Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Hi I have a wd640 hotpoint aquarius washer/dryer that has stopped working and been told by a fixya pro that it was the main circuit board,and so ordered this assuming it was the circuit board behind the controls/dial/readout but what turned up was a smaller circuit board in a glass case called a service key and i am assuming this is wrong. Can someone tell me what/where the main circuit board is,have I got it all wrong thanks Bruce
  • bruce Mar 20, 2011
    Hi do you mean the fuse in the plug as this is ok there is power getting into machine just nothing works
  • bruce Mar 21, 2011
    Hi the machine just died one day as if the fuse in the plug had blown but this tested ok and there seems to be power getting to the machine but no lights noise or anything and I have been told it's the mother board and assume this is the board at the top of the machine behind the dial/buttons etc but not sure? thanks Bruce
  • Hotpoint Master
  • 1,527 Answers
Hello there is usually a power board sits at the bottom if the machine is dead there a glass fuse that blows just replace the fuse make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Posted on Mar 20, 2011
  • 1 more comment
  • shaun taylor Mar 20, 2011
    hello that small board in the glass case could be the module board the controls the motor speed
    shaun
    hello that could be the module board this controls the motor speed if theres a humming sound then the brushes on the motor could be the cause these are made of carbon wear down can stop the motor from working
    regards
    shaun
  • shaun taylor Mar 21, 2011
    yes your right the main board is behind the display but it sound like power board fault
I need to a manual for hotpoint aquarius WDL520 washer dryer
you can download the instruction manual from here.
Hope this helps, thanks for using fixya.
Nov 08, 2011 | Hotpoint Aquarius WD640 Front Load...
I need to find a manual for hotpoint aquarius WDLS20
You can download the manual from here.
hope this helps, thanks for using fixya.
Hotpoint aquarius wd640 washer/dryer instructions
  • You can get a manual for your machine at this site
  • www.manual.pronto.com.
  • they carry manuals for many make and models so they should have what you need. If it turns out that they for some reason do not have it try this site :
  • www.webcrawler.com
  • These sites will help you with what you need. Thank you for choosing Fixya and have a great day...Good Luck
Oct 13, 2010 | Hotpoint Aquarius WD640 Front Load...
F13 error during drying cycle
Hi, that indicates that either the fan motor is not working/ blocked or the dryer thermistor (thermostatic sensor) is playing up. Of course, the pcb reads the sensor so it could also be that causing the error.
May 06, 2009 | Hotpoint Aquarius WD640 Front Load...
Error code f-01 on hotpoint washer dryer aquarius model wd 640
f-01 means there is a motor problem.
may be the motor and/or the circuit board that controls it.
Jan 05, 2009 | Hotpoint Aquarius WD640 Front Load...
I have a hotpoint wd640 and i cant get it out of test mode any ideas?
trn main dial to empty drum icon
press start/cancel button and on/off button together then switch off at mains and leave for 10 mins
got this info off hotpoint themselves and it works for me
Jan 02, 2009 | Hotpoint Aquarius WD640 Front Load...
Hotpoint wd640 replacement motor brushes
machine has brushes but they usually last longer than 2 years (mine are still ok after 5 years.
if you get no drum rotation, then suspect the brushes and replace them if necessary
Jun 21, 2008 | Hotpoint Aquarius WD640 Front Load...
Wd640 hotpoint washer dryer - error code F03
This indicates that the wash thermistor is "Open Circuit" and I think it is situated on the heater assy at the back of the machine.
Check the wiring and contacts between the thermistor and the PCB. If you still get the fault it could be the Thermistor ( which means replacing the heater ) or a faulty board.
If it is under 5 years old - Call Hotpoint as you have a 5 years Parts Guarantee mind you the call out is £89.98 but thats cheap if it happens to be the board!
Mar 14, 2008 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
