bowl. Please help.
Yes, it seems the folks who wrote the instructions have never actually done any plumbing.
first place a rubber washer on the bolt, then put it through the hole in the tank. Then place another rubber washer on the bolt, followed by a metal washer and a nut. Tighten the nut, not the bolt.
Using a screwdriver hold the bolt in place, and tighten the nut until snug and the rubber washers are compressed slightly.
Follow this step with all the "tank to bowl" bolts.
Now the bolts are tight to the tank and will not leak water.
Then place the large rubber gasket over the flush valve hole on the bottom of the tank. and set the tank on the bowl with the bolts through the bowls holes.
Place a metal washer on the bolt, and then a nut.
Tighten each nut equally until the tank has no wobble.
Oct 01, 2009 | Jacuzzi Bath Maxima EL61 959 White...
Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Sep 18, 2009 | Asko W6461 Front Load Washer
Need bolts to stabilize washer for move
Dont know if you can purchase these. First people to try are the manufactures. Otherwise, unscrew the two screws at the rear top of machine and pull backwards to remove top.Then pack some towells or rugs around the drum then replace top. Don,t forget to remove rugs at new home.!! Good luck on your move.
May 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 70 series washer
check securing bolt on adgitator sometimes the bolt will strip out in main stem may need to tap out and fit new bolt
Mar 14, 2008 | Kenmore 22422 Top Load Washer
Bosch Classixx WFC 2465 Front Load Washer Logo
54 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
