I have taken apart the dispenser drawer and all its hoses and housing to clean any residue but the machine will not dispense the fabirc softener. Washing powder is fine not problem but fabric softener stays in the drawer. Any clues how to solve?
    Brigadier General:
  • 6,277 Answers
I hope you do not mind me saying this but, although you have cleaned the softener drawer, the siphoning tube is often overlooked because it is difficult to access.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If all is clear it could be that the water dispensing is not filling the softener tray itself. It is possible to check by selecting (final?) rinse and pulling the drawer out very slightly until you can see and hear the water running in. If it isn't it's a call-out ;-0(
Good luck,
John C
Posted on Mar 20, 2011
Fabric softener dispenser/how to clean
Good Morning Friend,
I understand you want to know how to clean the fabric softener dispenser from your Frigidaire washer, model# ATF7000ES. To remove the drawer and clean the dispenser, please do the following:
• Remove the drawer by pulling it out until it stops.
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock tab (left rear portion of the drawer). Pull out the drawer.
• Remove the insert from the bleach and fabric softener compartments.
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders and liquids. Large amounts of fabric softener residue may indicate improper dilution or more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residues from the upper and lower parts of the recess.
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 28, 2014 | Frigidaire Affinity ATF7000E Front Load...
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
from the upper and lower parts of the recess. (Figure 4)
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Why does my WFW9450WW00 Duet Tumble fresh 4.4 dispense the softener with the detergent
Have you Cleaned the dispenser drawer. Remove the drawer and clean it thoroughly in the sink with warm water making sure all residue is removed. The take a damp clothe and clean the top of the housing where the drawer goes. Let me know after doing that if you still have the problem.
Jun 02, 2014 | Whirlpool Duet GHW9150P Front Load Washer
The softener and bleach compartments are always filled with water. Also, the dispenser drawer is VERY dirty. How do I remove the drawer to clean it?
I have the exact same problem. Ive taken the hoses beneath the drum apart in case it is backed up all the way to the dispenser. Found a bra wire and removed it. Ran another cycle - still the same problem with water in the dispenser - even running down the outside front face of the washer. Not sure what to do next?!?!?!
Nov 06, 2010 | GE WSXH208A Front Load Washer
I have a kleenmaid top loader washing machine. There is a leak coming from the bottom of the machine - I have taken the fabric softener cup out - but there is no bolt to remove the agitator. any ideas?
You could have a clog in the housing underneath the dispenser where the water flows through a hose into the tub.
Pull the dispenser drawer completely out.
There is a tab that needs to be depressed to release the drawer and remove it.
Check the opening at the bottom of the housing just inside the dispenser housing opening to see if a small sock or garment is clogging this opening.
Reach down into this opening to see if an item is inside the hose.
This is the normal issue that will cause water to leak out of the dispenser housing.
Wash the dispenser drawer thoroughly with warm water. Make sure that you pull off the siphon covers and wash all siphon holes. This process is described in your owner's manual. Replace the dispenser drawer and try the washer again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 10, 2009 | Washing Machines
How do you clean the fabric softener dispenser? I can't seem to be able to take it apart.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
Jun 15, 2009 | Washing Machines
MY FABRIC SOFTENER JUST SITS IN DRAWER
Mar 18, 2009 | Washing Machines
Bleach & Softener not emptying
Feb 26, 2009 | Kenmore 46462 Front Load Washer
Diepenses fabric softener too early
Jan 24, 2009 | Washing Machines
Dispenser problems
Open dispenser drawer and push down on center plastic tab at back of dispenser to allow you to take dispenser out of machine. Take the plastic pieces off and clean them. (they need to be clean in order to siphon the bleach, softener, etc out. If there is water left in them, the water fill valve is OK. Cleaning should fix your problem. If you are using concentrated additives, try diluting them a bit with warm water when you add them to the dispenser. Remember, only one tablespoon (max) detergent, one teaspoon (max) fabric softener per load.
Oct 18, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
168 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
