Question about AEG Dishwashers
Aeg dishwasher detergent door won't open - AEG Dishwashers
  • AEG Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Mar 20, 2011
Door of detergent holder on Bosch dishwasher won't shut. It just pops open. Is there an easy fix?
Proceed with this step:
Timer
check the timer, and the linkage see it is defective.
Bi-metal switch or wax motor
test the swithc or the motor for defective.
Detergent cup, itself
can be clogged, for to open.
sincerely. God bless you.
May 07, 2012 | Bosch Dishwashers
Initially the soap dish had residual detergent (cascade packets) but now the detergent door won't open during cycle
probably needs a new spring. you can order a whole new door with spring easier, just search google for appliance parts
Jan 26, 2012 | Jenn-Air Dishwashers
The detergent tablet does not fall free of the dispenser, end uo with a soggy mess still in dispebnser and dishes not properly washed. Have checked clearances between dispenser and top tray. No visible...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
heatman101
Dec 27, 2010 | AEG 24 in. Favorit 40850 Free-standing...
Where do you put the dish wash detergent for my dish washer!
Hi, for most dishwashers the detergent cup is behind a little door in the door of the dishwasher.. snap open the door and place the detergent in the cup while the door is open and down, then close the little door and then close the dishwasher door...
then you are ready to roll...
DishwasherRepair Problem Detergent Cup does not Open
heatman101
Sep 19, 2010 | Dishwashers
Soap dispensor door won,t open
Checkout this tip that I wrote about that problem...
http://www.fixya.com/support/r4225828-dishwasher_repair_problem_detergent_cup
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Jun 12, 2010 | Dishwashers
AEG Favorit fails to release detergent most of the time, but not always. Any thoughts?
There is either food debris blocking the action of the dispenser lid, or the solenoid which releases the door is sometimes failing to operate. The latter fault can be due to either a faulty solenoid or a loose/damaged cable connection anywhere between the main board and the solenoid: bear in mind that every time the door opens and closes there's a flexible connector which gradually fatigues and there are electrical connections which can be loosened if the door is regularly allowed to slam shut.
It's not really a DIY fix unless you are a competent and experienced home appliance repairer, but you can check for any food debris around the dispenser lid. If in any doubt run the machine empty using dishwasher cleaner. The possible electrical faults I've mentioned aren't necessarily expensive in terms of parts, but the labour will typically be about one hour.
An alternative is to use the new detergent dispenser from Finish. This sits in your machine, preloaded with twelve doses of detergent which are automatically released with every wash. It's an expensive way to buy dishwasher detergent, but it's a quick and relatively cheap fix which may buy you time until you can afford a proper repair.
If you do think that you may be able to diagnose and repair the fault on a DIY basis then I highly recommend the Haynes Dishwasher Repair Manual which you can either buy or perhaps borrow from a public library.
I'm hope that you have found my reply to be of use, all that I ask in return is that you take a moment to rate my answer.
Feb 28, 2010 | AEG 23 in. Favorit 50750Vi Built-in...
AEG 250 operating manual
hi friend,
step 1
Remove any large food deposits from the dishes to prevent damaging the dishwasher.
  • Step 2 Load the upper rack of the dishwasher with smaller items, such as glasses, cups and cookware lids. The items must be inserted face down, with the soiled side of each item facing toward the bottom of the dishwasher. Some dishwasher models feature clips, which can be used to secure lightweight items to the tines of the upper rack. The clips work like clothesline pins, and can be moved from one tine to another.
  • Step 3 Load the lower rack of the dishwasher with heavier items, such as plates, bowls and pans. Insert the items between the tines of the rack with the soiled side of each item facing toward the center of the dishwasher.
  • Step 4 Load the silverware basket. The silverware should be inserted into the basket with some items facing up and some facing down to ensure the items do not fit together, which would prevent the dishwasher from being able to clean all surfaces. Knives should be inserted blade down, so they can be inserted and removed from the dishwasher with the handle to avoid injury.
  • Step 5 Add detergent to the dishwasher, and then close the dishwasher's door. Note that the dishwasher has two detergent sections. One dispenser, called the main wash section, has a lid. Open the main wash section's lid by pressing down on the cover latch located next to the section. Fill the main wash section with 3 tbsp. of automatic dishwasher powdered detergent, then close the lid until it snaps into place. The other detergent section is the prewash section. It does not have a lid, because the detergent within the section empties into the dishwasher when the door is closed. Fill the prewash section with 2 tbsp. of automatic dishwasher powdered detergent. Close the dishwasher's door until it clicks into place.
  • Step 6 Prime the dishwasher by turning the kitchen sink's faucet on until it produces hot water. This will ensure the dishwasher has an immediate supply of hot water.
  • Step 7 Start the dishwasher by choosing and pressing the appropriate wash-cycle button, located on the front of the dishwasher's door. Cycle selections include "POTS --N- PANS," "HEAVY" for heavily soiled items, "NORMAL" for standard washing, "CRYSTAL/CHINA" for delicate items, "LOW ENERGY" for lightly soiled items and "RINSE ONLY" for items that will not be washed immediately.
  • hope this helps u
    please rate me........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 25, 2009 | AEG Dishwashers
    Detergent door does not open, it completes cycle without using the detergent
    1. The most common problem with the detergent doors on KitchenAid dishwashers is that they either don't open during the cycle or open only halfway. Before looking into more complicated repairs, make sure that the door is able to open. Check the seal around the door and the door latch for soap- and food-related gunk, and scrub it off if present. Sometimes this can keep the detergent door from operating properly. Consider switching detergents, as some liquids and pouch-style dish detergents can gum up the detergent dispensers. Also, make sure that there is nothing blocking the detergent door when the dishwashermag-glass_10x10.gif is loaded. Because of the location of the detergent door, a large item such as a cookie sheet or a pan can prevent the door from opening. Run the dishwasher through a cycle without anything placed in front of the detergent dispenser and see if that solves the problem.
    2. Broken Timer
    3. KitchenAid dishwashersmag-glass_10x10.gif rely on an internal timer to complete the wash cycle properly. When this timer malfunctions, certain steps in the wash process (such as the release of soap from the detergent dispenser) can be interrupted. If the dishwasher detergent door is either not opening or appears to be opening late in the cycle, this is likely the mechanical culprit. A broken timer isn't something that's simple to replace without knowledge of dishwasher repair, so it's best to consult a professional if you suspect that this is the problem.
    4. Malfunctioning Door Components
    5. For the detergent door to function properly, all of its mechanical components must be in working order. Older dishwashers' detergent doors rely on a spring-loaded hinge to pop all the way open when the timer gives the signal. If the door doesn't swing all the way open instantly when it's manually released, the spring may need to be replaced for the dispenser to operate properly. If the particular model is newer and does not rely on a spring to open the door, chances are it either uses a wax motor or a bi-metal switch to release the detergent door at the appropriate time. If either of these components is dying, that can mean that the detergent dispenser will not operate properly.
    thank you
    vijay(vote for me)
    Sep 23, 2009 | Kenmore 24 in. 16539 Built-in Dishwasher
    Detergent Dispenser does not open
    I had this problem - the dispenser only opens if there are small items in the rack in front which don't come up to the same height.
    Jan 08, 2008 | AEG 23 in. Favorit 86070Vi Built-In...
    Dishwashers Logo
    267 people viewed this question
    Top AEG Dishwashers Experts
    Oloyede Monsuru
    Mike
    Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
