Question about Krups Orchestro Dialog FNF2 Espresso Machine
My Krups iron only heats up slightly. HOw do I repair?
    Problem Solver:
  • 14 Answers
Your question is listed under espresso machines. Are you talking about a Krups Espresso Machine? Please clareify. Does it make Coffee and Steam?
Posted on Aug 03, 2008
How to remove the cover of v65 iron
How to open the Krups V65 iron
There are no clearly visible screws. Below the "secret" unveiled:
you have to pull the cover in the arrow direction, disengaging in circled positions.
After that, pull out the upper rubber keys, you will see the screw below:
Feb 25, 2012 | Krups V65 Iron
The iron is not getting warm indicator stops on first level
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Apr 10, 2010 | Krups V65 Iron
Iron does not heat light goes on but does not get warm
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
heatman101
Mar 21, 2010 | Krups V70 Iron
Krups KM7000 grinds but won't brew, warming plate no heat. Is this repairable, (perhaps a fuse?) or is it junk. Bought the machine in March 2008
Mine had the same problem ... all the lights are on, but no heating on the plate, and no dripping of water.
After a weekend on the workbench, I've mastered this machine. The KM7000 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7000@flightsystems.biz.
Oct 30, 2009 | Krups KM7000
Krups V70 Iron - stopped working
Sand points on temperature control switch.
Jul 07, 2009 | Krups V70 Iron
Krups model KM7005 water wont heat
After a weekend on the workbench, I've mastered this machine. The KM7005 has 2 x MicroTemp G4 thermal cutoff (TCO) fuses which interrupt the Live line, for overheat protection. Mine didn't overheat per se, but the TCO blew anyway. Not reset-able ... need to be replaced with a soldering iron. I'll be happy to advise you to fix this, or fix it for you. Write me at KM7005@flightsystems.biz.
Jun 02, 2009 | Krups Small Appliances Espresso Machine
Dead krups waffle iron
That is probably a thermal fuse. It is designed to open and stop heaters from working incase of over heat condition.
Meaning if you did not leave the appliance on too long with nothiung in it, the thermostat may be not opening at correct temp or the fuse was in a place where it got over heated or the fuse was weak.
You can replace it 1 time see if it worked ok but if it goes out again and you didn't see anything this time best replace it. Especially if under $50.00. Thermostat will probably run 1/2 of that. Thermal fuse 3 to 10. Try a heating AC parts store and take the old party with you.
If this helps you please help me by rating me as high as you can. Thanks for using fix ya.
May 06, 2009 | Krups 65475 WaffleChef Waffle Maker
Apr 10, 2009 | Krups Coffee Makers & Espresso Machines
Why isn't my Iron heating up? Just finished filling my Krups V65 iron with water. Was ironing linen shirt on linen setting, all of a sudden, heat dropped all the way down to light one (very low heat) and...
I do believe the thermostat is defective.All the iron have a small thermastat top control the temperature and is working like a switch.If the switch don`t work get stuck on the same position.Unfortunatly sometimes is better get a new one themn fix an old one but this is The Market and nothing i can do personally.Also make sure the thermostat knob is working properly.If you hear a click when you turn is ok.
Good Luck
Jun 12, 2008 | Irons
Red Light Blinking
heatman101
Jun 11, 2008 | Krups V70 Iron
Krups Orchestro Dialog FNF2 Espresso Machine Logo
180 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
cyfred
Level 1 Expert
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
