Question about HP Pavilion Notebook
HP Pavillion DV6000
Would say Software cannot be downloaded using "run as", logonas user with admin privileges and try again. all that was done bus the problem still occurs. It will not load from the disk
  • JDTec
    JDTec May 11, 2010
    What program is it that fails to load?
    Novelist:
  • 117 Answers
If you are logged on with a limited account or with a guest account you will have problems. Also make sure you are not locked out with Windows Steady State running. To solve your issue first make sure you are signed in as the Admin or an Admin. You will experience some problems with these machines because they use something called User Account Control, something HP put in to annoy everyone and prevent users from making critical mistakes when downloading software. You can Turn this off by going to control panel, then to users, and you will see a checkbox there to uncheck under disable UAC. once you do that it may prompt you to restart. thats fine. do that and you will get the machine booted back up. then from there it will pop a little box in the right hand corner of your screen that says your Security Settings have been changed, blah blah blah... just ignore it. Its standard to pop up and tell you that... Then see if you can run your disk or download your items.
When UAC is on you may have to right click your disk or program and select to RUN as Administrator, which will be an option when UAC is activated.
Let me know if that helps! If not, I can still help you
Good Luck!
Ruben
Posted on Jul 27, 2009
I cant download softwares or anything or run anything on my hp mini 1000 and it just gives me a massage from the administrator saying "access denied! you dont have enough power words to enable this...
reload the OS. (no OS stated by you, windows what?)
on all hp, press the F11 key at power on.
power on , and quickly hammer the F11 key (recovery)
next see the recovery page.
now pick fully restore
if you have data to save ? , that would be first,
then recovery,
this works on all HP from 2006 to now.
what you lack is Admin privileges. (power words)
if you had told the OS you run, there are hacks to make that work in most cases. (not so easy on w10 )
to test this fact
go to control panel
click users, see you? your login, name sure, click that and try to
set admin, privileges, it will now let you. nor let you manage other accounts, that is because your login is using non admin mode.
Nov 06, 2017 | HP Mini 1000 Netbook
What is the driver of hp pavillion dv6000 web cam?
Welcome to FixYA
Dear User,
Your Webcam Driver is Here....Download from Here and Install it Properly....
You will be Solved...
If this Helps you-Dont for get to RATE me....Thanks for Contacting FixYa....
Jul 03, 2010 | HP Pavillion DV6227 Notebook
Im using hp pavillion dv6000 today i could not
The Windows administrator or users password can be removed or changed with the Hiren's boot CD - Click on one of these link to download.
http://www.hirensbootcd.net/ or http://67.20.82.163/
Use a computer that has Internet access and download and burn onto a CD. Then boot-up this CD in your computer and select password removal and follow the instructions.
May 13, 2010 | HP Pavilion dv6000z Notebook
How to enable bluetooth on hp pavillion laptop
Hey there,
If your particular model of HP has the bluetooth installed from the factory, turning on the wireless switch on the front left edge of the laptop enables the bluetooth, as well as the wireless LAN. A bluetooth icon should appear in your taskbar, near the clock, when bluetooth is turned on. Most of the cheaper versions of the DV6000 series do not come with the bluetooth module installed. The module can be ordered from HP Parts and installed by the end user, if they have a little computer know how. You would then download and install the bluetooth software pack that is available on HP's support website.
Hope this will help to resolve your issue with Bluethooth..
Cheers!!!!!
Vivek
Feb 14, 2010 | Computers & Internet
My computer hangs up
as it is an HP DV6000, with known motherboard issues, I would suggest try running a few other programs also and see if they hang as well.
Feb 02, 2010 | Roxio Creator 2009 Ultimate for PC
Need drivers for hp pavillion dv6000 other devices pci drivers coprocessor sm bus controller running windows xp have yellow ?
You can find the drivers @ http://h10025.www1.hp.com/ewfrf/wc/siteHomeC?lc=en&dlc=en&cc=in&lang=en&os=228&product=top
Aug 27, 2009 | HP Computers & Internet
Hp pavillion dv6000 laptop drivers for microsoft windows XP prof.
try to download belarc advisor software. Run this in your vista OS and send it to me so I can check your hardware specs. This is the only way to avoid problems in the future or before you start the formatting.
Dec 01, 2008 | HP Pavilion dv6000z Notebook
ScanJet 5300c didn't work
Most likely the destination folder for the scanning is a shared folder with limited rights. As the administrator, reset the permissions for that folder or redirect the software to a common folder with read/write/creation etc... access.
Also, make sure you are using the HP provided drivers and not those from Microsoft.
Nov 24, 2008 | HP ScanJet 5300C Flatbed Scanner
Administrator problems
You may be the primary user but your user account may not have admin rights. This is a little unusual in Windows since most users have admin rights by default (this isn't a good security practice, but Windows tends to do this anyway).
I did a quick search of the web and discovered a set of instructions that will allow you to log into your Windows computer (assuming you have Windows XP) with admin rights. Once you do, run the software again and see if it works. If it does, you're ok. If it doesn't then the problem is with the HP software and not your user rights. Good luck:
How do I get admin rights on Windows?
Sep 03, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP software will not install
this error tell us that you are not logged in with full admin rights on your computer to install software and driver package, and it also sounds like you are trying to start software install using the "run command"
There is nothing wrong with printer but you do seem to be having trouble loading the required software and driver package on your p.c.
Are you also using new Vista software/driver package for your HP OJ 4215 cause the one that came with it maybe XP.
Go to HP and download correct package, AND log on as administrator with FULL priveledges, your username (normal login) may not, from the looks of this.
link to hp software download for HP OJ 4215
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&cc=us&dlc=en&product=351106&lang=en&
"it obviously needs a fix--tell me what it is"
Nov 05, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP Pavilion Notebook Logo
47 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
