Question about RTO Plasplugs inc No. TLC207 Tile Cutter
How do you use the Plasplug Ssf523 Sealant Finisher?
    Novelist:
  • 157 Answers
Hello. The manufacturer's suggested method is to place the tool against the wall so that the "flats" fit into the corner resting against the wall. Then you push along the seam gathering the excess into the "shovel" area. check out this link for a visual: http://www.plasplugs.co.uk/tiling-silicone-sealant-finisher.html While this works, it does lead to some possible issues.
Firstly, if you're like me, you will have a fair bit more silicone/acrylic in the joint then the paddle will hold. Every time you remove and re-apply the paddle, you will get "ripples" in the seam. Here's a few tricks for these tools that I've learned along the way. And incidently, these work for other silicone tools as well.
  • A margarine container (or similar) half full of water and a moderate squirt of dish detergent in it. Use warm/hot water first, and squirt after. You want a solution, not bubbles. Dip your tool often, this will make it easier to clean/use, and does not affect the material.
  • Have plenty of rags handy... they do come in handy.
  • Clean and/or wipe the tool regularly. Material that sits for too long begins to cure and will be noticed in your work.
  • When using a push style tool, do manageable areas and back-drag. Once you've applied and cleaned one seam for instance, clean and dip the tool, then drag the profile backwards along the seam. This will smooth out any "ripples that have occurred.
Hope this helps you out. Please remember to rate this if it has.
Thank you.
Richard
Posted on Mar 20, 2011
How to access the blade on my plasplug wet tile cutting machine
Depending on the model you should be able to lift of on side of the cutting deck
Jan 31, 2017 | Blade Saws
WE need the on off swich for plasplug power master wet dry saw
you could try looking around the internet or try ebay.
Dec 14, 2016 | Saws
Hello Expert, Canon image runner was moved to a new location. Now error displays "attach finisher". Do you know what may be causing this error? Thank you
Hello rob,
the copier sees the finisher is attached but it does not believe the finisher is firmly docked against the copier.There is a mechanical latching system that holds the finisher firmly against the copier and has a positive latching system, This externally mounted hardware that resides on the copier not only has a physically latching mechanism **** also has a metal tab that sticks out and penetrates an area of the finisher.This small **** on the finisher has a switch inside,When the finisher is close enough and secured to the copier the metal tab on the copier penetrates the **** on the finisher and presses the switch and tells the copier the finisher is in place.The finisher is either not close enough and docked securely to the copier, or the metal tab on the copier is bent and not reaching the switch on the finisher, or the switch was damaged by the move.
Feb 14, 2011 | Canon imageRUNNER 5000 Copier
My aficio 2035e shows sc 329 and sc 322. what does this mean?
  1. Remove paper from all output trays. Depending upon the options fitted to your device, the output trays are:
  2. Locate the gray cables that are connected between finisher and main unit. Check that they are secure, and that the cables are in good condition.
  3. Switch off the device at the red power switch.
Dec 16, 2010 | Office Equipment & Supplies
Ricoh AF/2090 finisher des'nt attached
The finisher for a Ricoh 2090 is not hot-swappable, meaning you have to turn the copier off completely, attach the finisher cable, and then turn the copier on in order for it to correctly recognize the finisher.
Jun 17, 2010 | Ricoh Aficio 1035 Copier
Finisher not connected
check the door that the staples go in that door has been known to "stick". make sure also the guides are lined up on the finisher. ..Iv'e seen a few time with that model where even though the finisher looks like it where it should be its not, there is a little peg on the copier that should line up with a hole on the finisher i've seen it where the peg doesnt make it in the hole and the censor that tells the machine the finisher is attached is not activated. To verify its just with the finisher turn the machine off unlpug the machine than disconnect the finisher cable, power the machine back up and make sure its working with out the finisher. Never plug in or disconect the finisher cable while the machine is on this can cause a board to malfuntion.
Apr 08, 2009 | Kyocera Copystar CS-5035 Copier
Intermittent error code E713-0004 Already replaced every board in copier and finiser (R-1). Also replaced the wire harness from copier to finisher, even tried another R-1 finisher, still throws code.
E713-0004 -05 Title Finisher IPC communication error (checksum error)
Remedy 1. Check the cable connection of the Finisher.
DC Controller side: J462, Finisher Lattice side: J9043
2. Replace the Finisher Controller PCB.
Description Communication between the host machine and the Finisher was lost
Dec 18, 2008 | Canon Office Equipment & Supplies
Tile Saw
i know blades on tile saws don't have to be super tight, i'm not familar with that kind of saw, i put a wrench on the nut and hold on to the blade with my hand and hit the wrench with a rubber mallet, and of course have the unit unplugged
Aug 31, 2008 | Saws
RTO Plasplugs inc No. TLC207 Tile Cutter Logo
519 people viewed this question
Top RTO Measuring Tools & Sensors Experts
Steve
Tim Venetis
Vuk B
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
