Question about Garden
I just bought a used Kingavon SC1 1000w hand held steam cleaner & can't get the safety cap off to put water in it. I've tried pushing down & turning the cap but it seems to be stuck. any solutions or ideas where I could get a manual would be appreciated. Thanks
SOURCE: No steam release
I solved the problem, the metal (hot!) release rod gets stuck & needs a little push.
Unfasten the top by prying off the rubber gasket after removing the top. Remove the 2 small phillips screws, then remove the front that holds the nozzle, & remove those 2 phillips screws.
Carefully pry up the top with a putty knife, inside you will see the tip of a metal piston that the plastic release knob is supposed to contact. Set it on its front, & soak the piston with a light household or sewing oil, giving it a few taps with a blunt object occassionaly to loosen, heat up & test before reassembling, but remember, the piston is very hot. When you push on the piston with a screwdriver, it should release the steam, but also stop when you let go. Work with it a little & it will come back to life.
Posted on Nov 08, 2007
SOURCE: prolectrix 3 tier steam
Hi i have a prolectrix pro steam iron that does not steam it gets very hot and when you press the steam button it makes a sort of pumping sound but no steam
Posted on Oct 18, 2008
  • 4 Answers
SOURCE: Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
SOURCE: Shark Steam Canister S3325 will not turn on when switch pressed
I had a similar problem; disassembed switch and clamped electrical bayonets tighter with a pair of pliers; works good now.
Posted on Jul 23, 2009
  • 10865 Answers
SOURCE: We have a spot bot that leaks almost the entire
Hi rvo... the nozzle activator (pin that depresses the clean water nozzel) is probably clogged with "gunk". It is easy to remove with a pair of tweezers or needle nose pliers.. rise it under water and reseat in the unit. If this maintenance does not solve the problem I recommend that you take it into your local vacuum repair shop as you may have an internal problem causing this annoying leak. Joe
Thanks for choosing Fixya!
Posted on Dec 14, 2010
Where can I purchase a safety filler cap?
See Google.
[PDF]steam cleaner - Pdfstream.manualsonline.com
pdfstream.manualsonline.com/.../e7f63cef-798e-41f3-bec7-5e43d5da5d...
When using your Steam Cleaner basic safety precautions should always be ... not screw the safety/filler cap onto the .... When using the Ultra Steam Shark II with.
Sep 29, 2015 | Shark Ultra Steam-blaster Hard Surface...
Refill water tank
With the unit unplugged push down the steam lever and hold while pushing down and turning the cap..
Dec 25, 2013 | Euro-Flex Monster 1200 Handheld Steam...
Can't remove the safety cap!! What do I do?
if it is anything like mine...you push the cap down, give it a full turn & release. keep doing this (maybe 5 or more times, and eventually it will start unscrewing easily without needing to push down
Sep 06, 2010 | Euro-Pro Shark SC710L Handheld Steam...
Need a water tank safety cap for euro- pro canister steam cleaner model S3325H
I need a cap which is located on the back of the clean water tank on a Bissell model 1950-3 steam cleaner
Aug 20, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
Karcher SC 1502 steam cleaner can't get cap off water tank
Dear jrider784,
I solved a problem like this on FIXYA, just a few months ago. I gave this solution. Try to fill the machine from somewhere else. You can do this from the outlet. If you manage to do this, put on the machine. ( now you know that when there is hot water in the machine, the tap goes round free for safety). Now as the water starts to cool down....start trying to see if you can unscrew it. My plan is that with the hot water, the safety will start to work again. If the cap does not release the safety on cooling, then there is no other way but to destroy the cap and replace with a new one. Very important to mention that this job must be done by a qualified technician or some one who knows what he is doing. Working with hot water is very dangerous.
Regards,
Fulltech.
Jul 27, 2009 | Karcher DE4002 Steam Vacuum
I have a clogged Shark super steamer.
I have had a Shark Steam Mop for about 8 months now & all of a sudden it stopped producing steam. I was using it this past weekend & it produced steam as usual then all at once it stopped. When I push down on the handle to make the steam, it does nothing. No sound or steam. I have always used distilled water as well. Any ideas? Could it be clogged. The unit doesn't appear to get very warm now either. Thanks!
Mar 11, 2009 | Kitchen Appliances - Others
Safety cap on the Euro-Pro dexuxe steam cleaner style SC507H
Oct 24, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Eureka Atlantis 2591A Upright Steam Vacuum
if it drips out while the tank is off the machine it couldbe the spring load mechanism in the cap. try soaking it in hot water for a few minutes to swell the rubber then with a pen push the spring plate up and down to lubricate the rubber. then try and see if that works. usually they are gravity fed systems but only works when the tank is in the unit.
Jun 08, 2008 | Eureka Atlantis 2591A Upright Steam Vacuum
Garden Logo
168 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
