Question about Forfex BABYLISS PRO Adjustable Taper Clipper in Silver (Model:FX684BX)
Find forfex guide combs - Forfex BABYLISS PRO Adjustable Taper Clipper in Silver (Model:FX684BX)
What is beach combing?
Beach combing is basically metal detecting on the beach. Most metal detectors on the beach are looking for jewelry and coins and in the busy summer seasons, probably can find quite a bit. This is the most popular kind of metal detecting.
Feb 21, 2013 | Retail Supplies
I purchased a pair of Forfex Magnetic Motor Clippers (FX684XW), sku #763358 and a mini-trimmer clipper (FX785NW) had them for about 3 months. I have had nothing but problems with them. They have pulled...
Have you tried removing the 2 screws holding the comb plate down against the moving blade?
Often cut hair residue will build up under the comb plate to the point where the blade does not cut properly and even seizes against this plate.
Just remove the screws, the comb plate and the cutting blade, clean everything thoroughly with some rubbing alcohol. Make sure to scoop / vacuum out any hair that hair that has fallen into the clipper body through the hole under the blade.
Once the parts are cleaned, reassemble the unit and apply a liberal coat of light mineral oil (available at any drug store) to the blade and to the underside of the comb plate. Don't be stingy, you can always wipe off the excess later before using it.
Now screw down the the comb plate onto the blade and body and tighten the screws just enough that it holds the plate securely but doesn't bind the blades in place.
Turn on the clippers and check that they reciprocate properly. Turn off clippers and adjust the tightness of the screws as required. If the clippers don't start when you switch them on then you probably have the screws too tight.
Now turn on the clippers and hold them blade end down over the sink and pour some mineral oil (at least a spoonful or two) directly on the blade / plate interface so the oil washes over and under the moving blade and in between the blade and the plate. Do this while the clippers are running, there will be a little spatter but that's why you are doing it over the sink.
You can do this oil wash every few haircuts cuts if you like, it's just an easy way to wash out the tiny hair particles and keep the blade well lubricated at the same time. Just wipe off the excess with a paper towel and its good to go. Hope this works for you and helps out a bit.
Please comment back here to this page if you have any questions or just require further general assistance and I will respond as soon as I see it.
If this was at all helpful please click on the 4 Thumbs Up helpfulness rating icon you see on this page.
Thank you very much and good luck.
Joe.
Feb 23, 2011 | Forfex FX 690
I am look for a charger for forfex babyliss pro model fx652 3.6v dc 1a
I have a charger for a forfex clipper fx 652, if you contact me sweenytodd@operamail.com I can give you details...
Sep 14, 2010 | Forfex FX 652 Hair Trimmer
I need a clipper guide comb for an Oster model 606B hair trimmer. Where can I buy one?
Buy one on e-bay. I have the same clipper and needed the guide combs, so I went out on a limb and bought the Oster combs that fit the 76 models. It says "universal" on them, and they fit my old 606B perfectly!
Apr 15, 2010 | Oster Health & Beauty
Battery is dead
it may be sold in electrionics shop
Apr 03, 2010 | Forfex FX 766 Hair Trimmer
Forfex blade reinstall
I have the Forfex babyliss 720 and I can't get new blades installed in it. I have tried 8 times and someone else has tried 5times. Do you have any instructions on this model.
Thanks
lchardt@embarqmail.com
Dec 16, 2009 | Forfex BABYLISS Pro Clipper/Trimmer Combo...
Power adapter for forfex fx652
There are very few parts available for Forfex products, are you sure it is the power adapter? If the clipper is 3 years or older most likely it is the battery inside the clipper, check their website for service centers.
Dec 20, 2007 | Forfex FX 652 Hair Trimmer
Forfex BABYLISS PRO Adjustable Taper Clipper in Silver (Model:FX684BX) Logo
104 people viewed this question
Top Forfex Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Forfex Health and Beauty Expert? Answer questions, earn points and help others
