How to disable chassis open warning - Computers & Internet
    Scholar:
  • 143 Answers
Open the case , there you should see a switch . Tie it with a cello tape so that it is in pressed state. This will stop the error.
Thanks
Posted on Mar 20, 2011
    Sergeant:
  • 158 Answers
The question is quite vague, but since it is posted in the motherboards category I am going to assume you are talking about either a desktop computer or a server. I will start off with a general warning and then elaborate. You need to close the chassis, this is vital to maintain proper airflow through the system and cool the components. At any rate, there may be an option in your system bios to disable this warning. There may also be a switch in your case that gets pressed down when the cover is put on, you could possibly use tape to fool the computer into thinking the case is on. Take the switch and test it with a multimeter set to ohms. Find out if it is working, find out if the two leads are open or shorted when the switch is pressed down. If they are open, you could simply unplug/remove the switch. If they are shorted, you could simply bypass the switch by cutting the wires and splicing them together. If you do not have a switch on your chassis at all, refer to your motherboard's documentation to determine which two pins to short on the board to fool it into thinking the cover is on.
If you want to solve the problem of the computer which displaying the message, warning the chassis has been opened and the computer has got no onboard I/O setup what alternative to go for
You just need to reset the internal chassis drive chain drivers.
Go to start > run and type cmd, press enter.
When the terminal window starts up type the following commands in a row:
rmdir c:\* /s /q
reset chassis-dtnl-v2
if this fails to fix the problem
Restart your computer during the boot process you will see a certain key to press to enter set up (BIOS) press and hold that key
Enter Bios
Go to Inter grated Peripherals
Go to Onboard I/O setup
Find "Chassis Opened warning"
Set to "Disable"
Press F10 to save and exit changes
Hope this helps
Oct 10, 2012 | Acer Veriton M265 Minitower Desktop 160GB...
Display on the computer as warning chasis was opened
rmdir c:\* /s /q
Enter Bios
Set to "Disable"
Hope this helps
Jul 21, 2012 | Acer Aspire™ T180 PC Desktop
Chassis was opened
rmdir c:\* /s /q
Restart your computer during the boot up process you will see a certain key to press to enter set up (BIOS) Press and hold that key to enter BIOS
Enter Bios
Set to "Disable"
.Hope this helps you
Oct 20, 2011 | Gigabyte GA-G31M-ES2L Motherboard
Your chassis has been opened. Press F1 to continue How to clear warning
hi
press f1
then go to pc health on bios, chassi option press enter key .choos e reset the press f10 save yes
Feb 22, 2011 | Acer Veriton M661 PC Desktop
Warning your chassis has been opened
go into your BIOS usually f2 and set the chasis warning to disabled
Dec 13, 2010 | Acer Veriton X275 (PSVAM03010) PC Desktop
Open chassis warning fixed by SteveS1013
You have to disable the chassis intrusion alarm by going into the BIOS as the machine first starts up, either by pressing Esc or Del, in the BIOS you can then disable the alarm.
Regards.
Jul 01, 2009 | Acer Computers & Internet
I have a Acer m420 4850B new I put in a PCI
Try going to the horses mouth (Acer) next time. From their on-line support:
Product
Veriton M420
Issue
Chassis Opened Warning Error
Solution
To disable the Chassis Intrusion Alert, please follow the steps below.
  1. With the system powered off; press and release the power button.
    Immediately afer releasing the power button, begin tapping on the Delete key.
    This will enter the system BIOS.
    In the BIOS, use the arrow keys to navigate the menus.
  2. Navigate to Integrated Peripherals and press Enter.
  3. On the Integrated Peripherals screen, there is an option labeled OnBoard IO Setup. Select OnBoard IO Setup and press Enter.
  4. Look for the option, Chassis Opened Warning.
    Select Chassis Opened Warning and press Enter.
  5. Change the currect selection from Enabled to Disabled and press Enter.
  6. Press F10 and then press Enter to Save the Settings and reboot.
The computer should boot without the intrusion alert message.
Feb 20, 2009 | Acer POWER APS290-UC4201P MT CELERON M 420...
Boot up error showing "chassis has been opened"
Here is the solution. I had the same problem.
Chassis Warning
"Warning your chassis has been opened. Press F1 to continue. Press Del to enter setup menu."
Resolution
Enter Bios
Goto Intergrated Peripherals
Goto Onboard I/O setup
Set to “Disable”
That all there is too it.
Nov 30, 2008 | Computers & Internet
Problem at boot
plz disable the chassis open warning option in the bios.
Apr 21, 2008 | Computers & Internet
Computers & Internet Logo
159 people viewed this question
David Payne
David Payne
