Question about Refrigerators
Ive forgotten which way the dial goes...is it min or max to make the fridge cold? the freezer part is working however
  • 1,998 Answers
On any refrigerator or freezer it should be set in the middle whereas if your unit said 0-9 you would set your unit to 5 or if it just says min and max in between these would be the the best. optimum tempretures are at 37-38 in your refrigerator and 0 in your freezer if you have any further questions message me back and please remember to rank how this opinion has helped it allows for me to help others in similar situations Thanks Rick
p.s it is also best to keep two manual thermometers in both the freezer and the refrigerator at all times this way you always know your exact tempreture
Posted on Mar 20, 2011
Fridge freezer freezer not staying frozen
Clean the unit, maybe is derty, I had the same problem and I cleaned and now is working fine. had lats of dust on it. I had to remove the back cover to do mine.
May 31, 2012 | Refrigerators
Fridge freezer not working just moved in to a new house and the fridge freezer was already here but had been turned off. i have turned it on up to the max of 5 and left it over night but neither seems to...
Thanks why they left it there, but the problem is probally in the start components of the compressor. Can be fixed without to much problems. Hope this helps. Wally
Oct 09, 2011 | Refrigerators
We have a Sharp R&L Fridge/Freezer - it is freezing everything in the fridge compartment - please could you advise whether we should move the dial to Min or to Max to make it warmer inside to prevent...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Apr 05, 2011 | Sharp Refrigerators
Water shoots out of the grill at the top of the fridge compartment,as if its coming from the freezer compartment?Tried turning it off for 2 days,but after a day has started doing it again..do i need to set...
First how old is this unit? sounds like the water line from the filter to the ice maker is the problem, even if your model does not have an ice maker their is still that water line running to that area.
Feb 03, 2018 | Whirlpool GR2FHMXV Top Freezer...
Hi, I have a Bosch intelligent frost free 44 which I bought second hand a few days ago. Manufacture date appears to be 2006 and was told it works fine but I am not sure. When I first turn fridge on the...
I think it's the freezer fan that stopped working,open the freezer and see if it goes you should hear it running and even see.This fan allows the cold air into the fridge compartment,without it it takes ages for the fridge to get cold.I've got the same problem if you find the motor online let me know on alvalen31@hotmail.com
Nov 03, 2010 | Bosch Refrigerators
Hi my lower part nolonger gets cold enough to keep fresh foods yet the freezer is working well
Set dials to middle setttings, if the colder /warmer dial is peffed max cold its max cold freezer!!! so move to warmer and the freezer will give more airflow to the reefer , the reefer is reliant upon the freezer for its cold air.
Nov 01, 2010 | Magic Chef CTB1821AR Top Freezer...
Both Lights flashing and fridge not getting cold
I turned the fridge and freezer off using the circular dials, I then turned the unit off at the mains. Left it for a few minutes and then turned the power back on. I then turned the circular dials to "max" and then depressed the super cool and super freeze buttons to turn this facility on. This time they came on normally (not flashing) and no alarm sounded. The fridge and freezer then started to get cold. Once the unit had been running for several hours I then turned the dials to the 3/4 mark and depressed the super cool and super freeze buttons again to turn them off. Over night the fridge and the freezer appear to be working properly so I hope that my problem is solved. Maybe the unit just needed to "settle" before being switched on?
Sep 03, 2009 | Freezers
Bought a chescold finch 3 way fridge but no instructions - help
The max/min gas flame is for adjustment of temperature when using the fridge on gas. The next one with 0 to 7 is possibly the electrical thermostat. I am not familiar with this exact model. One of the dials will be able to be pressed in. The idea is to press and hold this button in for about a count of five, then push the lighter strike. You will hear a click noise which is when a spark is delivered to the burner area. Some fridges have a small window or guage which shows if the flame has lit. You may have to look down the chimney. You keep holding the press button down after having depressed the lighter strike button for about five seconds. This allows gas to flow to the burner while the thermocouple heats up. Once the thermocouple (which is a small copper probe sticking almost into the flame) heats up, it will keep the gas valve open and if you then release the button, the flame will continue burning. The idea is that if the flame were to blow out, the thermocouple would cool and in turn act as a safety by shutting off the gas supply. Hope this is enough info.
Mar 05, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
My LG B197WV has a problem with temp controls is min the lowest temp and max the highest temp or is max the max coldness? everything keeps freezing in the fridge and its set on 3 Help please
1 is the lowest setting. And if you want to make it really cold in your LG then turn it to the highest number. Might back off the fridge setting to 2. Do you have two t-stat's one for freezer and one for fresh food compartment?
Jan 13, 2009 | Refrigerators
Refrigerators Logo
56 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
