Question about Mossberg Sport & Outdoor - Others
I have a mossberg 4x4 rifle bolt on action 30 06 i have alot of misfire catridges all of them they have that they get hit from the pin ,but i guess not hard enough to fire
  • 243 Answers
I would suggest that the firing pin channel needs to be cleaned. There may be a bit of crud or rust that is keeping the firing pin from applying a consistent strike to the primer. There may also be a burr that needs to be cleaned up.
Posted on Apr 20, 2014
4 Suggested Answers
SOURCE: remove bolt from 513 s remington rifle action
Point muzzle in safe direction.
Make sure it is unloaded chamber and clip !
Push safety off ( forward )
Pull trigger and pull bolt out at the same time.
Or sell to me ( have FFL ) just sold a 513 T that was to heavy for a old man.
Posted on Dec 02, 2009
Adrian762
  • 425 Answers
SOURCE: I have a Mossberg model 185k bolt action 20 ga.
The bolt you have acquired is either from a different model, or has been modified. With fire arms you are getting into dangerous territory, but I do suggest you have it looked at by a gunsmith. He will tell you what the problem is and you then make a decision based on that information.
Posted on Feb 03, 2010
vetteman3002
  • 2299 Answers
SOURCE: When was my Winchester Model
It was built in 2002
Posted on Nov 12, 2010
What do I need to mount a scope on a Mossberg bolt action rifle
You'll need scope mounts to fit that MODEL of Mossberg rifle and a set of rings that attaches the scope to the mounts.
Feb 18, 2015 | Mossberg Optics
I have a mossberg 385t,he took the bolt out to clean it and now cant get it to go all the way back in......What do i do?
This may be a bit tricky. If you have pulled the trigger as you re-insert the bolt and that has not worked. You may have to arm the bolt, try with safe off and pull the trigger as you reinsert the bolt. You may have to pre rotate the Coc piece into the slot in the receiver.
Jul 18, 2011 | Mossberg Marlin Rifle 992m,989,mossberg...
I took out the bolt to clean it and now can't get it back in. It goes part way.
Not real sure which model you have, one named is a semi-auto, the other is a bolt action. So if you have a bolt action, to reinstall the bolt you have to have the safety off, pull the trigger as you insert the bolt back in place (be sure it is unloaded and pointed in a safe direction). If for some reason the bolt has un-cocked you must first **** the bolt. some models have the firing mech. in the bolt.
Jan 04, 2011 | Mossberg Marlin Rifle 992m,989,mossberg...
Firing pin not working
Take the bolt out of the rifle and take the firing pin out of the bolt. Thoroughly clean the firing pin and surrounding spring with a harsh solvent (Gunblast works well--be sure to lubricate the spring and pin after cleaning).
Nov 28, 2010 | Mossberg Optics
My model 742 lever action missfires every 3 or 4 rounds.dimple on spent cartraige is much deeper than missfired shells
This may be an indication of a broken firing pin, dirt in the firing pin channel, or an over oiled firing pin/channel. All will exhibit this behavior. A through cleaning is called for, with dis-assembly to follow for parts inspection.
I have also experienced this behavior from a weak hammer spring.
Oct 10, 2010 | Mossberg Marlin Rifle 992m,989,mossberg...
I have a mossberg mod 352 KB with a broken firing pin need a schematic of the rifle or the firing pin, any help would be appreciated. Thanks
Go to gunparts.com online, they have schematics for every gun ever made and parts to boot. They sell to the public, certain items of course. Check them out.
May 29, 2010 | Mossberg Marlin Rifle 992m,989,mossberg...
I am trying to find extra magazines for my mossberg .22 magnum rifle bolt action, also am wondering how hard it is going to be to find parts for a weaver scope....????
Gunparts.com has the mags, the scope parts, I don't know, you would have better luck finding an old scope for the parts.
Feb 13, 2010 | Weaver Optics
How to load and clean and ammunition size for a mossberg 146b 22 s lr.
OK, your rifle is a bolt action 22. I can't find the146 but I have a 144 here. You clean the bore with a small rod and patch with solvent on it, run down clean patches till they come out clean, wipe down the metal parts with solvent, then wipe down everything with a patch lightly soaked in oil, run the oil patch threw the bore. Your ammo is .22 LR, If you have a magazine in the bottom of the gun, fill it up and pop it back in the rifle, if it is a tube magazine, pull out the tube, fill her up and close it up. Pull the bolt back, release the safety, and keep it safe. @22s are powerful little bullets.......
Nov 22, 2009 | Mossberg Optics
Sport & Outdoor - Others Logo
142 people viewed this question
Top Mossberg Sport & Outdoor - Others Experts
Colin Stickland
Colin Stickland
vgrechniw
vgrechniw
Level 1 Expert
RichardL
RichardL
Are you a Mossberg Sport and Outdoor - Other Expert? Answer questions, earn points and help others
