Question about Health & Beauty
My bed was working fine but then the bottom half kicked off and will not come back on. I have unplugged the plug from the top of the unit to the bottom and reconnected it but the bottom still does not come on what is the issue.
  • 3 more comments
  • rb21golf Mar 20, 2011
    Model F-2x32H
    It is a Sun Star model F-2x32h Tanning bed.
    Sun star model F-ZX32H 220 v
  • rb21golf Mar 21, 2011
    My wife was using the bed and the bottom half kicked off and did not come back on. The bed is a Sun Star model f-zx32h. I have unplugged the shaver and plugged it back in but that did not make the bottom half come back on.
    How would I get to the fuse to check it?
    President:
  • 2,047 Answers
Sorry but the question you have asked is incomplete. Which Bed are you talking about and also how did the bottom half kick off? Please give more concise details.
Hoping to hear from you soon.
Posted on Mar 20, 2011
  • Rockme
    Rockme Mar 21, 2011
    can you check the supply of power to the lower part? It is either this or a burnt fuse inside the unit.
  • 3,247 Answers
Not sure if you have a problem with the bed or a shaver.
need the make and model number.
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
Wolff sunquest bottom lights dont turn on
There should be a cord that goes from the top of bed to the bottom section of the bed in the back of the bed. Make sure the cord is plugged in all the way and is not broken. This cord could be bad, the plugs may be bad, the cord could be missing entirely. A connection to the plugs could be burned out inside the top or bottom sections or at the main power relay.
Sep 18, 2012 | Wolff Sunquest Pro 24RS 220 Volts
Scanner grinds when powers on
Its not drivers issue, hard ware issue.. Scanner assm faulty,replace it..For tech guys:Open flat bed glass, remove scanner assm clean inside reflector glass with ear buds & adf glass especially at home position.. lubricate on rail refix it back.. check it..
Dec 22, 2011 | HP Photosmart C4580 All-in-One InkJet...
Change a fuel punp on a 1987 dodge dakota
I have found that the easiest way is to remove the bed. Take the three nuts out that hold the flange inside of the fuel filler door. Remove the 8 bolts that hold the bed on from underneath. Unplug the tail light wires. One person on each side at the wheel well, lift it and slide it off, either completely, or half way (the second way helps to have two milk crates placed behind the vehicle). Remove the fuel lines and unplug the sending unit at the top of the tank. Unscrew the outer ring and remove the sending unit. Either that, or drop the tank which can damage the lines, etc.. then reconnect and lift the tank back into place. Removing the bed is usually the easiest route and the biggest time saver. Please rate my assistance, and leave a testimonial.
Jan 01, 2011 | 1987 Dodge Dakota
Problem with Whirlpool side by side refrigerator (Model ED25RFXFW01). Approximately 6 weeks ago, I found the refrigerator had quit cooling and ice in the ice maker was melting. The top half of the freezer...
sounds like a defrost problem ...
maybe the heater or defrost thermostat is bad...
he should bypass the timer and jump the heater to see if its woking...if not then i would remove the heating element for further testing. if the heater checked ok..it would only leave the defrost timer to blame.
good luck
Oct 05, 2009 | Freezers
I havs a side by side and the top won't stay cold or freeze.
Cold air being heavier than warmer air will settle to the lower levels. Check for fan motor operation inside the freezer section. If the fan is not operating you meed service. Also check for frost on the back wall of the freezer section. If the fan motor does not circulate the air frost will form on the back wall, also if the defrost system is not functioning.
Dec 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
May 27, 2008 | GE JBP69 Electric Kitchen Range
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I...
The top part of my fridge is not working properly.It is not keeping food cold. The bottom freezer unit is working fine. I have cleaned the back and I have unplugged the fridge and plugged it in again. I have also turn the buttons off and on inside the fridge.
Feb 21, 2008 | Zanussi ZX97 / 5 Bottom Freezer...
Freezer working fine, but Refrigerator no longer cooling
Sounds like there's an airflow problem to the top section. Things that cause no cold air to the top fridge section are... frozen up coils completely blocking most of air flow (defrost cycle not working), evap fan not working to blow air up to fridge, air control dampers in fridge closed or not working properly, or frozen air ducts supply/return. Pull the whole drawer out the bottom and take the rear inside back off to expose the coils. If they are frozen solid the defrost t-stat or defrost timer could be bad (heat element not usually bad). If there is a nice white frost all over evenly then that's OK. Check that the fan is running when the compressor is running to blow the air up and that there are no blocked air ducts, etc. If all that is good, check if you can feel good air flow from the upper vents with the lower door closed (that shows there is no blockage and the fan is running).
Jan 06, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
