Question about Ctm HS-2800 Power Wheelchair
I have aenigma wheel chair with a shark contoller when you switch it on all lights come on then only one left hand light flashes red thanks Stuart
  • 692 Answers
Stuart iy\ts indicating low battery voltage charge the batteries and see if it goes away if it doesn't then the batteries need replacing or your charge is not working correctly If after charging overnite when you get up in the morning the charger should have a green light on and the battery level should be full. If after just a bit it goes to the red flashing light then your batteries are bad and need replacing. If the chair is less than 6 months old then the batteries are under warranty and your provider(where you got your chair) must replace them at no cost Hope this helps
Posted on Mar 21, 2011
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Tip
Helpful Information when posting problems ith power chairs, scooters or lift...
If you are having problems with a power chair, mobility scooter or lift chair Give as much information as you can. Did Medicare pay for the mobility product? How old is the product? How old are the batteries? When you are getting flashing lights on the battery level indicator or light on scooter console. Count the number of flashes ie: 4 flashes pause 4 flashes pause etc. If the lights are scrolling are they moving right to left or left to right? As much info as you can give will help in telling what problem you are having and easier to help if possible.
In problems with lift chairs does to chair go up but not down? Will the chair move up or down at all? Do you have a red light visible on your transformer that is plugged into the wall socket?
Thanks
Lennie
on Sep 13, 2010 | Health & Beauty
Red light flashing on joystick about 10 min after charging
Most of the time it may be the batteries at fault. One more thing to try is charging the chair with the Joystick on all night 10-14 hours uninterrupted charging. Your chair may suffer from current roll back. There is a circuit in your system that has to be reset by the long charge cycle to reset it. I did not make this up. it occurs when the motors over heat or have a a large current draw. the chair will operate normally for ten maybe even twenty mins. then suddenly drop down to 2 flashing red lights.
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Feb 18, 2013 | NRS Hoveround MPV 5 - Used Power...
Blinking yellow wrench light on pride jazzy 614 HD
Your version has a Dynamic Controls model controller and joystick.
Unplug the charger and engage the motor/brake lever so the chair is no longer in free-wheel mode (con't push by hand)
Turn the chair off, wait 5 seconds, turn the chair back.
If chair still does not run and your wrench is flashing you have a problem. Count the wrench flashes - the flash count indicates the error detected. 3, 4, 5, and 6 flashes indicate and error with the motors.
3=Left motor fault
4=Right motor fault
5=Left brake fault (may not be engaged)
6=Right brake fault (may not be engaged)
Any other fault code usually means the electronics or wiring is bad and not worth fixing.
Jan 06, 2013 | Pride Jazzy 614 Hd JAZZY 614HD
When I turn on controller power the speed lights flash slowly. Joystick does nothing and chair is dead. Chair is Pride Jet 3 Ultra.
Do all of the speed lights flash at the same time or do they ripple from left to right? If they ripple from left to right the chair is in lock mode and you can use the unlock procedures from my tips to unlock. If they are all flashing at the same time you have an internal joystick problem and the joystick needs to be replaced Hope this helps
Apr 27, 2011 | Pride Mobility Products New Pride Mobility...
The chairs lights are flashing from right to left on the joystick which is call the sleep mode can not get it to reset.
Hi to unlock the shark joystick turn on the chair and press the horn button twice within 10 seconds of turning it on. This should unlock it for you. Hope this helps
Jan 23, 2011 | Electric Mobility 24 " Seat Merits Heavy...
WHY IS MY CONTOLLER FLASHING ? My power chair
Here is a link with descriptions of the flashing controller lights for most power wheel chair controllers. This will allow you a fast diagnosis to save time and money on your repair; it may be as simple as a brake reset instead of a costly motor replacement! The first page you will see is especially for Hoverounds, but you might be able to find other brands if you know the manufacturer of the controller.
http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Dec 22, 2010 | Invacare P9000 Xdt Motorized Wheelchair
I have an 11 month old jazzy 1170xl. part of the time when you push the power button you get 2 flashing red lights. if you keep resetting it with the reset button, it will eventually power up and work fine...
You can visit this website to find answers on what the flashing trouble indicator lights mean: http://www.pgdt.com/scenter/diagnostics/diagvsi.html
Locate the page that has the controller used on your power chair/scooter and count how many lights are flashing to diagnose the trouble.
If the Jazzy is pulling to one side, it may indicate that there is a bad fuse or motor and the blinking lights are trying to alert you to this.
If your insurance purchased the power chair for you, they may also cover the repairs and have a DME (Durable Medical Equpment) company to refer you to for service if the Scooter Store is not helpful; contact them for information.
Dec 11, 2010 | Health & Beauty
Jazzy select contol panel all leds flash 9 times, pause and then repeat. I have checked the free wheel mode levers on both sides several times and they are definetly not in free wheel mode
Bob on each brake at the motor there is a micro switch that the controller gets connection info as to wether or not the chair is in freewheel. I have seen these switches break and therefore the controller thinks the chair is in freewheel. you could also have a bad brake solenoid that is not activating the brake when you try to move. I think the micro might be the problem because you say it flashes 9 times as soon as you turn it on. You can get just the brake assembly from Pride instead of buying the whole motor/gearbox assembly. You didn't say if you bought the chair or Medicare. If Medicare did then they will pay for most of the repair you can contact your provider or a repair service Repair Xpress @1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Sep 13, 2010 | Pride Jazzy Select 6 Indoor Power...
Someone gave us a Jet 7 Power chair and we've replaced the batteries and the fuse. I've checked all connections and everything seems ok. but I'm missing something because I'm still getting 2 flashing red...
Assuming it is a P&G controller (it'll say PG Drives technology on the bottom of the joystick), two flashing lights is a left motor disconnect fault. Check the wiring from and to the left motor for tight connections at all junctions. Unplug and replug them, don't just wiggle test them. This should clear the fault.
Oct 17, 2009 | Pride Mobility Products New Pride Mobility...
Ctm HS-2800 Power Wheelchair Logo
94 people viewed this question
Top Ctm Health & Beauty Experts
wcdoc1953
wcdoc1953
Jeff Tilburn
Jeff Tilburn
Oloyede Monsuru
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
