Hello, My washing machine MW 6152W instuction guide can't find it and my washing machine is now on but doesn't spin at all for nearly 8 hours now. Please help me to get my washing mashine work.
  • Washing Mach... Master
  • 1,527 Answers
Hello check the pump first it has drain water out first before it spins if the pump is ok then check the module board this controls the motor speed if this ok the brushes on the motor can cause it not to spin hope it helps
regards
shaun
Posted on Mar 20, 2011
My washing machine goes through the washing cycle normally but does not spin.
spin not clicking in
no power to motor or its kick in solenoid
check timer or control circuit board
Apr 30, 2017 | Washing Machines
Fridgidaire front load Frigidaire GLTF2940ES Front Load Washer will not spin
Hello there and welcome to fixya
I am hoping that you didnt replace these parts without testing every thing
Here is the complete troubleshooting steps for this problem
f your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. The transmission may not be shifting properly. these have a electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it. The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
Dec 27, 2011 | Washing Machines
Admiral washer will not spin but does agitate.
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely -if it's frozen or stiff- replace it.
a.- It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
a.1. If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
a.2. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.- It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
b.1. The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
b.2 The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
b.3 A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
b.4 The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
b.5 The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
b.6 The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
b.7 The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
c.- It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
Additional details in Admiral: Washer Use and Care Guide (PDF Format)
Check it and keep us updated.
Oct 10, 2011 | Admiral AW22 Top Load Washer
My washer doesnt spin at all on different settings.it is a kenmore super cap. 3.5 quiet tumle action washer front loading type, model nos. missing
there are several things that you will need to check first ok please verrify the following
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Sep 22, 2011 | Kenmore 3.5 cu. ft. Front Load Electric...
Washer won't agitate or spin
Sep 07, 2011 | GE Profile WPRE6100G Top Load Washer
My Defy 600 does not drain all the water out and wont s apin. When I try to start a new cycle it wont let any water in, i suspect thats cause there is still water in the drum. Help!!!!!
hello there and welcome to fixya
Aug 23, 2011 | Washing Machines
Kenmore washer 90 series - 1/2 hour ago we replaced the coupler and clutch because it would not spin. Now, it spins great - if you manually set the knob to spin! It will not move through the cylcles...
the first thing to check is if the small appx. 3/8" diameter clearish rubber hose got disattached from the side of the outer tub espically if before replacing cluctch is didnt overflow
Aug 12, 2011 | Kenmore Washing Machines
My washer wont spin
Hello there and thank you for choosing fixya
This can be a rather easy fix or it can be a nightmare so i will post everything i have here for you to check ok
It doesn't spin It doesn't pump or spin
Aug 05, 2011 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
