I got a beco washer but the water does not get hot any more what is wrong
    Brigadier General:
  • 6,277 Answers
Presumably it is cold fill only?
The water heating element is either broken or there is a problem with the wiring going to it. Whichever it is, will need an engineer to fix.Sorry;-0(
John C.
Posted on Mar 20, 2011
Washer water temperature is wrong
i would guess that if you actually have hot water at the faucet it is connected to, the the inlet hot water valve is defective in the washer. seems like a lowes exchange to me.
Jul 22, 2015 | Samsung 4.5 Cu Ft Capacity White Top Load...
No hot water
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine isn't working the way it used to--or should--try these tests:
  • Is the hot water turned on? If not, turn it on.
  • Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.
  • Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace it.
  • Sep 21, 2008 | Hotpoint VBXR1090D Top Load Washer
    Why is the hot water pipe dripping after tighening up.
    First the is a hot and cold water pipe. To those are connected hot and cold water outlet bib valves to which are connected, respectively, hot and cold water hoses going to (or you could say, coming from) their respective connections to the washer. Correct this if I am wrong but, it appears you might be talking about those hose connections to the water spigots but calling them pipes, not hoses. If that is true, you contecture is correct: it is most typically a worn out hose washer or o-ring and replacing that item should correct any dripping. By sure the part is characterized for hot water.
    Oct 28, 2014 | Washing Machines
    How do I get the hot water work for my Fisher & Paykel Eco Smart washer?
    How hot is the water temp in the house that you are in? If the inlet hose to the washer is not hot, then it is not the washing machine.
    Jul 31, 2014 | Fisher Paykel EcoSmart GWL15
    Maytag performa washer hot/cold now reversed
    Try moving hot hose to the cold side and c old hose to hot side on supply side. this should correct your problem
    Feb 26, 2018 | Maytag Performa PAV2200
    Haier Genesis HLT364XXQ CAN'T GET HOT WATER WASH
    hey Paul, you don't have to wash anything in hot water. Hot water only wastes money and does nothing, in my opinion, to get anything cleaner. It does ,however set the stains. To kill any thing the water has to be 212 degrees [ boiling ]I have not used hot water for over 40 years and our clothes are coming out clean. Just set the machine on cold. I put a twoway spigot on my cold tap and put the hot water and cold water together incase someone breaks in and does my laundry. Barry
    Feb 14, 2009 | Haier HLT364XXQ
    Warm water temp Maytag PAV1000aww washer
    Perhaps you need to simply open the hot and cold water faucets all the way.
    Jan 05, 2009 | Maytag PAV2300 Top Load Washer
    What does efo mean
    Electrolux Washer Fault Code for EFO or EF0
    Drain Filter is Clogged. Resolution => Click lint filter for soap buildup or other debris. Check drain hose.
    Oversudsing - A high efficiency detergent was not used.
    Too much detergent was added. Resolution => Use only a high efficiency detergent. Follow manufacturer's recommendation for dosage. Amount may need to be adjusted for water temperature,
    water hardness, load size and soil level.
    Hot water doesn't enter washer - Hot water hose is connected to the wrong faucet. Hot water faucet is not turned on. Resolution => Connect hot water hose to hot water faucet and hot inlet on
    washer. Be sure hot water faucet is fully opened. Check water heater.
    Jan 03, 2009 | Crosley CW5000 Front Load Washer
    Cold/Hot water
    if this is a machine with two fill hoses, then you have them the wrong way round. to check, put on rinse and cold water should come in. if not, swap the hoses round. don't rely on what you house plumbing says is hot or cold - this is often wrong
    Aug 28, 2008 | Bosch Classixx WFC 2465 Front Load Washer
    Washing Machines Logo
    29 people viewed this question
    Top Washing Machines Experts
