I have a Huke wall mounted aircondotioner after you turn it on it cools for about 10mins switches off and shows a EL error message
Check the compressor and see if it is working. If it is working then change the capacitor. This should help with the error code EL. The huke aircon should work properly unless the gas is low.
Posted on Jan 03, 2012
  • wiseman
    wiseman Feb 16, 2015
    I have refilled the gas and changed capacitor but still reflects code error EL
Hp laserjet 3055 has error message on copying "50 fuser error, turn off then on". Restarting brings on the same message when copying.
The all-in-one has experienced an internal hardware error.
1. Turn off the power by using the power switch, and then wait at least 30 seconds.
2. If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket.
3. Check the cabling connections to the heating element.
4. Turn on the power and wait for the all-inone to initialize.
5. If, the error persists, replace the fuser.
NOTE The device power mustremain off for at least 20 minutes forthe fuser to cool down and correctly reset.
Turn off the power switch, wait at least 20 minutes, and then use the power switch to turn on the all-in-one and wait for it to initialize.
Aug 23, 2011 | HP LaserJet 3055 All-In-One Printer
When scanning or copying from hp laserjet 1522NF error message show 52 errors then turn off
52 error is a scanner error.
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the product to initialize.
If a surge protector is being used, remove it. Plug the product directly into the wall socket. Use the power switch to turn the product on.
If the error persists, contact HP. For contact information, see www.hp.com/support/ljm1522 or the support flyer that came in the product box.
Jun 16, 2011 | HP LaserJet M1522nf Multifunction Printer...
TENGO UN ERROR F2-04 EN SHARP AR257 YA CAMBIE EL CHIP Y NADA QUE ME FALTA POR HACER?
The reason for the error code is of course due to an incorrect toner cartridge being used on the copier. You can turn the copier off, but it will not flush from memory. in order to correct the issue perform the following:
1. Turn the printer off
2. Remove the incorrect toner cartridge
2. Unplug the power cable from the wall outlet.
4. Plug the Printer back on
5 Turn the printer back on
You will see the message change to another message requesting to insert the toner cartridge.
Feb 19, 2011 | Sharp AR-207 Copier
E3 ERROR COMING IN HUKE MINI SPLIT A/C
E3 Outdoor activation of high pressure switch. Due to over charged gas/condenser block/less rpm fan motor.
If overcharged release the over charged gas./clean condenser/replace fan capacitor.
Dec 19, 2010 | Heating & Cooling
I am not able to print it shows "52 scanner error restart printer
From HP Support:
Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the all-in-one to initialize.
If a surge protector is being used, remove it. Plug the all-in-one directly into the wall socket. Use the power switch to turn the all-in-one on.
If the error persists, contact HP Customer Care.
Hope this helps.
Jul 29, 2009 | HP LaserJet 3055 All-In-One Printer
When I turn on my HP designjet T 1100 I get error message 08:11
turn off printer, disconect hdd from pcb, turn on then printer beeps, turn off mount hdd back, turno whait ;).
Mar 19, 2009 | HP Designjet T1100ps Printer
1 red lights shows on screen error E68
Maybe you dont't keep ot in a good cooling area. The same thing happened to me. Do this:
Take out your hard drive and let it cool for 5 mins.
Dissconnet all the cables including the controlers.
When your done dissconnet the power cord.
After this is done let the xbox cool for 5-10mins.
Reconnect everything except the hard drive then see if it works. When the xbox is back to normal it is safe to put the hard drive back.
Jul 20, 2008 | Video Game Consoles & Games
Heating & Cooling Logo
131 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
