I have two pakon scanner, F335 report error code 28, the second scanner F235plus report error 235 . please what is the solution,
2 Suggested Answers
SOURCE: We are looking for USB Board of Pakon film scanner
PLEASE, WHAT CAN I DO IF PAKON FILM SCANNER FP335 REFUSED TO SCAN WHEN THE DUST AND SCRACHED REMOVAL IS ON. BUT IF WE OFF IT THE SCANNER WILL SCAN BUT WITH STAINS
Posted on Jul 06, 2010
P-9, P-21, P-28 error code
P-9 Replace the black developer and drum unit.
P-28 Have tech clean the IDC sensor located under the transfer belt forward section (right side of the copier) the rear one towards back of the machine right side There are two clean both
Above two codes should then fix P-21 which is the fault that registration is not right. And Since the Black Image unit is the reference for the other three color in regards to Registration that is why P-9 and P-28 need fix first.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Apr 17, 2014 | Konica Minolta Bizhub C364 Color Copier /...
X-rite ats color scanner error
X-Rite doesn't support the ATD, ATS or PDC-S anymore, however we at Lithronix still do! Please give us a call at 513-235-4299 or see our listing on ebay! We have repaired systems working for more than five years on the market! www.lithronix.com
Jan 18, 2013 | Office Equipment & Supplies
The drivers for this device are not installed. (Code 28) There is no driver selected for the device information set or element.
Cause of the Code 28 Error A Code 28 error is caused by a missing driver for that particular piece of hardware. There are any number of reasons that a driver might not be installed for a device but your troubleshooting of the problem will be the same no matter the root cause.
Resolution
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
    • Remove or reconfigure the newly installed device.
    • Roll back the driver to the version prior to your update.
    • Use System Restore to undo recent Device Manager changes.
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Please let me know if you've fixed a Code 28 error using a method that I don't have above. I'd like to keep this page as updated as possible.
Applies To The Code 28 error could apply to any hardware device in Device Manager but most Code 28 errors seem to affect USB devices and sound cards.
Any of Microsoft's operating systems could experience a Code 28 Device Manager error including Windows 7, Windows Vista, Windows XP, and more.
Still Having Code 28 Issues in Device Manager? Let a community of computer support enthusiasts help out! Post the details of your problem in the PC Support Forum. Be sure to let us know that the exact error you're receiving is the Code 28 error in Device Manager. Also, please let us know what steps, if any, you've already taken to try to fix the problem.
----------------------------------------------let me know if this helps--------------------------------------------
Jun 20, 2011 | Computers & Internet
I have a pakon scanner f 235 which read error code 235 ,what can i do to resolve that problem.
the drivers for the scanner might have been corrupted
you might have to uninstall the printer/scanner restart your computer then reinstall the printer/scanner and its drivers
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options plus you can troubleshoot hope this helps
Apr 08, 2011 | Computers & Internet
How do i get rid off code error 28
http://pcsupport.about.com/od/findbyerrormessage/a/code-28-error.htm
Oct 19, 2010 | Computers & Internet
The scanner has reported a hardware error. Please reset the scanner by switching on and off. If this does not work please contact your local nikon service or support service office
Maybe this refer also the hardware faulures on a nikon 5000ED. I managed to repair them my self after being mischarged a couple of times at NIkon repair centre.
Please see some solutions I added on
www.scancare.nl/scanner.html
Different problems regarding a nikon 5000ed were shown.
regards
Andries Bos, www.scancare.nl
May 20, 2010 | Nikon Super Coolscan 4000 ED Film Scanner...
Hello. For me a problem with the device 4345 mfp. Produces an error 30.1.19. It happens after I have cleaned scanner mirrors. Prompt what to do please?
This error code is reporting a scanner lamp failure. Check to be sure you did not dislodge the lamp during your cleaning of the mirrors. If necessary, reseat the lamp carefully.
Aug 05, 2009 | Office Equipment & Supplies
We are looking for USB Board of Pakon film scanner F-235
Jun 25, 2009 | Office Equipment & Supplies
I need a CD for HP Deskjet F335 All-In-One
i lost my cd to install my HP Deskjet F335 All-in-One Printer.Scanner.Copier Can anyone help me install all the features in my computer..Thank You!
Jun 10, 2008 | HP Deskjet F335 All-In-One InkJet Printer
125 people viewed this question
k24674
jasbo
jasbo
