Question about Dimplex Heating & Cooling
Can I buy chrome replacements for a Dimplex HTN20 fire.
    Brigadier General:
  • 4,736 Answers
If they can be purchased as replacement parts, Dimplex USA, Customer Service is the place to start. Call 800-668-6663 - Monday - Friday 8:00am to 4:30pm ET.
Posted on Mar 20, 2011
How do i replace the on/off switch on dimplex fire? Model Number MON20R
https://www.manualslib.com/manual/762887/Dimplex-Rec20r.html&ved=0ahUKEwjmgaXO4rjTAhUJzoMKHVkpAfoQFgghMAM&usg=AFQjCNHqq7ZBbHJC6PuRMVx_G3BQsFOJ5g&sig2=EqzuIoMZYeySCbFSE_BHRQ
Apr 22, 2017 | Dimplex Heating & Cooling
Hi, can any one give me procedure for replacing one of the front panel rocker type switches on a Dimplex Horton HTN20 (OLDER TYPE) electric fire.
switches in any electrical circuit only do one thing--either allow the 'juice' to flow, or to interupt/stop it. Having never seen the item in question, I need to know how many wires are on this switch. If it is a SPST (single pole, single throw) there will be TWO wires--one will be the feed, the other the carrier to take the juice somewhere else when the switch is thrown (closed.) More complicated switches can have multiple connections (more than two wires) which allows various paths for the juice to flow. It's pretty rare to find a replacement switch that is an exact match for the one that is 'bad', but if you have a Dremel tool, you can always modify the opening to make something else fit. The hardware stores sell a moldable putty that hardens like epoxy, to glue a smaller switch into a 'too big' hole.
Nov 23, 2014 | Cars & Trucks
Need replacement grille for Dimplex floor drop-in heater FFIH15A31
Get the dimensions of grille and contact dimplex, or plumbing & heating supply store for new grille.
Apr 15, 2014 | Dimplex FFIH15A31 Electric Heater
Fire wont mist ad keeps turning its self off 3rd time lucky at posting this as not a car or truck and it keeps coming up under cars or trucks
You can call Dimplex directly for Tech Support:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Feb 07, 2013 | Dimplex Compact Electric Flame Stove...
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
1-888-346-7539
Monday - Friday
Nov 28, 2012 | Dimplex DS4411 Electric Heater
Htn20 how do I change the light bulbs
It's not difficult to do on your Model Electric Stove/Heater. However, if you have a drawing to look at, it makes it easier. So, in case you have misplaced your Owners Service Manual go to the link below and your can download and print it for future reference.
http://partner.dimplex.com/files/domain4103/7207400100r05_EN.pdf
Hope this helps you solve your problem.
Feb 17, 2011 | Dimplex CS3311 Compact Heater
Where can a fuer dbg 2-5w 230v ac 50hz 15rpm motor which operates the flame effect on my dimplex fire be purchased
You can buy it directly from the Dimplex USA website. Make sure you have your Model Number handy.
Feb 16, 2011 | Dimplex Compact Electric Flame Stove...
How to replace fire bulb for Dimplex HTN20
I wanted an answer to this too. It was hard to find, but here we go.
Get hold of a torch, and look closely at the decorative surround at the bottom of the fire. There are two screws hidden in there, on each side! See below:
Unscrew these, and you can take the front off, and get at the bulbs.
For information, the fire takes two screw in bulbs, described as 240V – 60W E14 SES Clear Candle Lamps.
Hope this helps.
Feb 07, 2009 | Dimplex DS5598 Mid-Size Heater
Heating & Cooling Logo
128 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
