Question about Vivitar Cameras
How do I get my pictures on my SD card to show up on my camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Posted on Mar 20, 2011
When i remove the sd card to upload photos to my computer my new pictures are not there but are when the sd card is in the camera?
There are two possibilities that I can think of. 1) The SD card is full. You will need to copy the pictures off the SD card and onto your computer, then format the card. You can probably do this in the camera, but MAKE SURE you have copied the pictures you want to your computer because the format will erase everything. 2) The SD card is write protected. Look closely at the SD card there is a little slide switch that "locks" the SD card so that your camera cannot put any pictures on it. This slide switch must be in the unlocked position (or NOT locked).
Hope this helps.
Feb 02, 2013 | Fujifilm FinePix S4250 Black 14MP Digital...
IPICS ON SD CARD DO NOT SHOW ON PLAYBACK OLYMPUS 8010
Many cameras will only display pictures taken by that camera (or at least the same model). Also, if a picture has been edited in any way (opening a pic in a photo editor and saving it without making any changes counts as editing) then the camera will not display it.
Feb 21, 2012 | Olympus Stylus Stylus Tough 8010 / mju...
My camera won't show any pictures from my SD card
You have to change the 'storage' to 'memory card' or 'external card' from 'internal memory' or 'camera' using the camera menu.
Dec 10, 2011 | VistaQuest VQ-5115 Digital Camera
Need help with moving pictures from internal Kodak Z740 to SD card
Hi.
You will need to use a computer, there is no option for direct transfer from internal memory to SD card.
Remove the SD card from inside the camera and connect the camera to the computer using an USB cable. With no SD card the computer will show the pictures stored in camera's internal memory. Copy the pictures in the internal memory in computer hard disk, then eventually move them onto the SD card.
Regards.
Ginko
Jul 18, 2011 | Pentax Optio S Digital Camera
How do i unlock my memory card its not allowing me to take photos.
I am assuming that your camera uses and SD card to store the pictures.
If you remove the memory card from the camera, you should see a little slider on the side of the card that says "lock," it is easy to accidentally lock SD cards.
I have attached a picture to show you what a locked SD card looks like.\:codyrt.jpg
Here is another image showing the card in the unlocked position: codyrt_0.jpg
Mar 01, 2011 | Cameras
SD CARD DOES NOT SHOW PICTURES ALREADY ON IT IN FUJI Z35
Your previous camera wasn't another Z35, was it? Most cameras will not display pictures that were taken with another camera. The old pictures are most likely still on the card. You can plug the card into a card reader and transfer them to a computer.
Mar 14, 2010 | Fujitsu Cameras
Just put a new memory card in the camera but the screen keeps showing internal memory is full
How to switch the camera over to saving pictures directly onto the SD card.
    1. Menu
    2. Cam settings
    3. Chose AUTO or SD card option and Press OK
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you still experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
    After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    Upload images to SD card
    I just purchased a frame and wondered the same thing. My computer has a slot for an SD card once inserted the computer shows the SD file. Then go into where you store the pictures highlight the picture one at a time in the picture file my program says copy to file click on it and shows the SD file as F file click copyit then downloads to the card. Done put SD card in frame worked perfectly.
    Dec 18, 2007 | Nikon Coolpix 3200 Digital Camera
    Cameras Logo
    16 people viewed this question
    Top Vivitar Cameras Experts
    SHARCNET-USA
    SHARCNET-USA
    James Woodgreaves
    James Woodgreaves
    Are you a Vivitar Camera Expert? Answer questions, earn points and help others
