Question about Microwave Ovens
I have been given a Typhoon Kitchen blow torch but no instructions! I do not know what type of gas to use etc. Please help
PLEASE HELP!!!!!! I had a house built 6 years ago and had an over the range microwave installed. The first one that came with the house was a GE. after like 6 months it would run for a few seconds and...
It may be that the exhaust duct is blocked or the filter is dirty.
That can cause the oven to run chronically hot, which damages the microwave.
The whole duct needs to be checked for any blockage.
You will need to remove the oven from the wall.
To remove it from the wall, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Whirlpool customer service is here and you can also enter your model number on that page to download your owner's manual, installation instructions, etc..
You can find links to helpful exploded view diagrams and order parts here.
I'd recommend that your bookmark this link to your favorites.
Oct 10, 2011 | Whirlpool MH2175XS Microwave Oven
I have been given a Sanyo Fan Assisted Oven 1200w / microwave 900w but no instruction manual. Can you help?
We can most likely help you but need and exact model number so we can help you try and find you the correct manual.
I am going to post 2 links that you can use your model number to try and download a manual. In the case of these manuals if you have a model number that is close to your model number it will work for you.
http://us.sanyo.com/Customer-Support-Owner-Manuals-Locator
You will need your model number.
Also try here:
http://kitchen.manualsonline.com/manuals/mfg/sanyo/emc6786v.html
If you are in the UK you will need to use this link:
http://uk.sanyo.com/support/Instruction-Manuals/
Thanks for choosing FixYa.
Kelly
Aug 27, 2010 | Microwave Ovens
Everything works except the microwave function
yes there are fuses inside it,,,but,,,there is also a lot of volts still in it too, "ie, 1000's" and they bite too,
bit like a police stun gun will,,but they may not just stun you,,they could very well kill you,, so be warned!
also the fuses are not the normal sizes you would have at home, and some of them are "slow blow" type and some are "fast blow" type,,, and one is at least 1 to 4 1000 volts type?
and my gess is a fuse has poped becouse the magnatron has given up the ghost and poped its clogs!!! like its dead! and a new magnatron would be dearer than a new microwave to have fitted,,
so,,,get a new unit,,dont tinker with it and stay alive!
Jun 06, 2010 | Frigidaire PLMV169DC Microwave Oven
Turn on oven 30 seconds latter turns off.
You have given very little information, I give simple instructions to reset the microwave and check the simple problems sometimes found with them.
If there has been a power surge, or electric fuses blowing, etc., sometimes you can clear a problem simply by unplugging the microwave, and then plugging it back in after a minute.
After that, make sure that your clock is set to the correct time. Then try your microwave again.
The other thing that can make the microwave go off is if the door is not tight and latched properly.
Look at where the latch of the door snaps into the body of the microwave. Usually, they look like hooks that fit into slots. Make sure that the area is clean and that they are not broken, chipped, blocked.
If they are, clean the holes. Replace the latches. I can't provide good instructions without knowing what kind of microwave you have.
Please leave comments on the kind of microwave you have, whether the clock works, and any other conditions that happened before the problem. If there are beeps that you hear and how many, lights that come on, all of this will help the techs isolate your problem.
The trouble can also be on the inside of the microwave and that will require step by step instructions to open the microwave and look inside. If the problem continues, a qualified person will respond with better instructions.
Thank your for allowing us to serve you better by leaving comments.
Nov 25, 2009 | Microwave Ovens
Help..what is part number on pasrtstore.com???
What??
Can you be more explicit in your request please what part number?
what item what model what part etc etc. the url is full of items i would not know where to start
My crystal ball is all out of guessing gas here
Aug 30, 2009 | Samsung 1.8 Cu. Ft. Over-the-Range...
Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Aug 04, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Just moved new house, panasonic "the genius" microwave (inbuilt into kitchen wall!). It is saying "word prompt, demo mode only" and although will respond to key pad, won't cook as in...
This is a UK model? Try this:
http://www.samsung.com/uk/info/contactus.html
Otherwise please reply back and let us know what country you're in.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 24, 2008 | Microwave Ovens
GE EMO300SS microwave
Yes this can be done.  The unit will need to be taken down and the vent fan will need to be reversed.
Oct 13, 2007 | GE EMO3000 Microwave Oven
Microwave Ovens Logo
152 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
