Question about Karcher Garden
Will not switch on karcher 520M, have changed fuse
    Sergeant:
  • 259 Answers
You have to see if you are getting power to the switch with a volt meter you should be getting 110 volts.
Posted on Mar 20, 2011
  • stevekitcher Mar 20, 2011
    done that already
  • Tim Venetis Mar 20, 2011
    Somehow if you can get to the motor shaft make sure it is not seized up, it should turn easy. Check the brushes of the motor also they would be under screw caps.
2 Suggested Answers
  • 46 Answers
SOURCE: karcher 520m oil leak
small engine shop should be able to obtain the proper gasket for you.....oil 20 weight fill untill you can see it at the bottom of the threads at the whole you pour it into!
Posted on May 25, 2009
Karcher pressure washer doesn't work
it;s normally a switch interrupter must replace with actual with for motor protection.
Aug 14, 2014 | Karcher Garden
Karcher gun leaking
the gun needs replacing, non servicable, interchangable with many brands
Mar 21, 2014 | Garden
I have a 520m karcher high pressure cleaner when turning it on it trips the electricty therefore I cannot start
try turning the motor by hand somehow to c if u can free it then try again or possible bad capacitor??
Jan 02, 2014 | Garden
I have Karcher 520m and when you press the trigger you can hear what sounds like a relay engaging but there is no water pressure, then it will fire up and work, but next time you press the trigger the...
The issue you are having is with the unloader valve in the pump. Now with the 520m it is a little bit harder to repair than with more gasoline powered pressure washers but it can still be done. It would be easier if I could just send you a email of the breakdown on the machine. Send me a email to justin@wmpcs.com with the discription of the problem you are having.
Oct 10, 2010 | Karcher 1750 Psi Elec Pressure Washer
Karcher 520m oil leak
May 24, 2009 | Karcher 2500 PSI Pressure Washer
Karcher 520M wont operate at high pressure
The solution is very simple. All you have to do is change the spill valve.
This because the spill valve is not worth servicing. The actual problem is that the spill valve is leaking from its bottom-part seating. When you close the gun, the spill valve goes down, opens from the underside, and switches the electricity off. When you press the gun, the spill valve returns to normal, and if the underside does not close, you have low presure, because the water keeps circulating.
Regards,
MG. (Karcher service engineer).
May 05, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 520M Pressure washer won't operate at high pressure
I had the same problem - good water inlet pressure, no output pressure, even though the lance and handle seemed to be clear and working find.
I found that the electrical switch wasn't being operated correctly by the spill valve and wasn't turning the motor on/off correctly.
Inside the plastic electrical box there is a small white device that presses against the micro switch assembly. Carefully adjust the allen screw perhaps 1/4 turn out or 1/4 turn in to obtain correct operation of the microswitch - you will hear the micro switch clicking in and out when re-assembled. I'm sure they must have a rig to check correct positioning of this screw in the factory!
Hope it helps - mine is working find now and saved me buying another!
Garden Logo
684 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
