Question about Garden
Have you a diagram for the bosch charger model number d 70745 need to know what the ohms is for a resistor
    Genius:
  • 1,015 Answers
If you can see the resistor then make a note on the color rings on it. If you go to a electronic supply store and tell them what the color code is they can tell you what it is rated at.Hope this helps you. Thanks
Posted on Mar 20, 2011
Need a circuit diagram of a dewalt charger DE9108-xe 7.2V-18V one hour charger type 1:Q 96307-12/15 OUTPUT : 2.6A 7.2-18.0V 46.8VA
Can you (carefully!) measure the volts across them with a load (battery) and then the current through them by disconnecting one end, and if the charger is still working OK then they are V/I ohms, choose nearest value. 10k sounds very high, are you sure they aren't 1 ohm or less?
May 21, 2014 | Dewalt 7.2-18.0 Volt One Hour Charger
How to recharge bosch 70745
A Bosch 70745 is a cordless tool; the battery recharges with a power pack, or a plug in charging station. This is not a UPS Battery Backup system.
May 13, 2014 | Powerware Computers & Internet
I have a Toshiba projection T.V, model number 43J7DM.It is dead
247 is .050 watt15K ohm
404 is 0,25Watt 1K ohm
420 is 0.5 watt 10K ohm
513 is 0.25watt 100 ohm
However if you dont understand them dont play around with them you may end up doing more damage than what you have now. If resistors blow then some other fault has caused excess power to fuse them and that takes knowledge of how to measure the current at each step. Some of these resistors are related to the power board. Getting circuit diagrams from toshiba is difficult Quite often there is a diagram inside the chassis of each model.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Toshiba 55H70 55" Rear Projection...
Where can I obtain a circuit board for a bosch cordless drill charger, Charger is AL 2404, part number 2 607 255 185, also has D-70745 Leinfelden printed on charger
most tool manufacturers don't offer the circuit boards as a separate saleable part. I can't find anything at the Bosch website.
Jan 13, 2010 | Bosch Drills
Bosch Chain Saw D 70745 - fuses checked but will
The lever could be in a safety position. Unlock the safety lever to get it in contact with the switch., and squeeze to run.
Oct 22, 2009 | Bosch Garden
JVC AV-56WP74 Convergence part #'s
(2) STK392-110 Convergence Amp ICs
(3) 220 ohm 2watt metal film resistors
(3) 150 ohm 2watt metal film resistors
(2) 1.5 ohm 1watt metal resistors
(2) 2.2 ohm 1watt metal film resistors
(1) 1.8 ohm 1watt metal film resistor
(1) 3.3ohm 1watt metal film resistor
You can get the entire convergence repair kit which contains all the parts listed at the following link its called the AV48WP30 Convergence repair kit , but it applies to your model as well, and they include free installation instructions.
http://servicemanuals.vstore.ca/
Aug 18, 2008 | JVC AV-56WP74 56" Rear Projection...
Red arched ghost
But be careful as TV has high voltage inside.
Jul 16, 2008 | Hitachi 57F500 57" Rear Projection...
Garden Logo
228 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
