Question about Indesit Washing Machines
Hi i have been away for few days washing machine was fine i dont use it very often as i live alone and takes a while to acumilate enough washing to use the machine. its a WIL163 Just loaded the washer up and went to press the power button and nothing happend no red flikering light??? the sockets have power going to them and i have checked my fuse box ... everything is fine?? im confused
    Brigadier General:
  • 6,277 Answers
Sorry but with such a major fault it is virtually impossible for anybody on this forum to remotely guess what is wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB. I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
Posted on Mar 20, 2011
What causes the water not to spin out of the clothes?
Hi, it means that the machine is not spinning fast enough and pumping the water away. If its not spinning enough then you have to get the machine looked at as its not clicking on in the cycle for it to spin fast enough. You also have to have it set to wash cycle that has a fast spin. If it is spinning fast then you have to look at the pump to make sure its pumping the water away.
Mar 18, 2016 | Washing Machines
Hi under my hotpoint aqaruius wml540 6kg washing machine the black rubber tube has come away from the machine therefore water everywhere i have the machine tilted so i can attach the black tube back to...
Sounds like you need a new tube or fastener.
Is the tube connector on back of machine long enough still ? (ie not broken off).
Please dont forget to vote if you liked my answer
thanks
Feb 11, 2011 | Washing Machines
What isF:17
Hello -- Looks like you are NOT alone in having F17 come up.
It covers a few possibilities.
Supply Hose (into machine) - Kinks , valve not open enough - etc Clean Filter Water Pressure
Mostly cover the water going INTO the machine - there is a different error code for the OUTLET pipes.
Ray
Jan 22, 2011 | Bosch Exxcel WFX 145S Front Load Washer
Hi, good evening. I have a zanussi iz12 washing machine that stops during rinse node and gives e20 fault (wont drain). I checked the pump - working fine. I've found that if i blow into the waste pipe the...
Hi there
I have an IZ12 jetsystem which sometimes works and other times it starts and then clicks and stops just before the water starts to run in. I usually turn it off and try it again a few hours later and then it starts to work again. Sometimes it is the next day before it will work again. Would anyone know the problem?
Jan 11, 2010 | Zanussi IZ12 Front Load Washer
Washer won't spin enough to remove water.
well firstly sorry your getting nagged at i have a wife like that,but getting down to it ,its a long shot but try checking the carbon bushes on the motor,take them out and see if there is plenty of carbon on them,if there isnt then this would cause the problem,ps when you take these bushes out wich are located on the side of the motor in plastic slides just give them a flick with your finger to get rid of any carbon dust wich may of acumilated over the years then replace them,hope this helps you and the wife,rgrds,paul.
Jul 07, 2009 | Kenmore 46462 Front Load Washer
Lubricant for coffe machine
Hi, you shouldn't really use any other lubricant apart from the one recommended, but I have used vaseline on a similar coffee machine, and as long as you keep it away from the brewing head, it should be fine. Do not rinse the brewing head in very hot water as it will wash away any lubricant that is there.
Jun 15, 2009 | Saeco Talea Ring Plus Espresso Maker with...
Washing machine filling with water when switched off
Electric inlet valve doesn't close properly. You should get it replaced ASAP. It is a cheap part and quite easily replaceable. Turn off water to your machine until you fix this and keep it unplugged.
Apr 24, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Washing Machines slowly fills with water over a few days
could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Mar 17, 2007 | AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines Logo
120 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
