Bush washing machine wm-1460tv error 1 error 1 came up then worked now on timer say 0:01 and can't use as it thinks its still on a wash.
SOURCE: LG WM-1280 DD front loading washing machine
Be sure the unit is level, not just stable,with the four feet touching the floor. If the unit is not level the centrifugal force of the spin cycle will be distributed unevenly, causing more pressure to be exerted in one corner then the other. this causes the unit to slighty lift in the opposite corner, thus shaking or vibrating. Many people citing this problem have their washers in an upstairs laundry room. Some of these houses may lack the needed support to sustain these washers without the floor flexing. the quality of the building is a factor.
Posted on Nov 30, 2006
SOURCE: fault code 01
this is actually a fault code error code 1 not one minute check your manual as codes different on some machines from memory i think 1 is a filling fault this machine uses fuzzy logic if water fill takes longer than 4 mins (low pressure) machine stops can be restarted by pressing start button.
see if machine will complete just a rinse cycle.
good luck
Posted on Jan 18, 2008
  • 228 Answers
SOURCE: Hi, we have a Classixx 1200. It will not switch
YOU WILL NEED A NEW HEATER NOT EXPENSIVE QUITE EASY TO CHANGE
Posted on Sep 10, 2009
SOURCE: LG wash machine # wm 2277 hb front loader display flashes LE wont
We had the OE message come up and did the above procedures...that didn't fix it. I removed the dual pump modules (they come off in one piece...one is the recirculating pump, the other is the drain pump). Turns out, the drain pump impeller design sucks. Even though it turned when I put power to the pump, that doesn't mean your pump isn't bad. Once it is under load pumping water, the impeller can slip where the pin connects to it from the motor. We replaced the motor for $60 and that fixed the problem. Our unit is at least three years old and we have a family of four, so it does get used quite often. Nobody told us about the filter at the bottom of the unit and I figure if we knew this ahead of time, we probably could have avoided the impeller issue...but it is still a sub-par designed motor/impeller. The new one I ordered looks like an updated design so I don't see this happening again. It is quite easy to remove and replace the pump, btw.
Posted on Feb 21, 2010
ginko
  • 19396 Answers
SOURCE: what does error 5 mean
Hi.
Error 5 means that there is a water inlet problem.
Move the appliance, ensure that the water hose is not kinked or blocked, and check filter in water hose if installed.
Check connected faucet and water pressure.
If the inlet hose and pressure is OK, then the inlet valve and water pressure switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Posted on Oct 29, 2010
Bush WM-1260TVEME wash on a cotton wash when i heard noises that sounded like a firework been lit i turned round and orange sparks were coming out of top of display panel.i havent used it since this as...
first unplug the machine if you haven't already-if your machine is less than a year old you should be under warranty-call the company that you bought it from-cheers Denny
Oct 22, 2013 | Washing Machines
Cant get Bush WM-1260TVEME washing machine to start a cycle off the button
Check to see if the power is getting to the machine. If it ismake sure the door is closed firmly, there is a safety switch on the door. If none of these things work, you have adoor switch problem or a panel fuse out or a broken panel circuit. If you have the skills to open and troubleshoot than those are the things to look for.
Jan 02, 2013 | Washing Machines
I BROUGHT A BUSH WASHING MACHINE WM-1470TVE HAD IT 2 DAYS AND KEEPS COMING UP WITH Err5
Hi.
Err 5 is water inlet problem.
If the inlet hose and pressure is OK, then the inlet valve and water level switch must be tested as one of the two parts is likely giving the error.
Regards.
Ginko.
Oct 29, 2010 | Washing Machines
What does error 5 mean on the bush wm-1260tve washing machine?
Hi.
Regards.
Ginko.
Sep 20, 2010 | Washing Machines
My WM 2455 HW washer won't start washing. It
my washing machine will not turn on. it has power but will not turn on
May 07, 2010 | LG Washing Machines
Washing Machines Logo
332 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
