Question about Toshiba 36A60 36" TV
My 2001 Toshiba TV will at times work fine. Other times the screen goes black. When it goes black after repeated times of unplugging/plugging it from the wall (no obvious process makes it work - it seems random) it will then start working fine as long as I keep it turned on. When the TV is in it's "Black Mode" I can't even get the OSD to display. When it's been "warm and working" I can turn it in and off at will and it performs properly. Starting cold, I have go through repeated plug/unplug cycles to make it work again. Interestingly, when the TV is working well, the power indicator light stays on without blinking. When the TV isn't working, the indicator light flashes. Any ideas?
  • Toshiba Master
  • 5,138 Answers
These Sets are well known for Poor Solder Connections pull out chassis and resolder the Board and this should fix the problem.
Posted on Mar 20, 2011
Standby light flashes 4 times
One option to try is to try to factory reset the tv, to do this turn the tv on hold the Down Arrow on the remote and while doing this press the power button then release the down arrow button.
Bit of info on your issue
* Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
Trend to find everything
Oct 04, 2014 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Onkyo HDMI + 42 " LG TV = black screen but both work fine with other inputs/ outputs
If using a box disconnect it and the set from power for a few minutes and try again.
Next I would remove connections one at a time with set off and try to see if one is creating this issue. HDMI does not like to be connected when a unit is on or power connected to it.
Dec 23, 2012 | Televison & Video
Toshiba 32C100U popping sound no picture
Might be worth the effort to open it and have a look for loose plugs or a ribbon cable somewhere--if do look for any plugs that are held down with tape near where they plug in.
Jun 14, 2012 | Toshiba 32C100U 32 in. TV
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Color gets blotchy, then goes screen goes black
The issue is with the color wheel but you have to replace the engine inorder to get one. The cost would exceed the value.
Jan 08, 2009 | Toshiba 46HM95 46" HDTV
Toshiba Regza screen is black but audio works
I unplugged everything and then reset-up the tv, dvd player, audio, and other components.
Dec 29, 2008 | Televison & Video
Picture goes black
GO TO MENU, THEN SETUP, SCROLL DOWN TO TIMER AND MAKE SURE IT IS ON 0 (ZERO) MIN. SOUNDS LIKE ITS PROGRAMMED TO GO SLEEPAFTER A CERTAIN TIME. THIS TV ALSO CUTS OFF AUTOMATICALLY IN 15 MIN. IF ITS TUNED TO A VACANT CHANNEL( NO PICTURE).
Jun 18, 2008 | Toshiba 36AF42 36" TV
Black screen
my sony kp-61hs30 displays that there is no siginal, also the red indicator light blinks when the power is turned on but goes out i have dirct cable pluged into the set and up until about a week ago it worked fine.All of the other tv's in my home work fine so i don't understand what the problem is . I have a dvd player connected to the set and it works great for viewing dvd's please assist with me with some trouble shooting points
Jan 24, 2008 | Sony KP-61HS30 TV
Screen goes black and turns off
sounds like something is over heating.
i would check convergence ic
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sep 28, 2007 | Panasonic PT-47WXC43 47" Rear Projection...
Toshiba 36A60 36" TV Logo
47 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
