Question about Exercise & Fitness
I have a LIFE GEAR - Easy Track 97478: http://www.lifegear.com.tw/product_3.asp... When I turn the power ON, the treadmill start to beep over and over like an alarm. The display is write E2 error code.I wait for their help!Thank you!
bwinton
  • 83 Answers
SOURCE: life fitness treadmill display: transistor error-won't run
This error shows up if motor controller detects a failed part. This isn’t a reset-able error. Treadmill will not allow workouts until serviced.
Solution
Main motor wires/leads could be disconnected at the start of a workout. If the motor is properly connected and in working condition then the drive transistor could have failed. Check Motor Controller.
Posted on May 07, 2010
maxtreadmill
  • 832 Answers
SOURCE: E2 Code on Treadmill after starting
This is a speed sensor error. Unplug the unit then remove the motor shroud locate the power board with LED lights plug in unit locate the 5v DC if this is on then replace the speed sensor.The sensor is located on the frame by the front roller pulley or on the Drive Motor itself. Call IconFitness @ 1800-999-3756.
Posted on Jun 27, 2010
dj_relly999
  • 4070 Answers
SOURCE: healthrider treadmill modle #HTRL21470 serial
Hi and welcome to FixYa!
An E2 is definitely a system failure. As a first course of action I strongly suggest that you press the reset button on the frame near the power cord. This will reset the system and can get the treadmill back to it's normal operation.
If the problem still persist please unplug the unit from power source and switch the treadmill ON while unplugged to hard reset the system.
Hope this helps and thank you for using FixYa! Have a good one!
Posted on Jan 17, 2011
anupam19
  • 263 Answers
SOURCE: I have life gear treadmill.
you need to recalibrate your meter
Posted on Mar 16, 2011
  • 1196 Answers
SOURCE: I have a Life Gear
I will suggest you try reset it, Press POWER to turn off the treadmill, At the same time, press and hold the +, -, and POWER keys. Continue holding all keys until their is nothing on the screen display. Release the keys. insert the key properly and see what happens. With that, the problem should be solve.
Posted on May 01, 2011
How to insert batteries in a life gear path flashlight
Hello, Sandra -
From a Life Gear web page with frequently asked questions:
http://www.lifegear.com/faq
(Quote)
  1. How do I change the batteries in my Life+Gear flashlight?
We are currently in the process of uploading instructions on how to properly change the batteries in your Life+Gear flashlight, in the meantime please feel free to contact our customer service department for instruction. If you are unsure about which model you have, you can upload a picture of your flashlight and attach it to your email.
(End quote)
The email address for Life Gear Customer Service can be found here:
in the lower left corner of the page.
I do not find a Customer Service phone number you could call.
Best wishes.
May 03, 2018 | Camping, Backpacking & Hiking
How do i fix a lifegear treadmill 97520?
Try below:
ERROR CODE
DESCRIPTION
E1
Speed error (The treadmill running speed is 3.2 kph faster than the displayed
speed). The treadmill will stop immediately when the console detects this error.
E2
Speed error (The treadmill running speed is 3.2 kph slower than the displayed
speed). The treadmill will stop 16 seconds later after the console detects this
error.
Troubleshooting / Resetting error codes
In the rare event of the treadmill displaying an error code ("E" followed by a number), simply reset
the computer by:
1. Step off the treadmill. Ensure that you are clear of the running belt.
2. Turn the treadmill off at the master power switch located near the motor housing.
WARNING: Ensure nothing is positioned near or under running belt which may possibly block
3. Turn the treadmill on at the master power switch.
4. Ensure that the Safety Tether Key is securely and properly installed onto the console or just
reinstalling the Safety Tether Key can also reset the display.
If the above does not clear the error code, please contact the nearest Dealer/Service Center
LifeGear 97320 Owner Manual Page 17
May 22, 2016 | Exercise & Fitness
Battery number for lifegear magnetic oxy cycle
http://www.lifegear.com.tw/PDF/16063-Motorized%20Oxy%20Cycle%20Manual.pdf TO REPLACE THE DISPLAY BATTERY:
When the display screen begins to fade, replace a 1.5V "AAA" size battery.
Disengage the digital display computer from top of the device by gently pulling
on it; replace a 1.5V "AAA" size battery.
Nov 15, 2014 | Computers & Internet
Life gear Silver Track 97420 Manual
www.manualsonline.com
If you wish to get some details; visit the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Sep 20, 2013 | Nordic Track NordicTrack Treadmill, A2550
Lifegear motion plus 97920 problem
please adjust the REED switch and see the diagram attached. Test for open or faulty. Clean it + tight the connector very well.
2) if you equipment has battery replalce by new ones and clean it, and putt with FULL energy.
3) TIGHT THE RIBBON CABLE for keypads , clean it and try again.
God bless you
Feb 22, 2013 | Exercise & Fitness
3 long beeps error
Hello here is the homepage:
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=271&DetailName=Feature&MenuID=1&LanID=0
Here is a list of beep codes:
http://www.computerhope.com/beep.htm
3 long beebs, means you have a keyboard error.
The power supply, could also be failing.
Look for any drivers missing, in the device manager.
Good luck
Dec 22, 2011 | PC Chips M925G (M925G V9.1B) Motherboard
I need the I.C number on a Lifegear Walkease Motorized Treadmill # 97295, found out the ic was burnt on the control panel whicl always display E2 code
Dear Sir:
1)In electronics, you must need to get the number of IC.
2)If you get some information like as the number of the Control Panel, will be more easy to find, the I.C.
3) You must shure the why the I.C. was burn? . Normally this problem can occur a) failure for some short of some component around the I.C. b) Power supply +5 or 12 Vdc or Low or Higher( Indicating that power supply is Not Good).
4) Would you please tell the exactly Model, Mark, Serial from your Treadmill? In that way I can help you more, and try to get the Schematic Diagram from your Fitness Treadmill.
Sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 24, 2011 | Exercise & Fitness
Exercise & Fitness Logo
81 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
