Question about Canon PIXMA MX310 All-In-One Printer
I am having trouble loading paper into the pinter the printer is saying e4 on paper
  • Canon Master
  • 2,517 Answers
Hi there maximum time we found it is a the head problem. The print head is what the cartridges sit in inside of the printer. For resolve the problem please follow these.
Open the printer and wait for the carriage to slide over. Some how if its not come then Unplug the printer & Manually slide the carriage. Now Remove the ink cartridges from the print head & Use wet warm cotton swab or use alcohol to thoroughly clean the print head. Repeat this until there is no ink residue coming off on the cotton swab. After finished it make the head dry then fix it back. Now Try to print something now If that does not work then follow the next step.
Remove the printer data cable & restart the PC & printer. Then fit back the data cable & turn on the printer. Hope that's start working , if no luck then Uninstall the printer driver & restart the PC & Printer both again. Now install the driver of the printer and connect it with PC ,Turn on printer & go for a test print from the printer preference. Thanks & waiting for your reply.
Posted on Mar 20, 2011
My hp2050 pinter won't print itjust shooting blank pages. i dont understand why!
Have you checked that the printer is selected and ticked as being the default printer - also check that all the correct trays are opened and ready for use - some machines give a choice of top loading paper or front loading - paper needs to be in the selected tray in this case
Nov 04, 2012 | HP Deskjet 2050 All-in-One Printer
I am having trouble trying to print card stock paper
110lbs?
that may be too heavy, try a few first then check if the printer will initiate printing.
Jun 26, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error E4
E4= paper jam. Check all your feed areas and make sure they are clear. Then reset your printer and begin you print again. If all areas are clear and your still getting an E4 reading you may have damaged a sensor clearing a previous paper jam. If a reset wont clear your error then your printer may need to be repaired. It would probably be cheaper to simply replace your old printer for a new one. Hope this helps Shannon
Mar 07, 2012 | Canon PIXMA MP150 All-In-One InkJet...
Pinter iP2600 says I have a paper jam and wont feed paper. I see no paper jam but paper wont feed.
perhaps if you got a paper when you try to remove jammed paper to a piece of paper rupr remained on paper route, and have seen where, if paper was not broken when it is possible that when you pulled a paper to be skipped sensor that never returns to the starting position
Apr 12, 2011 | Canon Office Equipment & Supplies
Paper jam on kodak pinter but no paper is in pinter and keeps saying paper jam
make sure to fan all sheets several times before loading, both from the 8.5" side, and also the 11" side. fixed my problem. hope it will fix yours
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Pinter tray is showing as empty when full.
Hi
I had the same problem, what you need to do is ruffle up the paper abit dont put it in so neat , for some reason the sensors are notrecongnising the paper (dont know why) i have used the same before...
good luck
Abdullah
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
My pinter says paper jam I have have taken the back portion off and then looked thru the paper window with door open as best I can as best the wheels turn but when it start s to print I cam hear it...
The noise of the printer is not related with the software of your computer. If it says out of paper then you will try to clean the rollers of the printer. If it is still saying out of paper and have a weird noise then the printer is already defective.
Aug 14, 2008 | HP Office Equipment & Supplies
Printer
Have you tried switching your printer to load from the back feeder using the feed switch button?
Oct 30, 2007 | Canon PIXMA MP510 All-In-One InkJet...
Canon PIXMA MX310 All-In-One Printer Logo
old marine
old marine
