Question about Maytag Refrigerators
Refrigerater not staying cold and coil is frozen. condenser and fan are working freezer ice machine not working
  • 518 Answers
The tube between the freezer and fridge is also likely to be frozen up. You need to unplug the unit for a day and let it thaw out. When you plug it back in, start with a low to med setting on the temp.
Posted on Aug 02, 2008
Freezer not getting cold and dripping water
I own a similar Kitchen Aid fridge that had a defrost icing issue: Kitchen Aid KSRP25FNBL00
> Ice had plugged the drain hole at bottom of chill coil section inside the freezer compartment.
> I learned that the coil, circulation fan was not working, but condenser was working.
> I paid a tech to replace the circ fan, about $200, including a new swiss-made fan. He said it was unusual for these fans to fail, but not unheard of.
Expensive, but saved the purchase of a new fridge. Has worked great for 6 months since then.
HOpe that helps.
Al Zayha
Mar 09, 2014 | KitchenAid (KSRD22FKST) Side by Side...
I have 2 door refrigerater one side is cool but frozen is not make the ice or cool on that part
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
Apr 16, 2011 | Samsung Refrigerators
My fridge light and digital readings turn on and off and the fridge doesn't stay all that cold. My freezer light is always on but the food is not staying frozen. The ice maker isn't making ice.
The first thing I would do is to check the compressor and the condenser fan. Remove the cover on the back of the fridge and check how hot is the compressor? Is the condenser fan turning well? Also check the condenser coil under the fridge, it is very possible it needs cleaning.
If the condenser fan is not working properly then it has to be replaced.
If the condenser fan motor is fine and the cleaning did not help then the sealed system is low on Freon and in such case you need a certified technician to fix a leak and to charge the system.
Good luck.
Jul 28, 2010 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
My refrigerator isn't cold, but my freezer still works.
Put your unit on a 24 hr defrost the freezer coil is frozen and blocked with ice the fan cannot draw any chill from the freezer section.
May 17, 2010 | Maytag MFD2560HES Bottom Freezer French...
Maytag refrigerator isn't cold.
if freezer is working and ice mker is working . and fan / then only other is the damper in top center is not working . very common . mm
Apr 18, 2010 | Maytag MFD2560HES Bottom Freezer French...
Freezer light blinking Ice maker not making ice freezer not as cold
sounds like ur freezer is in alarm due to not being cold enough and wont allow the ice maker to distribute water to be frozen into ice u should have a fan behind the back panel inside the freezer make sure it is working and the coil underneath it is not frozen solid if the fan isnt working then check and make sure it has power if it does and the fans not running then replace the fan and this should get ur freezer working again but if the coil is frozen and the fan is running then u may have a bad defrost element that runs through the coil it is black u can test it by taking the wires off it and checking continuity thru it if it has continuity then its ok if not then it needs replacing
Mar 01, 2010 | Samsung RS2534 Side by Side Refrigerator
Doesnt get cold??
Defective compressor, refrigerant low from a leak in the system, dirty condenser coils, condenser fan not working, bad compressor relay or capacitor, main thermostat control not working, thermostat needs to be set at proper setting, frozen evaporator coils do to faulty defrost timer, defrost heater coil broken, or the defrost determination thermostat has stayed in the open position, which would result in no defrost and the ice blockage would stop air the circulation, defective evaporator fan, defective door switch which controls the evaporator fan when one opens and closes the freezer door. Freezer drain clogged which would possibly cause the fan to be stuck because of ice built up around it.
Oct 13, 2009 | LG LFX25971ST Bottom Freezer French Door...
Freezer works fine but the fridge won't get cold
It sounds like cold air from the freezer isn't making it to the fridge compartment. This can be cause by a several things. The damper that lets air into the fresh food side is stuck in "closed" position, the temp sensor (t-stat) isn't working properly, the evaporator fan (in the freezer comp above the coils) isn't working to blow air up to the fresh food section. In some situations, the defrost cycle for the freezer section isn't working and the coils have frozen into a block of ice and air can't flow over them properly so you get not cold air to the fresh food section but the freezer still stays cold due to the block of ice.
Feb 21, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerator won't get cold
You likely have a defrost cycle failure. The freezer's cooling coils need to be frosty and cold so the air that the fan pulls over them can cool the fridge section. If the defrost cycle fails, the coils freeze up to a block of ice and air flow suffers (fridge is about 55 degrees F). The freezer stays cold only because there's a block of ice in there now... sometimes that cold "sinks" to the bottom and only the food at the bottom stays frozen (and can even freeze food at the bottom of the fridge compartment while the rest is warm). To be sure, you'll need to take the rear interior panel off the freezer back wall and check the coils to see if they are frozen solid. If they are then there's a defrost cycle failure. If they are showing a nice white frosty pattern evenly all over the coils then that's normal and maybe the evap fan (right above the coils) is not blowing air up properly or is not working at all. That fan should run if the compressor is running, etc. the only time it doesn't run is during an actual defrost cycle. Once you find out what condition the coils are in it should be simple to direct you further on the problem.
Jan 05, 2007 | Maytag 22.6 cu. ft. Side-By-Side...
Refrigerators Logo
77 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
