Question about Electrical Supplies
Just brought new generator to blow up bouncy castel but it trips out as soon as we plug fan in
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,949 Answers
Dose it pull to many amps. on start up ?/or have a short in it?
Posted on Mar 20, 2011
  • 3 more comments
  • derekh255 Mar 20, 2011
    i think it pulls too many amps its the fan is 1.5hp the generator is 6.5hp so its well big enough
  • Shane Gannon Mar 20, 2011
    no the amps for startup will be higher than the running amps and if its to high it wont start it without triping braker
    so is there any way around this?
    im afrad not other than a bigger gen...
    but there should be a amp rating on the blower motor for both running and startup
Coleman mach rv ac unit tripping breaker
If it trips the circuit breaker as soon as you turn the FAN on, suspect either a bad fan motor or a failed fan motor start capacitor. If you are able to turn the fan on but the circuit breaker trips as soon as the COMPRESSOR starts, it is possible that the compressor is seized.
If, on the other hand, the unit is tripping a GFCI (Ground Fault Circuit Interrupter) breaker or GFCI utility outlet, it is possible that neutral and hot are reversed at the outlet into which the trailer is plugged (happened to me this year at an RV park).
May 14, 2015 | Coleman Heating & Cooling
GE JVM1850CH06 MICROWAVE
the panel display is fried. you'll need to remove and replace it...this the sort of thing you enjoy doing?
May 23, 2008 | GE XL1800 1100 Watts Microwave Oven
I have just brought a older style lie Down sunbed! My thing is the bottom section works fine ! But the top one as soon as I plug in the plug it trips the switch
Some of these units use more than 10amps [2400watts at 240volts 1100watts at 110volts] AND will cause the fuse to blow/or circuit breaker tripping every time on a normal wall outlet/circuit.
Best option is to get your local ELECTRICIAN to run a "DEDICATED" 15amp [or larger] CIRCUIT and wall outlet in the room where your Sun Bed is installed ...
The electrical amperage requirement for your unit should be found on the manufacturer's Compliance Plate [on your unit] ...
ALSO it is possible that there may be a FAULT in the top unit [sometimes caused by a damaged supply cable on the older type "CLAM-SHELL" units] ...
Probably best to have it CHECKED/TESTED by your local Electrician.
Sep 20, 2014 | Health & Beauty
Washing machine blowing trip?
It is best to disconnect the mains lines from the control panel to the different section, which are the motor, heater, inlet and outlet valve pump. If the fuse trips then the fault is the control panel board and could be a failure of the rectifier or SMPS driver. You might need to replace the board.
Jul 04, 2012 | Washing Machines
Genset starts and runs fine but the 30 Amp circuit breaker trips as soon as a load (AC) is applied. Started right up, ran half a day, but now when it starts the minutes I click on the ac the circuit...
What about when you have it powering the motorhome, without AC on, does it trip then? Do you have anyone you know with a multimeter and knows how to use it? How about buying a plug in voltage meter at a hardware store as a good start. You simply plug it in to a receptacle in your motorhome and it will tell you the incoming voltage and they are not very expensive. That will help diagnose generator problem.
Nov 01, 2009 | Watts Onan Portable Generator - 4000 ,...
Brand new microwave trips circuit as soon as it is plugged in, but does not trip the circuit the microwave is on
sounds to me like there is a reverse polarity somewhere ... Id be looking inside as how the power cord connects.
If you plug it in and blows the breaker, must be hot wire to ground.
Please let me know what you find.
I hope this helps sort your trouble out.
a
Oct 01, 2009 | Microwave Ovens
Have roof top air conditioner that blows air but soon trips breaker. any suggestions? Henry
check the condensor fan in the rooof unit. It's the fan blowing on the cpil on the roof.. If it failed, the head preasures can becme excessive andwork the compressor hard causing the breaker to trip. Let me know and good luck, Ned_
Sep 13, 2009 | Dometic Rooftop RV Air Conditioner
Rv electrical question
By the main breaker in the camper, do you mean the main 24 or 12 volt breaker, or the incoming 120vac breaker? Is it tripping the breaker in the camper, or the house? If it is tripping the breaker inside, i would look for maybe water damage, rusty components, maybe have an electrician come look at it, not worth going out away from home, and that problem ruining your vacation! Does this unit have a generator set? Try disconnecting the generator too. Hope that helps!
Jun 04, 2009 | Dometic Rooftop RV Air Conditioner
Electrical Supplies Logo
37 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
