Question about Zanussi Washing Machines
My washing machine is not spinning can someone plz help
  • Zanussi Master
  • 1,527 Answers
Hello check the pump first it has to pump water out before it spins if the pump is ok check the module board this control the motor speed if this ok the brushes on the motor can cause the motor not to spin hope it helps
regards
shaun
Posted on Mar 20, 2011
Washing machine wont spin
if its belt driven the belt could have come off or snapped hope this helps. if possible state machine make and model then someone should be able to help you more
Oct 09, 2016 | Washing Machines
I have a nec nw-691, when you put it on spin cycle it brings error message --lid open??? plz help
Yuo might try making sure it is still level but I'd just try using a lower spin speed. How have to use "gentle spin" when I wash towels or my washing machine has errors and stops. If still too damp just use a gentle spin only cycle once more to finish the job.
Apr 16, 2015 | Washing Machines
My haier washing machine with error code E3,what 's the problem?
Can you help me to fix my haire plz it not spin
Nov 11, 2011 | Washing Machines
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
The drain is plugged...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
Fisher & Paykel Smart Drive 7.5 washing machine.
Unplug the machine have someone tilt the machine back and look under the machine for a little fan on a motor give it a turn to see if it spins it might just be sticky or it may need replacing.
Jan 07, 2010 | Fisher Paykel Eco IWL16
Washer filling not turnin when on wash turns when goes onto spin
it is either the belt is bad or the gearbox is bad look under it from the back side and check the belt
Jan 06, 2009 | Hoover Washing Machines
It is unlikely to be the motor faulty, if it will wash but not spin, check the pump filter first to be on the safe side, if that does not solve the prob, then remove motor and check carbon brushes in motor, as this can often be the cause of the prob.
Also check the water level switch pressure chamber for a possible partial blockage, as this can give the same sympyoms.
Plz rate my solution.
Thanks
Jan 02, 2009 | Washing Machines
Washine machine won't turn last spin.
If it has a Start-Reset button, try pressing and holding for 3 seconds..
Select a drain and spin prog and try again
Plz rate my suggestion.
Thanks.
Dec 26, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WM 62
Hi, Does the drum turn during the wash cycle? When it comes to the spin cycle does it go through to the end without the drum turning? It sounds like it could be the motor needs new carbon brushes. Regards, Tom.
Apr 03, 2007 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
